View Poll Results: Have you blown your stock motor with boost?
Yes complete failure needs rebuild 32 5.39%
No been boosting and running strong 188 31.65%
Nope because I am not boosting my motor 374 62.96%
Voters: 594. You may not vote on this poll
Old 04-21-2014, 12:48 PM   #169
AZFA20
Automotive Connoisseur
AZFA20's Avatar
Drives: too many cars
Originally Posted by Reaper View Post
Any reports of piston or ring land issues? I'm on e85 and a budget and thinking about running fullblown rods with oem pistons.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
If you are going to go through the trouble of tossing a set of rods in, it would make very little sense to not also put a set of pistons in. It's kind of like replacing a clutch and not replacing the throw-out bearing. You are in there anyway so you might as well eliminate the other potential weak point. Budget and performance are a difficult concept to juggle. I recommend saving up and perhaps dialing your tune back until you can afford to break stuff.
LSx Powered 86/ASE Master Certified Automotive Technician
AZFA20 is offline   Reply With Quote
Old 04-21-2014, 12:49 PM   #170
BRZPDX
Boosted Member
BRZPDX's Avatar
Drives: 2013 SWP BRZ Limited
How important is a AOS catch can? Has anyone ran their FI motor without it for some time? I know I need to pick it up soon, what issues will I be looking at without one? Just waiting on PXXXXN to release it soon (I get local discounts).
Suzuki Swift GTI '89, Subaru Impreza L '96, Lancer OZ '03, Subaru Impreza WRX '06, Honda CBR600RR Graffiti, Volvo c30 T5 R '11, Subaru BRZ '13, Audi RS4 2007
SUV's: Mercedes Benz R500 '06, Mercedes Benz ML350 '12
BRZPDX is offline   Reply With Quote
Old 04-21-2014, 01:07 PM   #171
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Its a little more than that. I'm on e85 and have no want to lower compression. If I lower it ill end up wanting to run a larger turbo or if I put in custom cp pistons that are near factory compression they get very expensive quickly. Much more so than the off the shelf 10:1 pistons cost. @nelsmar went with 11:1s but at quite a price iirc. So what I'm seeing is 10:1 pistons and run upgrade to a r30 or 35 (which is pricy) or keep my gtx28 run stock pistons on e85 and change out just the rods for some peace of mind at over 400
Old 04-21-2014, 01:12 PM   #172
nelsmar
IIRC I cracked one ring gland on a non failed cylinder. Though its hard to tell I would have to verify my pistons. There was wear on the side of the piston and some rings were seized in.
As for pistons custom spec CP pistons are actually quite affordable. Most of my cost went into my custom spec rods, and the fact I had upgraded wrist pins, and coatings applied to my pistons. The down side is the wait time is something like 6-12 weeks typically but I really can't remember! I would upgrade them personally if you have the time to wait. If you are having a problem getting the pistons you want I am sure you could call goodspeed (who has been a big part of my build) and they can order custom compression for you.
My flickr - Canibeat
Local magazine scout
Old 04-21-2014, 01:13 PM   #173
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Hard to say without pulling your intake manifold and looking at the intake ports to see how much coking and oil is in there. I would at least make sure you have a check valve in the PCV line so that you aren't pressurizing your crank case under boost.
Old 04-21-2014, 01:18 PM   #174
nelsmar
Personally I would run one moving forward. I did it for 12k miles without. There was sludge in the intake runners. Nothing out of the ordinary though. I actually expected a lot worse to be honest. I always had more of an issue on boosted hondas than I had on this. I would recommend looking into one to reduce buildup.
Old 04-21-2014, 01:20 PM   #175
Reaper
Reaper's Avatar
Drives: violent
@nelsmar thanks. Looks like I need to start thinking about 11:1
Old 07-24-2014, 11:05 AM   #176
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Sorry for the long time between updates. Three more motors added to the list:
@Cross
@C130NAV
@kingkai23
Anyone know of any others?
Old 07-24-2014, 10:31 PM   #177
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
When/How did cross blow his?
Luckrider is offline   Reply With Quote
Old 07-25-2014, 12:29 AM   #178
s2d4
s2d4's Avatar
@Cross
@C130NAV
@kingkai23
Everybody's favourite mate Lexus and that other guy with TR3 built motor.
Old 07-25-2014, 07:27 AM   #179
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
Anyone blown a stock boosted motor yet?
@lexusb3's motor let loose?
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here]
ecko04 is offline   Reply With Quote
Old 07-25-2014, 08:48 AM   #180
xwd
He has another thread and is doing a LS swap now, but I can't find it. It sounded like he had a cam failure of some sort, not a bottom end failure.
Old 07-25-2014, 08:57 AM   #181
kingkai23
Drives: 13 swp limited
My motor recently made windows in my block at 3300 miles..im just curious if the heads ok? I havent begun teardown yet..im hoping heads ok so i can just get a shortblock
kingkai23 is offline   Reply With Quote
Old 07-25-2014, 10:12 AM   #182
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Cross mentioned it in his I need a new motor thread in the Forced Induction forum. I don't think @lexusb3 's motor blew. I think he just sold it to someone. I don't know that the other guy with the TR3 built motor is on the forum and the list is only for forum members. I did hear about an Arizona motor that just blew, so I need to track him down.
How much HP can the stock motor handle? FullTuneZN6 Engine, Exhaust, Transmission 34 11-16-2017 01:22 AM
Full Blown 521hp Stock Motor @ 20psi FullBlown Forced Induction 276 08-31-2016 02:05 AM
FBM 604Hp 472Tq -- Stock Motor Stage 2 Turbo Kit FullBlown Forced Induction 414 07-14-2014 09:52 PM
FRS300 Rebuild Has Begun..Blown Motor to Built Monster FA20Club.com Forced Induction 917 10-20-2013 06:26 AM
Highest HP on stock motor using only 93/94 octane? hmong337 Forced Induction 11 09-09-2013 10:53 AM
