Old 04-25-2014, 03:29 PM   #4607
robwbright
Drives: '13 BRZ Limited WRB Phantom ESC 1.5
Originally Posted by fenton View Post
You do everytime you create a negetive pressure between the charger and the throttle body.
His mode just lets him go WOT without the boost. In standard mode drag reduction will kick in and give you the NA feel.
I LOVE drag reduction....any time you tip into the throttle the charger adds just a bit of boost to get you going.....im tempted to call it 'torque fill' but then mclearen might sue me
Drag reduction really is the crown jewel of this whole system.
I think I understand all that... The option of WOT without boost is just that - an option... and I like to keep my options open. LOL.
I think what you're describing with the term "drag reduction" is the resolution of the problem of the fan blocking the intake when the fan isn't moving..?
'13 BRZ Ltd MT WRB Phantom ESC 1.5
2012 Honda Accord Coupe
2006 Saab 9-3 2.0t
1997 Honda Accord Coupe
1995 Honda Prelude VTEC
robwbright is offline   Reply With Quote
Old 04-25-2014, 03:42 PM   #4608
Bu-Tang
Drives: 2013 Scion FR-S, Nissan Pathfinder
Originally Posted by robwbright View Post
Rob, is that starter battery going to be strong enough to work all winter?
And also, if I were to go with a stronger, larger starter battery, would I still be able to get the 1.5 dump pack and the starter battery under the hood?
Thanks.
Hi Rob. That starter battery should work under most conditions if you are using it regularly. We regularly get -20 to -30C, i ran a slightly larger battery and mine worked flawlessly....it did fit with the 1.5dump but it wont fit the standard battery tray that Rob sends with the 1.5 dump.
@Bu-Tang used the small starter this winter, i will let him speak to his experience with starting in the cold.
[ame]http://youtu.be/VroXMtPPLLU[/ame]
This was my cold start after sitting in -30C for 5 days without starting.
I drove mine all winter and when it was -40C with windchill it was a slightly weak start but still fired right up. you will not run into a single issue if you drive your car on a regular basis and dont leave it parked for long periods of time EG: several days outside in -30 or colder in windchill condiditons.
These batteries in -15 will perform just like the factory battery.
Bu-Tang is offline   Reply With Quote
The Following User Says Thank You to Bu-Tang For This Useful Post:
robwbright (04-25-2014)
Old 04-25-2014, 03:43 PM   #4609
robwbright
Beautiful. Thanks!
2006 Saab 9-3 2.0t
Old 04-25-2014, 04:39 PM   #4610
Jac
Drives: Fiat Abarth
I'm interested in being able to run in non-boosted mode. I'm not entirely sure why, but I am. LOL.
Its nice to have the choice. It can be annoying sometimes to accidentally activate the ESC when i didn't mean to, especially on corners.
Jac is offline   Reply With Quote
Old 04-25-2014, 04:57 PM   #4611
fenton
Maybe adjust your WOT switch closer to 100% throttle? I had mine too far in for a while too.
fenton is offline   Reply With Quote
Old 04-25-2014, 05:00 PM   #4612
Jac
Drives: Fiat Abarth
Mines at like 90%, I think i just suck at pedal modulation.
Old 04-25-2014, 06:28 PM   #4613
TM
TM's Avatar
Drives: DGM BRZ 6MT
My package just got out of customs this morning. I guess this weekend is not the weekend I get to install it. Hopefully, I get to install it on Monday, but it's going to be raining all week. sigh.
Should've ordered the 1.5 dump batteries together with the other batteries. Now I'm going to have to pay for shipping when I'm ready to order it. I'm cheap haha
TM is offline   Reply With Quote
Old 04-25-2014, 10:27 PM   #4614
shif7i7down
Erected Member
Drives: frs
after reading 4,625 post, i've decided to jump on the band wagon, finally put in a order for a esc kit.. yaah me.
Last edited by shif7i7down; 04-25-2014 at 10:27 PM. Reason: just kidding about the 4625 post thing ^_^
shif7i7down is offline   Reply With Quote
The Following 2 Users Say Thank You to shif7i7down For This Useful Post:
drewbot (04-25-2014), Sojhinn (04-25-2014)
Old 04-25-2014, 11:45 PM   #4615
nlowell
nlowell's Avatar
Drives: 2013 Scion FRS
Congratulations! Welcome to the club
nlowell is offline   Reply With Quote
Old 04-26-2014, 02:07 AM   #4616
nlowell
nlowell's Avatar
OK - so after having high AFR on my tune and hearing all about how California gas is crap, I figured I'd try something. I bought a can of Torco Unleaded Accelerator from Amazon and added ~10oz to a full tank of Shell 91. This should make the tank ~93-94 octane according to the bottle.
On the way home I did some pulls and I'm convinced that this stuff works! While I'm still running pretty lean, it's way better than it was before. Shiv just gave me an adjusted tune and I'm hoping it makes it even better...heading in the right direction!
(Side note: my boost shows 4.21 at maximum...seems high...how accurate is this calculation?)
Before Torco - 2nd Gear Pull
After Torco - 2nd Gear Pull
After Torco - 2nd Gear Pull (with Boost shown)
The Following 2 Users Say Thank You to nlowell For This Useful Post:
DAEMANO (04-26-2014), WRB5titch (04-26-2014)
Old 04-26-2014, 02:13 AM   #4617
Robftss
Drives: VW
Looks perfect now
Sent from my HTC One using Tapatalk
Robftss is offline   Reply With Quote
Old 04-26-2014, 02:23 AM   #4618
nlowell
nlowell's Avatar
Eh, 15:1 is still too lean, right? Shouldn't I be somewhere in the 12s?
Old 04-26-2014, 08:18 AM   #4619
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
Your only regret will be that you had to read 4,625 posts.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
Old 04-26-2014, 08:31 AM   #4620
Gary in NJ
Gary in NJ's Avatar
The ECU (even a tuned ECU) will always seek a stoichiometric air:fuel ratio (AFR) when lightly loaded. The stoichiometric is a value of ~14.8:1 and is considered neither rich or lean. Fuel additives can drive this value lower (because there is less combustible material in the mixture). Running a 14.8 AFR at partial throttle is normal and good for economical operation and component life. Running an AFR below 12.0 while at WOT is desirable to help cool the piston and valves, which also extends component life (or more accurately reduces the chances of catastrophic failure).
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
