Old 05-09-2014, 02:45 AM   #1
existensil
existensil's Avatar
Drives: 2014 BRZ Limited
93 octane w/ethanol or 91 without
In my area some stations offer 93 octane (with 10% ethanol) premium, and others offer 91 octane premium (no ethanol). They are basically the same price. Which would you chose?
Using 93 for now.
existensil is offline   Reply With Quote
Old 05-09-2014, 03:02 AM   #2
husker741
Drives: 2013 Whiteout Scion FR-S 6MT
When I was back in Nebraska, I was only doing 91 without ethanol. The minute I used 93 with 10%, I got crickets. So if it were me, I'd go with 91. Now I have no choice and can only put in 93 with 10% ethanol and I get crickets all the time. Ugh.
husker741 is offline   Reply With Quote
Old 05-09-2014, 04:17 AM   #3
Kostamojen
Ethanol = Crickets
So ya, no Ethanol
Old 05-09-2014, 04:24 AM   #4
SilverlightPony
SilverlightPony's Avatar
Drives: '13 Subaru BRZ, '06 Toyota 4Runner
Crickets?
SilverlightPony is offline   Reply With Quote
Old 05-09-2014, 09:19 AM   #5
existensil
existensil's Avatar
Originally Posted by SilverlightPony View Post
Crickets?
Yeah, I'm a little confused exactly what this means too. Seen "crickets" mentioned elsewhere. Guessing a reference to some engine sound and not an infestation of one of nature's more annoying insects?
The Following User Says Thank You to existensil For This Useful Post:
Alfr-s (05-10-2014)
Old 05-09-2014, 09:41 AM   #6
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
Ryan86 is offline   Reply With Quote
Old 05-09-2014, 09:46 AM   #7
TM
TM's Avatar
Drives: DGM BRZ 6MT
Crickets?
Listen to this video for the crickets: http://www.ft86club.com/forums/showthread.php?t=65189
TM is offline   Reply With Quote
Old 05-09-2014, 09:50 AM   #8
TM
TM's Avatar
Drives: DGM BRZ 6MT
I also read somewhere on the forums that 91 no ethanol and 93 with 10% ethonal have the same 91 fuel.
The 113 octance rating of the 10% ethanol brings the 91 fuel rating up to 93:
(91 x .9) + (113 x .1) = 93.2
Old 05-09-2014, 10:22 AM   #9
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
93, crickets never bothered me, never spend much time idling and they've gone away on their own.
ineedyourdiddly
Old 05-10-2014, 09:55 AM   #10
Xinshadow
Drives: 2013 Scion FR-S Ultramarine
93. Crickets are fixed easily enough with a nice catback and I like the extra insurance of 93 for knock protection, particularly on hot days.
Sent from my XT1056 using Tapatalk
Current mods: OFT Stage 2 (w/93 oct), OFH, Perrin Resonated catback, DSS Aluminum Driveshaft, Perrin drop-in filter, Avo silicone inlet, Mishimoto catch can, Grimmspeed MCB, Perrin crank pulley, Nameless overpipe/downpipe combo, DBA slotted rotors, Ferrodo brake pads, goodrich SS brake lines, DOT5 synthetic brake fluid.
Xinshadow is offline   Reply With Quote
Old 05-10-2014, 12:51 PM   #11
BadMoon
BadMoon's Avatar
Drives: 2014 GLI Autobahn/Nav
How the hell is the "fuel pump" fixed by adding a catback?
BadMoon is offline   Reply With Quote
Old 05-10-2014, 01:23 PM   #12
Xinshadow
It covers the noise pretty well! After all that's all it is, an annoying noise.
The Following User Says Thank You to Xinshadow For This Useful Post:
BadMoon (05-10-2014)
Old 05-10-2014, 09:45 PM   #13
roddy
roddy's Avatar
Drives: '13 Ultramarine
From my experience, the higher octane you can go, the better (at least in warmer weather). In my area, we have 94 with ethanol, and 91 without. In temperatures above 75 degrees F or so, the car runs noticeably better on the 94. So much so that I put up with the damn crickets to run it (no crickets on the pure gas 91).
Old 05-10-2014, 11:04 PM   #14
extrashaky
The high pressure fuel pump in this car often makes a squeaking sound at idle that sounds just like crickets chirping. The comparison is uncanny.
Some people swear that ethanol is the source of the crickets. However, in the 186 page thread on this subject in the tech section, there are people who have reported crickets on ethanol-free gas, and there are people who swear their crickets went away when they switched over to E85. If ethanol were the culprit, we should see consistent results for everyone, and we don't.
Personally, I think these fuel pumps just sound like this, and the people who don't have them are the exception. I also think the additive packages in the fuel blends can make them better or worse. Unfortunately, since there are more than 20 blends of gas marketed in the US, there is no way you can be sure what exactly you are putting in your tank, even when you fill up at the same station every time.
Some people have reported success in getting rid of crickets by using either an upper cylinder lubricant or ashless two-cycle oil as a fuel additive. Their thinking is that the extra lubrication in the fuel smooths away the cricket. I'm about to try Marvel Mystery Oil myself. We'll see how it goes.
The Following User Says Thank You to extrashaky For This Useful Post:
Allch Chcar (05-24-2014)
Higher Octane or Ethanol Free Chad86 Scion FR-S / Toyota 86 GT86 General Forum 1 03-28-2014 10:06 PM
Non ethanol gas reesmicm Scion FR-S / Toyota 86 GT86 General Forum 21 08-21-2013 02:14 PM
Ethanol Andrew666 AUSTRALIA 30 08-09-2013 08:13 AM
91 w/o Ethanol, or 93 with 10%? Superhatch Engine, Exhaust, Transmission 21 05-20-2013 10:07 AM
100 octane race gas: 91 octane ratio? GhostofAkina Scion FR-S / Toyota 86 GT86 General Forum 15 02-08-2013 01:23 AM
