Old 08-16-2013, 11:11 PM   #1
Mollusk
Drives: Honda Civic
Flash Flood Water Damage - Please Help
A few hours ago we had a torrential downpour come through my area and the parking lot outside my building was flooded with about a foot and a half of water. I realized the danger and ran outside just as the water was reaching the lower "lip" of the front bumper, just centimeters away from the air inlet. I jumped inside and started the car, thinking my only chance was to get it out while the water was still just below the critical point (it was still raining heavily at this point). As I backed out of my parking space, I realized it was already too late, my parking space was actually the shallowest point.
Luckily some of my neighbors showed up and helped me push the car (with the engine off) out of the flooded area and over to a small hill. But before we could get it out the flood water had risen to reach the air inlet, and the footwells inside the car were filling with water. It got about as high as the seats before we reached dry land and luckily not high enough to reach the shift knob or any of the dashboard.
As of right now I have bailed out all of the standing water inside the car, and I have not tried to start the engine again. The electronics still seem to work - door locks, power steering, dome light at least. But I'm sure there is still water in between the interior fabric and the metal shell.
Has anyone ever had their car flooded before? What should I do? I know I need to remove all the footwell carpeting and padding (not just the floor mats, those are already out) ASAP and allow them to dry, but I don't know how to get them out. I need to remove the seats too, including the rear ones. And is it safe to try starting the engine again, or do I need to get it towed to a shop?
If anybody knows how to take these interior pieces apart, or any general advice, I would be extremely grateful.
Mollusk is offline   Reply With Quote
Old 08-16-2013, 11:13 PM   #2
thill
Call your insurance company...
Old 08-16-2013, 11:19 PM   #3
Mollusk
Drives: Honda Civic
I'm going to, but in the meantime the longer it sits there the more chance there is for mold & corrosion.
Old 08-16-2013, 11:31 PM   #4
czar07
czar07's Avatar
Drives: '97 RSP JZZ30 GT-T
Pull all the carpets out and dry them.
Germans>Japanese>Italians>Americans. Unless its a Corvette.
czar07 is offline   Reply With Quote
Old 08-16-2013, 11:44 PM   #5
TNPerformance
Drives: 2013 Hot Lava FRS/97 Supra/93 Supra
Usually to get the carpet out you just take the seats out and pop the bottom part of the rear seat up. Also the carpet is usually secured underneath the center console (not always). Other than popping off the door scuff plates that's really it. It should slide out from underneath the other plastics. However, it if is not wanting to slide out from underneath the center console, chances are it is hooked under there and you'll have to take out the console to get it out.
I would definitely slide up under the car and pop off the rubber body plugs if there are any (I just got my car 2 days ago, so I am not sure how many or where they are). But they are just rubber plug, you can remove them by hand and that should allow some extra water sitting underneath the carpet to drain out. But the carpet will definitely have to be removed to get it all.
Don't fret my friend, I think you'll be fine.
And about the engine. You should be fine there as well. The engine won't suck up water without running, and if it didn't stall while you had it running then it didn't even come close to hydro locking. However, if you are still worried, just pull out your airfilter and see if it is wet. If not, then I wouldn't worry at all.
TNPerformance is offline   Reply With Quote
The Following User Says Thank You to TNPerformance For This Useful Post:
Mollusk (08-17-2013)
Old 08-16-2013, 11:49 PM   #6
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Smile
Time to pull all the carpets and switch em out, but first your best bet is to call the insurance company in case they can help monetary wise, but you really do not want mold and corrosion screwing up your interior. Also the intake and engine should be fine, as long as the motor didn't run in the high water, because then there was no suction to suck water up in the first place.
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
Old 08-17-2013, 12:16 AM   #7
Accurate Race Shop
Accurate Race Shop's Avatar
Drives: Scion FR-S
You might be able to get most of it with a powerfull wet/dry vac. Your still going to have to take the seats out to get all of it. It's not a fast process but it you should be able to get enough of it to let the rest dry out with leaving the windows down. as for starting the car take off the air intake and make sure there is no water sitting in the resonators. This is just one of many options. Your best bet is to take it to a detail shop and have them remove the carpet to wash and dry it.
Sent from my Q10
The Following User Says Thank You to Accurate Race Shop For This Useful Post:
Old 08-17-2013, 03:19 AM   #8
topazsparrow
Drives: slow
Get a big fan in there to keep the air moving. Air that sucker out!
topazsparrow is offline   Reply With Quote
The Following User Says Thank You to topazsparrow For This Useful Post:
humfrz (08-17-2013)
Old 08-17-2013, 05:15 AM   #9
fistpoint
Drives: Supercharged Golf Cart
I had the exact same scenario with my '00 Si. My car however was driven through, but never stalled, and also never quite the same. But you didn't drive so on to the real comparison:
I waited about 18 days before calling it in because I too bailed all the water out and dried everything, and all electronics worked...it was my performance/mpg loss that made me take it in.
Initially they said the car doesn't appear to be flooded because I did such a good job, then they pulled the floormats. Rust everywhere, computer was suggested to be replaced as it was still moist.
So, at the very least you need to remove the carpeting immediately if you want to do a thorough job. You could avoid insurance, but you might as well call them. Do it yourself like I suggested is for no insurance people. Surely you have a $500 or less deductible? If not, you should. The price difference isn't that much and it would have paid for itself right now.
fistpoint is offline   Reply With Quote
Old 08-17-2013, 07:22 AM   #10
Clembo
'Senior' Junior Member
Clembo's Avatar
Drives: 13 FR-S,08 Mustang Bullitt,06 MX-5
Calling in the insurance company will possibly put it on the CarFax. Just something to think about when it's time to trade or re-sell. It will likely diminish the value.
Tough decision as you may not have electrical problems now but if some wiring, connectors, sensors or relays were flooded you may have corrosion issues later on. The ones that expect to see water in normal driving situations will be sealed from damage but the rest might not be. I'd be real thorough in assessing the water level vs. all the car's electrical components and wiring then come up with a determination of the direction to take.
IMO, the carpets are the least of the problems. They can easily be replaced.
"You'll never know if you don't try" - Shinroko Momose
Clembo is offline   Reply With Quote
Old 08-17-2013, 07:40 AM   #11
Mollusk
Drives: Honda Civic
Thanks guys. I've tried pulling the seats and carpets out but wasn't able to finish due to the passenger seat bolts being stuck. I also got enough of the trim pieces off to access the edge of the carpet, but the carpet appears to be stapled to a plastic piece that I can't remove. I don't have the tools to proceed at this point, I need a professional. Hopefully I can find one open on a Saturday.
Old 08-19-2013, 08:13 AM   #12
Rossman
Rossman's Avatar
Drives: '22 BRZ, '17 BRZ (prev '13 FR-S)
I see people say this all the time and it kind of irritates me. This shit should be in CarFax, and it probably should diminish the value. I wouldn't want to buy a car that was flooded out like this even if it wasn't that serious.
It sucks you car got flooded by shit happens in life and scamming the next person down the line is unacceptable and unjustifiable.
Rossman is offline   Reply With Quote
The Following 10 Users Say Thank You to Rossman For This Useful Post:
Ammonia (08-21-2013), Books (08-19-2013), CAMBAM_6 (09-16-2013), denkigrve (09-16-2013), FRiSson (08-19-2013), gily25 (08-19-2013), HunterGreene (09-16-2013), Kimsey47 (08-19-2013), kludger (08-19-2013), suaveflooder (08-20-2013)
Old 08-19-2013, 09:39 AM   #13
FRiSson
Drives: FR-S MT
You can try to mitigate any issues yourself, but then you probably won't be able to collect insurance if it doesn't work out. This is what insurance is for.
FRiSson is offline   Reply With Quote
Old 08-19-2013, 09:47 AM   #14
f0rge
head of infinite swagger
Drives: 2013 FR-S 6MT
Go buy a dehumidifier and an extension cord and put it in your car with the doors and windows closed, in a day or 2 it should be pretty well dry.
Don't forget to empty the dehumidifier often.
2019 Golf R 6MT - current daily...I need another coupe
2008 Civic Si - winter beater
2000 Silverstone M5 6MT - SOLD
2013 Ultramarine FR-S 6MT - Car Journal - SOLD
2004 AlpineWhite M3 6MT - SOLD
f0rge is offline   Reply With Quote
Hail Damage execoll BRZ First-Gen (2012+) — General Topics 61 07-21-2014 06:22 PM
Toronto Flood July 8th 2013 nos145 Issues | Warranty | Recalls / TSB 2 07-10-2013 11:47 AM
Damage report that_one_guy Scion FR-S / Toyota 86 GT86 General Forum 14 01-02-2013 03:34 PM
Fuji 86 Style 2012 JDM @ Fuji Speedway (Photo Flood) shawrf1 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 59 08-19-2012 11:13 PM
