#15 |
Stories like this really make me hesitant to boost the twins
| The Following User Says Thank You to jflogerzi For This Useful Post: | FRS_FIEND (06-25-2014) |
#16 |
Drives: BRZ DGM Limited
#17 |
Drives: 2019 BMW ///M4
Eeekkk.... curious as to what happened.
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension |
#18 |
Drives: 2014 WRB BRZ LTD
Mine blew at 37K. This makes me less inclined to think it was due to the year old front end repair. Especially since they gave me no trouble whatsoever about replacing the engine, even knowing about the previous work.
Sent from my SPH-L720 using Tapatalk |
| The Following User Says Thank You to Annahra For This Useful Post: | Mr 286 (05-12-2014) |
#19 |
Drives: white Sport-tech
How long on that oil? Last time checked? Go through any overly big puddles lately? Check air filter lately? Notice any smoke from the exhaust after warm up? ANY sign of anything going bad?
| The Following User Says Thank You to Muskokan For This Useful Post: | strat61caster (05-11-2014) |
#20 |
Drives: 2013 Raven FRS MT
Keep us posted. Sure all will be resolved without any headaches. Good luck buddy.
| The Following User Says Thank You to AVodka14 For This Useful Post: | Mr 286 (05-12-2014) |
#22 |
Time Traveller
Sorry about your car OP.
Still $14k of collision damage could have netted some impact on the engine that was not diagnosed during the original repair. This one I wouldn't lump with other failures on that reason alone. |
| The Following 11 Users Say Thank You to DAEMANO For This Useful Post: | Creole (06-09-2014), evan (05-10-2014), FRSBRZGT86FAN (06-10-2014), ftc~brz (05-16-2014), Lonewolf (05-10-2014), Mr 286 (05-12-2014), Pseud0logik (05-13-2014), strat61caster (05-11-2014), transition (05-23-2014), tyrantcf (05-11-2014), zoth (05-14-2014) |
#23 |
#teamswagoi
Drives: 2014 Raven FR-S Monogram
Man that sucks , hopefully everything goes well man .
On the bright time you get to spend some quality time with old faithful
#24 |
Drives: fr-s
The motor is fine. There are flukes in any mass produced object. People would be surprised at how many iPhones Apple "swaps" under warranty. Yet, the phones are held in the highest regard in terms of build quality.
| The Following 6 Users Say Thank You to evan For This Useful Post: | Creole (06-09-2014), FRSBRZGT86FAN (06-10-2014), Pseud0logik (05-13-2014), samisons (05-11-2014), Sportsguy83 (05-11-2014), strat61caster (05-11-2014) |
#26 | |
Sent from my SGH-T999 using Tapatalk
2013 Series 10 FRS #553
| The Following 3 Users Say Thank You to jflogerzi For This Useful Post: |
#27 |
Drives: fr-s
That is correct. It will hurt financially. If you can support your hobby without straining your wallet, then all power to you. While I am fortunate to be able to do so, I am sometimes attracted to the idea of a factory reinforced/high-power car and keeping the warranty. Yes the initial outlay is higher, but over time it amounts to less headaches and money spent. Problem is, modding is addictive regardless. Once you catch the bug, it's really hard to shake off.
#28 |
| Tags |
| blown engine |
| Engine Failure (#4 Rod Bearing + Short Block) | eriktherod | Issues | Warranty | Recalls / TSB | 215 | 10-30-2015 12:24 AM |
| Crawford posts of engine failure example at 218hp | OICU812 | Engine, Exhaust, Transmission | 95 | 03-27-2015 05:40 PM |
| Major accident/Engine failure after repeated P0351/P0017/P0019 | DB86 | Issues | Warranty | Recalls / TSB | 48 | 09-16-2014 03:05 PM |
| Stock Engine Failure | Annahra | Issues | Warranty | Recalls / TSB | 37 | 06-25-2014 01:42 PM |
| Will I get a check engine light on if the engine bay has a direct injection failure? | Astroboy | Engine, Exhaust, Transmission | 7 | 03-29-2014 06:16 PM |
