Old 04-19-2014, 07:54 PM   #15
Kolian
Kolian's Avatar
Drives: Raven Black scion frs
Originally Posted by FlamingRectumSyndrome View Post
How are you checking the alignment? I'm not familiar with any way of doing this that doesn't involve some fairly sophisticated machinery. That would be found in an alignment shop.
I take it to a shop and pay them to check it I don't do it alone.
Kolian is offline   Reply With Quote
Old 04-19-2014, 07:56 PM   #16
ftc~brz
Done
Drives: WRB BRZ
go somewhere else for an alignment, show them your paperwork from the 1st place show them your tread ware....no way that was done correctly
ftc~brz is offline   Reply With Quote
Old 04-19-2014, 07:56 PM   #17
Kolian
Kolian's Avatar
Originally Posted by ftc~brz View Post
when you post photos post wheel size info too (like the offsets) and do you have spacers on too? the more info you give us the better we can help.
I had/have stagger set up as well. There is a natural camber in rear anyway but my tire ware was always pretty even. I'm curious about whats going on there.
No spacers nothing just rims. And I can't figure out why it's wearing on the inside and not the outside.
Old 04-19-2014, 07:58 PM   #18
Kolian
Kolian's Avatar
Ok I'll try a different alignment shop I'll probably take it to the scion dealership and explain what is happening and see if they notice something different.
I will still be posting rim pictures and tread. Just to get more info.
The Following User Says Thank You to Kolian For This Useful Post:
ftc~brz (04-19-2014)
Old 04-19-2014, 08:00 PM   #19
Shriveled Old Member
FlamingRectumSyndrome's Avatar
Drives: 14 Hot Lava FR-S
Originally Posted by Kolian View Post
As I said before I rarely drift ever since I got new rims and tires I drifted about 5 times. And I couldn't have wasted that much tread in those five times no matte what I do.
I don't think the drifting is the problem.
Does your car look like this?
Admittedly exaggerated, but out-of-whack rear camber will do exactly what you're describing.
FlamingRectumSyndrome is offline   Reply With Quote
The Following 2 Users Say Thank You to FlamingRectumSyndrome For This Useful Post:
FRSBRZGT86FAN (04-19-2014), ftc~brz (04-19-2014)
Old 04-19-2014, 08:01 PM   #20
ftc~brz
Done
Drives: WRB BRZ
because it's not aligned properly. there is no way. sorry babe. now that you have springs you need to get that checked out again. I recommend getting some word of mouth references from people for a better place.
When I get my cars worked on I go to places that allow me to watch what they do and explain to me what they do and why. They should have given you a read out of your original alignment and what changes were made.
also don't trust the dealer.
Old 04-19-2014, 08:02 PM   #21
Kolian
Kolian's Avatar
So you have excess wear in the inside rear yet are lowing the car and increasing rear camber as a result while you still dont know the cause (though a few people have given some good info).
You say the alignment is fine, what are the specs? Are you getting a new alignment post spring install?
The shop I took it to get lowering springs said they will do alignment and they don't know why I'm having that problem. What are post alignment springs?
Old 04-19-2014, 08:04 PM   #22
Kolian
Kolian's Avatar
No it does not look like that my rear tires are straight with my fenders and looks fully straight all around the car no camber and nothing like the picture.
Old 04-19-2014, 08:06 PM   #23
ftc~brz
Done
Drives: WRB BRZ
he was asking if you were getting a new alignment after the spring install.
any time you make major adjustments to suspension you want to get an alignment.
Old 04-19-2014, 08:08 PM   #24
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Inside is camber wear. No doubt about it.
N1rve
The Following User Says Thank You to N1rve For This Useful Post:
Old 04-19-2014, 08:11 PM   #25
Kolian
Kolian's Avatar
They also let me watch and explained what they were doing. I know a couple other shops around my place and see what they tell me. After my springs are and I get my alignment paper I will be able to tell you what different about the car. And what they did to align my rear tires.
Old 04-19-2014, 08:12 PM   #26
Kolian
Kolian's Avatar
Thank you to everyone that is trying to help me figure out what is wrong with my car.
Old 04-19-2014, 08:12 PM   #27
Kolian
Kolian's Avatar
So what can I do to fix camber wear?
Old 04-19-2014, 08:19 PM   #28
N1rve
N1rve's Avatar
Get camber bolts LOL. I believe I've read somewhere on here that the lower the car gets, the more camber you'll get... it's just the nature of the car.
N1rve
questions, rims, tires, tread life
Odd rear tire wear...anyone else? BRZnut Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 03-09-2014 07:31 PM
Let's Discuss Tire Wear SkitterSkotter Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 01-14-2014 11:35 PM
staggered setup - how's the tire wear? cfordart Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 04-21-2013 12:27 PM
question about tire wear driver01 Tracking / Autocross / HPDE / Drifting 8 08-05-2012 09:50 PM
Outer tire wear at track? fasteddy Tracking / Autocross / HPDE / Drifting 20 07-24-2012 01:16 PM
