Old 04-16-2014, 10:28 AM   #155
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by Fizz View Post
By the way, where can i get new caliper mounting bolts? Is it ok to just use similar size/length/pitch purchased from hardware store?
I would only go with OEM STI caliper bolts personally, but a quality Grade 8 bolt would be an okay replacement. Perhaps a search on NASIOC or some Subaru parts sites will net you the length, thread size, and thread pitch.
Old 04-16-2014, 10:28 AM   #156
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Originally Posted by Figo View Post
My STI caliper with red powder coat
Damn those look amazing. I would have loved that look much more than my black STI decaled calipers.
Figo (04-16-2014)
Old 04-16-2014, 10:31 AM   #157
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Thanks. Could you take a couple of shots showing the back of the caliper where the banjo connects. Which bleeders and stainless lines did you get?
By the way.....just wanted to make sure that 05 calipers are the same as 04 yes? Just the rotors are different....?
I used the BRZ stainless lines and you will find that the banjo on the back of the caliper won't line up with the tabs meant to hold it in place. I just found a good position for it to fit and tightened down the banjo bolt with no issues in over 20,000 miles. I used the OEM bleeders that came in my STI calipers. The 05 calipers are the exact same as the 04 calipers. The only difference in the rotors is the 04s are 5x100 and the 05s are 5x114.
The Following 2 Users Say Thank You to King Tut For This Useful Post:
chanomatik (04-16-2014), Fizz (04-16-2014)
Old 04-16-2014, 10:46 AM   #158
OrbitalEllipses
Drives: Attitude
Looking great @Figo, glad to see the setup done!
Always used Grade 8 or 10 belts from the hardware store/McMaster-Carr.
Figo (04-16-2014)
Old 04-16-2014, 11:09 AM   #159
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Thanks. I've actually found the part number for brand new OEM mounting bolts, and they're only a few bucks each so I'll get those instead of looking in hardware stores. I've also read its prudent to smear some copper anti seize on the mounting bolts....apparently they're prone to seizing.
@King Tut I have to say I was "inspired" to take up this mod after seeing pics of your brake swap months ago
Fizz is offline   Reply With Quote
Old 04-16-2014, 11:31 AM   #160
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I would definitely use some anti-seize on the bolts since it is a steel bolt going into some really soft aluminum. Also don't over torque them.
Old 04-16-2014, 11:36 AM   #161
Figo
Figo's Avatar
Drives: Vortech Supercharged FR-S
I appreciate for your advice.
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me.
Your car is your story, so don't let someone else write the book.
( White Tiger ) - FiGo's 車誌.
Figo is offline   Reply With Quote
Old 04-16-2014, 05:05 PM   #162
AyJay
AyJay's Avatar
Drives: 22 GR86, 13 FR-S, AP2 S2000
Originally Posted by jamal View Post
Exactly. Two opposed pistons move the same distance and require the same fluid displacement as one piston in a sliding caliper.
The front brembos only have very slightly more piston area than the stock brakes and with the larger rotor you are getting about 10% more brake torque given the same pressure. Here's the interesting part: Going to the rear brembos actually moves the bias even farther forward because the pistons in that caliper are smaller than stock and the rotor isn't that much bigger.
So your bias is actually better with only the front brembos compared to putting them on all four corners.
This bolded text claim was made earlier in the thread, and seemed to be co-signed by RaceComp Engineering.
If one were to run STI Brembo fronts and OEM rear would it be ideal to run the same compound pad on front and rear still?
For instance, if one were to run a CarboTech XP10 in front would it then be ideal to run an XP8 pad in the rear? Or would you want to run the same pad all on all 4 corners?
AyJay is offline   Reply With Quote
Old 04-16-2014, 06:44 PM   #163
bee_are_zee
bee_are_zee's Avatar
Drives: GBS BRZ
Ok so I need some clarification on brembos. Do 08+ fronts fit on the factory rotors or do they need new rotors as well?
bee_are_zee is offline   Reply With Quote
Old 04-16-2014, 08:12 PM   #164
azian_advanced
*****istrator
azian_advanced's Avatar
Drives: 2013 Scion FR-S 10-Series M/T
you'll need new rotors.
most people have been getting DBA 4000 T3 series rotors (dual-drilled version) with their swaps.
SC10N FR-S #435 of 2500
azian_advanced is offline   Reply With Quote
Old 04-16-2014, 08:14 PM   #165
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
You need front rotors from a 2004 STI (and only 2004, 2005+ have the wrong bolt pattern).
This is the simplest recipe for a Brembo Twin:
08+ STI Brembo calipers
2004 STI front rotors
2008+ STI rear rotors drilled for 5x100
Caliper sets can be found on IWSTI and NASIOC if you're fast.
Adam's Rotors can put together a custom set for a good price, and DBA makes dual-drilled rotors.
The Following 2 Users Say Thank You to Draco-REX For This Useful Post:
bee_are_zee (04-16-2014), chanomatik (04-16-2014)
Old 04-16-2014, 08:22 PM   #166
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
http://www.fastwrx.com/rebradkit2im.html
http://www.fastwrx.com/brakerotors.html
Old 04-16-2014, 09:13 PM   #167
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
You'll definitely need new rotors. Best to get new lines as well at the same time.
Old 04-16-2014, 09:16 PM   #168
bee_are_zee
Drives: GBS BRZ
I dunno why I thought in 08 the rotors dropped back down to the wrx size. Anyway I just got stoptech rotors like a month ago so it looks like I will be going with 4 pots...
will the sti brembos fit fr-s/brz? driver01 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 51 04-12-2014 02:25 PM
Those Brembos, fixed caliper? Or not? [Patent inside!] madfast Suspension | Chassis | Brakes -- Sponsored by 949 Racing 155 12-08-2011 02:06 PM
