Old 04-19-2014, 08:24 AM   #1
Kolian
Kolian's Avatar
Drives: Raven Black scion frs
Cool I need some help with tire wear on my 2013 scion frs
This is from my iPhone so if I have any mistakes sorry in advance
I have a 2013 scion frs. My rear tires have been wearing out very fast. The car is fully stock except for an exhaust and aftermarket str rims staggered and concave I think that's what it's called the rear tires are a little bit stretched. I don't have any other mods no camber kits fully stock suspension. My new tires in the rear have 3k miles on them and the inside of the tire is almost gone. I had these tires for about 10 weeks and I don't understand why they are getting used up so quick I had alignment done when I bought the rims and tires 10 weeks ago and after 2k miles I rechecked my alignment and tire pressure. The alignment is all good and my tires are at 40psi. Only the inside of the tire is getting used the outside is perfect and the front is like brand new but the inside of the rear tires are really low. What else could be causing my tires to use up so quickly. I have drifted it like 5 times in really rainy conditions and I don't think I could have used so much tires in 5 different drift times..
I don't know we're to post this so any help will be grateful. This is my second car and I worked really hard to get it but I keep having these problems and I don't know what could be causing them.
Kolian is offline   Reply With Quote
The Following User Says Thank You to Kolian For This Useful Post:
ZionsWrath (04-19-2014)
Old 04-19-2014, 09:10 AM   #2
ZionsWrath
Thanks
ZionsWrath's Avatar
first of all, pics of tire? Off car if possible?
Wheel and tire specs?
Old 04-19-2014, 09:32 AM   #3
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Did you change the weight of the car in any way? That really sounds like an alignment issue
Sent from my SGH-T999L using Tapatalk
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
Old 04-19-2014, 09:57 AM   #4
retrosmiths
Drives: Scion FR-S Whiteout
Toe?
2013 Scion FR-S
retrosmiths is offline   Reply With Quote
The Following User Says Thank You to retrosmiths For This Useful Post:
Old 04-19-2014, 12:47 PM   #5
Kolian
Kolian's Avatar
Smile
I can't get the pictures today. The frs is getting new springs today. It's at the shop and tonight I'm picking it up. I will upload as soon as possible the tire specs and the rim picture. But it will probably be on the car. Thanks for the help! I really appreciate it.
Old 04-19-2014, 12:50 PM   #6
Kolian
Kolian's Avatar
I didn't change anything other than exhaust and rims. I do some beginner drifts that are just by overpowering. And it's really hard to do nice drifts with staggered rims. I checked my alignment and it always comes up good. And I don't know what could be causing it to wear that fast. So I went to the forum that for my car.
Old 04-19-2014, 01:02 PM   #7
ftc~brz
Done
Drives: WRB BRZ
when you post photos post wheel size info too (like the offsets) and do you have spacers on too? the more info you give us the better we can help.
I had/have stagger set up as well. There is a natural camber in rear anyway but my tire ware was always pretty even. I'm curious about whats going on there.
ftc~brz is offline   Reply With Quote
Old 04-19-2014, 03:03 PM   #8
FlamingRectumSyndrome
Shriveled Old Member
FlamingRectumSyndrome's Avatar
Drives: 14 Hot Lava FR-S
How are you checking the alignment? I'm not familiar with any way of doing this that doesn't involve some fairly sophisticated machinery. That would be found in an alignment shop.
FlamingRectumSyndrome is offline   Reply With Quote
The Following 2 Users Say Thank You to FlamingRectumSyndrome For This Useful Post:
FRSBRZGT86FAN (04-19-2014), ftc~brz (04-19-2014)
Old 04-19-2014, 03:16 PM   #9
humfrz
I'd suggest you have the alignment checked at a different alignment shop.
humfrz
Old 04-19-2014, 03:23 PM   #10
ntron1
Sarcastic Bastard
Drives: '13 DGM BRZ, '13 Mini, 1999 Blazer
40 psi is 15% too high and with stretched tires I would expect excess inner wear with just the stock camber. Ya wanna play ya gotta pay....
ntron1 is offline   Reply With Quote
The Following User Says Thank You to ntron1 For This Useful Post:
Old 04-19-2014, 03:33 PM   #11
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Your problem right there.
-alex
Old 04-19-2014, 03:44 PM   #12
FRSBRZGT86FAN
+1 ntron1 suggestion, the reccomended cold psi is 35 or so.....
Old 04-19-2014, 04:41 PM   #13
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
So you have excess wear in the inside rear yet are lowing the car and increasing rear camber as a result while you still dont know the cause (though a few people have given some good info).
You say the alignment is fine, what are the specs? Are you getting a new alignment post spring install?
Old 04-19-2014, 07:52 PM   #14
Kolian
Kolian's Avatar
-alex
As I said before I rarely drift ever since I got new rims and tires I drifted about 5 times. And I couldn't have wasted that much tread in those five times no matte what I do. And it was in really rainy conditions.
questions, rims, tires, tread life
Odd rear tire wear...anyone else? BRZnut Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 03-09-2014 07:31 PM
Let's Discuss Tire Wear SkitterSkotter Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 01-14-2014 11:35 PM
staggered setup - how's the tire wear? cfordart Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 04-21-2013 12:27 PM
question about tire wear driver01 Tracking / Autocross / HPDE / Drifting 8 08-05-2012 09:50 PM
Outer tire wear at track? fasteddy Tracking / Autocross / HPDE / Drifting 20 07-24-2012 01:16 PM
