Old 04-24-2014, 12:51 PM   #4509
fenton
Originally Posted by robwbright View Post
Rob, is that starter battery going to be strong enough to work all winter?
And also, if I were to go with a stronger, larger starter battery, would I still be able to get the 1.5 dump pack and the starter battery under the hood?
Thanks.
Hi Rob. That starter battery should work under most conditions if you are using it regularly. We regularly get -20 to -30C, i ran a slightly larger battery and mine worked flawlessly....it did fit with the 1.5dump but it wont fit the standard battery tray that Rob sends with the 1.5 dump.
@Bu-Tang used the small starter this winter, i will let him speak to his experience with starting in the cold.
fenton is offline   Reply With Quote
Old 04-24-2014, 12:52 PM   #4510
TM
TM's Avatar
Drives: DGM BRZ 6MT
I assume these are the ones you ordered?
http://www.phantomsuperchargers.com/batteries.html
Did you go with that starter battery? Or something stronger? I want to do the 1.5 dump pack and keep everything under the hood... but we have temps down to -15C here occasionally.
Yeah, I just ordered the one linked from the FR-S/BRZ developer's kit page. I think we get down to -15C at the very extreme during our winters here, but I plan on moving somewhere warmer before next winter.
TM is offline   Reply With Quote
Old 04-24-2014, 12:54 PM   #4511
fenton
Here is another picture of the conversion kit and how it all looks when grouped with the other dumps. Rob has created a very clean installation.
Sent from my HTC One using Tapatalk
Old 04-24-2014, 01:37 PM   #4512
nlowell
nlowell's Avatar
Drives: 2013 Scion FRS
Awesome, thanks Fenton - looks nice! My mini batteries arrive tomorrow - I'll just stare at them for now until I get my upgrade kit =) I love the upgrades - keep 'em coming and keep up the great work Rob!!
nlowell is offline   Reply With Quote
Old 04-24-2014, 01:44 PM   #4513
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Attachment 76059
Attachment 76060
Here's how it looks installed for people to get an idea how it looks when its done.
Installed Mods:
Old 04-24-2014, 01:53 PM   #4514
robwbright
Drives: '13 BRZ Limited WRB Phantom ESC 1.5
This winter was REALLY cold for this area. Normally we'd have nighttime temps no lower than -12C and daytime temps ranging from -10C to +5C, but it actually got down to -20C two or three nights with daytime temps in the -17C to -10C range... but that was only for several days/nights. Still, the average temps were probably 5-10C colder than any other winter since 1978.
I would be concerned that the small starter battery wouldn't work at -20C, but: (1) that's a very uncommon occurrence around here; and (2) I likely wouldn't be driving anyway.
Still, I think I'd prefer a larger battery just in case. Which larger battery did you use, what tray did you use to put it on and where did you get that tray?
Thanks!
'13 BRZ Ltd MT WRB Phantom ESC 1.5
2012 Honda Accord Coupe
2006 Saab 9-3 2.0t
1997 Honda Accord Coupe
1995 Honda Prelude VTEC
robwbright is offline   Reply With Quote
Old 04-24-2014, 01:54 PM   #4515
BRZlimited
BRZlimited's Avatar
Drives: 2013 Subaru BRZ limited
Here's an idea. What if some where down the future it's possible to incorporate a hybrid type car brake regeneration design in which the battery can be charged also from braking to a red light or stop sign. Something like this would reduce the charge time for the battery. And since this car isn't electric all four wheels wouldn't need this system, you could go mini scale and have it on only one wheel or just the two front wheels. Just an idea.
BRZlimited is offline   Reply With Quote
Old 04-24-2014, 01:56 PM   #4516
robwbright
I suppose I could just buy the regular one and then if it doesn't work out in the winter, buy a larger one just for winter use and put it in the trunk or something...
2006 Saab 9-3 2.0t
Old 04-24-2014, 01:57 PM   #4517
Sojhinn
Sojhinn's Avatar
Thanks!
Honestly guys we argued this a long time ago. You don't need to swap out the starter battery. Its fine. Give it a shot and I know it will work. Im so confident in it that IF I were a little richer I would offer you your money back on the starter battery if it did not work out. I had it sit for 2.5 weeks and it fired up on the first try. Gary had it sit in cold weather multiple times and it worked, and I think Bu-tang is running a audio system on it.
Trust me its fine.
Installed Mods:
Old 04-24-2014, 01:59 PM   #4518
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
Being an RWD a simple system could be added to the rear driveshaft or pinion on the rear axle like they do for some rock crawlers like this:
Luckrider is offline   Reply With Quote
Old 04-24-2014, 02:00 PM   #4519
robwbright
Trust me its fine.
Sounds good to me. I'll go with it.
2006 Saab 9-3 2.0t
Old 04-24-2014, 04:53 PM   #4520
Urmyson
Can someone measure that battery tray for me?
Urmyson is offline   Reply With Quote
Old 04-24-2014, 05:16 PM   #4521
Robftss
Drives: VW
PM's sent to individuals regarding May TQ250 kits(w/1.5 upgrade option) and standalone 1.5 dump pack additions.
Due to the demand of the 1.5 dump pack upgrade my initial target of May 5th to 9th my get pushed by a week.
Thanks all
Robftss is offline   Reply With Quote
Old 04-24-2014, 05:25 PM   #4522
Boxer486
Drives: small
Originally Posted by TM View Post
My batteries just arrived today! Boy were they heavy.
Like how heavy?
Boxer486 is offline   Reply With Quote
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
