Old 04-14-2012, 10:05 PM   #1
driver01
Drives: brz 13
will the sti brembos fit fr-s/brz?
i have the chance of getting my hands on the brembo calipers from the sti, anybody know if these will fit?
driver01 is offline   Reply With Quote
Old 04-14-2012, 10:13 PM   #2
Spaceywilly
ZC6A2B82KC7J
Spaceywilly's Avatar
Drives: 2002 WRX
Nobody has the car yet to try it, but the brakes on the STI are on the back of the wheel and the brakes on the BRZ are on the front of the wheel so it seems unlikely. Also I don't think there's any chance the stock wheels will clear them so you'd need to pick up some 18s or 17s that clear the Brembos.
Straights are for fast cars. Turns are for fast drivers.
Spaceywilly is offline   Reply With Quote
Old 04-14-2012, 10:20 PM   #3
Ranatsu
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
i have a spare set so I can give it a shot once the car actually gets here.
Ranatsu is offline   Reply With Quote
Old 04-14-2012, 11:45 PM   #4
old greg
Rocket Surgeon
Drives: PSM GGA OMG
Fit? Yes.
Work? Not really.
old greg is offline   Reply With Quote
Old 04-14-2012, 11:47 PM   #5
blu_
blu_'s Avatar
Drives: SWP BRZ LTD
Originally Posted by old greg View Post
Fit? Yes.
Work? Not really.
But wont they look cool?
blu_ is offline   Reply With Quote
Old 04-16-2012, 09:02 AM   #6
Godzpeed
Drives: Nissan GTR
any brakes can fit and work on any car with the right bridge
Godzpeed is offline   Reply With Quote
Old 04-16-2012, 10:05 AM   #7
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
Weren't the BRZ hubs from an 04 STi? Or was that disproven?
If they are, then you might have a decent chance at getting some 04 STi Brembos on there.
- The Ancient BRZ Sacrament
by Zaku
Old 04-16-2012, 10:59 AM   #8
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Here's the problem, as has been explained on here many times already.
STI calipers are differential-bored. So the leading pistons are larger than the trailing pistons. When mounting on an STI, which has them mounted rearward of the axle, the leading piston is on the lower end of the caliper, and the bleeder is at the top. When you mount that to a BRZ, which has it's calipers mounted forward of the axleline, you have two options:
1. Keep the left caliper on the left side, and the right on the right.
2. Switch L to R and R to L.
The problem with option one is that the bleeder is at the bottom of the caliper, so you'll never get a good bleed.
The problem with option two is that the leading piston is now the small piston and the trailing is the large piston, so the brakes won't work as well as they should.
For those reasons, a post of "Work? Not really." is accurate. Will they technically work? Sure, will they work correctly or as well as they should? Not at all.
In any case, will they be an improvement on the street in terms of performance, absolutely not.
Feel, modulation, yes, but if you are an ABS braker, it'll stop just the same as stock brakes in the same distance given equal pads.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 04-16-2012, 11:00 AM   #9
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
04 STI rotors would technically fit, I don't believe there was an indication that the hubs were 04 STi parts, unless those are the same as WRX. Not sure.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 04-16-2012, 11:50 AM   #10
Turbowned
Turbowned's Avatar
Import Tuner wrote an article saying they would swap over, and you could use a certain year STi front rotors with modified 08 rear rotors. Not sure what their source was.
I'm personally more interested in WRX 4pot/2pots. They'll clear 16" wheels, are aluminum and presumably cheaper than the Brembos to buy used. Anyone wanna speculate if those will fit?
Old 04-16-2012, 11:52 AM   #11
Godzpeed
Drives: Nissan GTR
they are still just the lotus calipers from Brembo, Nissan and Mitsubishi uses the same one in different locations
Old 04-16-2012, 12:22 PM   #12
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
How does that refute the obvious evidence that they won't work correctly in this application? The calipers should only be used with the bleeders up top and the larger piston at the leading edge. Every car with fixed differtial bored calipers are setup that way for good reasons.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 04-16-2012, 12:23 PM   #13
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
They should fit and work fine once you switch them L to R and R to L. They are not differential bored so you just have to swap sides with them to keep the bleeder on top.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 04-16-2012, 12:35 PM   #14
old greg
Rocket Surgeon
Drives: PSM GGA OMG
It's the other way around actually. There's normally more pressure/wear on the leading edge of the pad, so a larger trailing piston helps keep heat and wear evenly distributed across the pad face under hard braking.
Those Brembos, fixed caliper? Or not? [Patent inside!] madfast Suspension | Chassis | Brakes -- Sponsored by 949 Racing 155 12-08-2011 02:06 PM
