Old 04-15-2014, 03:39 PM   #1
Ryan Tuerck
Drives: 2jz powered FR-S
FR-S Flood Car|| Help get running.
Hey guys,
I recently picked up a Flood car from Alabama to build into a nice street car for some video projects. I am trying to get the car running again to rebuild the title and am having issues finding out what is actually tied together with the immobilizer system.
It seems like the front portion of the car had the worst of the flood so most of the computers need to be replaced. So, I have replaced all computers from another chassis except the Keyless remote/ TPM computer, which came from a different chassis.
My big question is. What exactly needs to be replaced that is synced together? I am getting such mixed information online and the dealers are of no help. I can't figure out wether I need to replace all the computers from the same chassis or if it is only the Ignition, Key, ECU, and Dash that are synced. If somebody could clarify it would be greatly appreciated.
Ryan Tuerck is offline   Reply With Quote
The Following User Says Thank You to Ryan Tuerck For This Useful Post:
ilpad (04-15-2014)
Old 04-15-2014, 03:44 PM   #2
ilpad
ilpad's Avatar
Drives: 2013 - Scion FR-S in White"red"out.
Hi Ryan,
Nice to see you on our forums!
Best of luck with this project. Wish I could be of more help, but you're question is above my pay-grade.
Hope you have another great season this year.
ilpad is offline   Reply With Quote
Old 04-15-2014, 05:56 PM   #3
Ozzman
Drives: old
just try using the original ecu's first. It's quite possible that once an ecu is flashed to a particular car it may never work in a different one.
Ozzman is offline   Reply With Quote
Old 04-15-2014, 06:03 PM   #4
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
Do you have any pics of this project car?
Old 04-15-2014, 06:06 PM   #5
stugray
Drives: 2013 GBS BRZ Limited
I hate to be a downer, but I personally witnessed a flooded BRZ:
That car was so full of mud that I considered it a complete loss and was hoping that it was never resold as a drivable car.
There was mud in places that made me positive that there was mud all through the car (the front hood weighed about 40 pounds).
I hope that the one you got was not this one. It will never be the same.
Old 04-15-2014, 06:44 PM   #6
HapaHaole
Drives: Grocery cart
You will need to get a scan tool with the capability of programming a module and for immobilizer, BAD part is that you will need a TECHSTREAM to do the latter part.
SOLD: 2014 BRZ Limited WRB 6 Speed.
HapaHaole is offline   Reply With Quote
The Following User Says Thank You to HapaHaole For This Useful Post:
andrew20195 (04-16-2014)
Old 04-15-2014, 10:34 PM   #7
Ryan Tuerck
Guys,
Thanks for the welcome. I will post pics when I start a build thread on here in the next month or so. Right now it's just stock with a beat up interior. Luckily the mud didn't get to this car looks like it was just soaked in water.
Can you elaborate on a TECHSTREAM? I am waiting to talk to a diagnostics guy tomorrow about the car.
Old 04-15-2014, 11:16 PM   #8
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
http://www.ft86club.com/forums/showthread.php?t=34502
The Following User Says Thank You to Kiske For This Useful Post:
Drift&Drag (04-16-2014)
Old 04-15-2014, 11:38 PM   #9
Drift&Drag
TURBOLICIOUS
Drift&Drag's Avatar
Drives: a machine :]
You hit the nail on the head HapaHaole!
Thanks for the welcome. I will post pics when I start a build thread on here in the next month or so. Right now it's just stock with a beat up interior. Luckily the mud didn't get to this car looks like it was just soaked in water. Can you elaborate on a TECHSTREAM? I am waiting to talk to a diagnostics guy tomorrow about the car.
Ryan welcome to FT86! I recently went through a similar issue with my BRZ which has the push button start, not the traditional cylinder lock on the steering column. My friend at a local Subaru dealership narrowed it down to this part:
Subaru part#: 88801CA041
SMT MAIN ECU ASSY - Keyless Access Control Unit
We also replaced the immobilizer and key to be on the safe side. All of which needed to be reprogrammed (the immobilizer/key and the keyless access control unit). Do you plan on keeping he FA20 or swapping engines? Be sure to check the fuses, battery, and of course the fluids (oil, brake, trans, etc,.) to make sure they are not contaminated with water/soiled. Keep us posted.
Originally Posted by Kiske View Post
Awesome post! I might need to configure some stuff for my build.
Drift&Drag is offline   Reply With Quote
Old 04-15-2014, 11:38 PM   #10
CircuitJerk
Pull my finger...
CircuitJerk's Avatar
Drives: Silver Scion Slushbox
Wiring harnesses would be a really good place to start. You are likely to be chasing problems both early on, and later if you don't ensure they have not been compromised.
CircuitJerk is offline   Reply With Quote
Old 04-16-2014, 12:01 AM   #11
steve99
Drives: FT86
Guys,
+1 on the tecchstream it will allow diagnosis and tests of busses between cpu,s.
Got techstream 7 off internet and used my tactrix adapter, but ones off ebay for $30 work fine and come with software search for techstream on ebay.
Unfortunatly as previous poster mentioned you going to have problems with wiring harnes as well i would pull every connector and clean with contact cleaner and crc or wd40.
Past experience with electronics that been wet while powered up would say your in for a lot of niggly intermittent problems due corrosion electrolysis damage ect. That generally why they write them off.
good luck
Old 04-16-2014, 11:32 AM   #12
Ryan Tuerck
Copy that. Thank you for the info guys. I have a spare engine bay harness I will be installing over weekend. Seems like it ties into quite a bit of what's under the dash as well. I also have a diagnostics guy coming next Tuesday who seems to be very knowledgeable. Fingers crossed it all works the first time. I really only need to get this car running to get the title rebuilt. Then it is time to tear it down and rebuild her into something sweet.
Old 04-28-2014, 01:59 PM   #13
Ryan Tuerck
Does anybody know where exactly the Keyless Remote ECU is located on the car?
Old 04-28-2014, 02:20 PM   #14
sshole
Probably on top of the rear deck. I think that's where most cars have it?
Edit: here's a thread where someone helpfully circles and points the keyless module out: http://www.ft86club.com/forums/showp...15&postcount=5
sshole is offline   Reply With Quote
Flash Flood Water Damage - Please Help Mollusk Scion FR-S / Toyota 86 GT86 General Forum 27 09-16-2013 04:28 PM
Toronto Flood July 8th 2013 nos145 Issues | Warranty | Recalls / TSB 2 07-10-2013 11:47 AM
Running 19's SocalBurt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 09-04-2012 02:45 PM
Fuji 86 Style 2012 JDM @ Fuji Speedway (Photo Flood) shawrf1 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 59 08-19-2012 11:13 PM
