Old 04-21-2014, 01:01 PM   #29
cjsporl1996
Drives: WRB BRZ, Monte Carlo SS
Ok I changed my mind again I'm going with a staggered setup.
What is an ideal wheel width for a 235 tire and I'm assuming a 9.5 wheel for the rear?
@CSG Mike
cjsporl1996 is offline
Old 04-21-2014, 01:28 PM   #30
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
There is no "ideal" wheel width. A 235mm tire should be about 9.25 inches wide. If you want some stretch then go with a 9. If you want more stretch go with a 9.5. Generally I like to stay within the tire manufcaturers rim width recommendation so decide on a tire and go to their website or Tire Rack. If you want stretch go with the largest they advise and if you want meaty, then go with the smallest.
King Tut is offline
Old 04-21-2014, 09:05 PM   #31
CSG Mike
CSG Mike's Avatar
Sorry, I can't recommend ANY Rota wheel.
CSG Mike is offline
Old 04-22-2014, 04:06 AM   #32
OjiGeorge
OjiGeorge's Avatar
Drives: White 2013 FRS
I ran a 235 f on an 8.5 and a 255 r on a 9.5, Hankook V12. Now I'm square and I'd recommend you re-think your position unless you are putting down 400whp+
To add: if I hadn' ave gone square I would have tried to put a 245 on the 8.5. The balance will be off. I ran quite a bit of front camber and it still was under-steering. I'm not a great drivier. If you are then maybe you will make up for it, but I still think you will enjoy the car immensely better with a square setup.
If you are hell bent on some 235's I'm selling mine. Once you go square, you wont go back...
OjiGeorge is offline
enkai, tire advice
Square Tires on Staggered Setup OjiGeorge Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 01-10-2014 09:31 AM
Which square or staggered setup should I go with? switchlanez Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 50 01-07-2014 11:51 AM
Square vs staggered setup slowbrz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 05-11-2013 10:18 PM
Rays 57 Xtreme - 18x9.5 +40 - Square setup No Limit Motorsport Wheels and Tires 16 01-21-2013 02:59 PM
Square Setup w/ Rear Spacers thejevans Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 01-11-2013 04:53 PM
