Old 04-10-2014, 06:04 PM   #29
ptuning
ptuning's Avatar
Drives: White FR-S
You will not crack the SS Tial turbine housing driving through water LOL. If you run through water deep enough to damage the turbo, I'm certain you'll also crack your engine block in the process, so the turbo will be the least of your worries.
- Toan
ptuning is offline   Reply With Quote
The Following User Says Thank You to ptuning For This Useful Post:
rb6freak (04-10-2014)
Old 04-10-2014, 06:24 PM   #30
Jason@DSG
Jason@DSG's Avatar
Drives: 1997 Eagle Talon TSi AWD
- Toan
Curious as to why you put the turbo that low though? Water won't be an issue but since this car doesn't really have a great unserpanel, have you considered all the crap flying up from the road?
Jason@DSG is offline   Reply With Quote
Old 04-10-2014, 06:59 PM   #31
Mrc@ptuning
Mrc@ptuning's Avatar
Drives: S1000RR
The turbo sits higher than you think. it's just the camera angle:
Mrc@ptuning is offline   Reply With Quote
The Following User Says Thank You to Mrc@ptuning For This Useful Post:
bjun (04-10-2014)
Old 04-10-2014, 08:38 PM   #32
Jason@DSG
Jason@DSG's Avatar
Right on! Much better in those camera angles.
Old 04-10-2014, 08:56 PM   #33
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
i submerged a ct26 more than once and it didnt blow up. In fact i think its still running somewhere.
Old 04-10-2014, 09:05 PM   #34
AllDayJonRay
Drives: 2013 Ultramarine FR-S
How on earth did you manage to fully submerge a ct26?? mr2? That would mean half the entire car was submerged. Even if it was a Celica, thats crazy water depth... You sir sound like a maniac!
'13 Ultramarine 6MT FR-S || K&N Drop-In, SpeedFactory V1 Cat-Back || Moto-East tuned
Join the 86 Owners Clan on Clash of Clans: "86 Owners" Password: "fa20" || Help us take over the world || Thread
AllDayJonRay is offline   Reply With Quote
Old 04-10-2014, 09:18 PM   #35
Reaper
Reaper's Avatar
Drives: violent
it was attached to a 22re in a 91 toyota pickup lc engineering built 2.7 stroker.
Old 04-10-2014, 09:32 PM   #36
Zach3794
Drives: 2013 Scion FR-S, Raven, Manual
Originally Posted by FreshFRS View Post
I think with e85 (can't remember if he said pump gas only or not) he could hit 350whp with a supercharger.
@Zach3794 here is at 330whp with E60 on the base (9psi) C30-94 kit, and can chime in here. my guess is that the high boost C30 would be able to push over 350whp without major problems (on E85). the C38 could do this as well IMO.
It will be easier to do with a turbo, and you will have headroom (depending on turbo size) though.
Yeah I'm at 332whp on E85 at about 9psi on the C30 rotrex blower. I have yet to install the smaller pulley, but since that e85 tune isn't even finished yet I think we'll easily get to 370whp on the C30 at 13 psi on E85, perhaps even with the stock header still.
Tuned by Delicious Tuning
http://www.delicioustuning.com/node/209
Kraftwerks Supercharged
Zach3794 is offline   Reply With Quote
Old 04-10-2014, 10:16 PM   #37
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
Man i wish BC had E85. since the OP is in florida, E85 should be pretty easy to come by. you're still on the factory header? thats pretty crazy thanks for the info.
FreshFRS is offline   Reply With Quote
Old 04-10-2014, 10:17 PM   #38
Zach3794
Yeah, we stopped trying to make more power there because the clutch was slipping. After we replace the clutch I'm expecting about 20whp more without changing anything else, then an additional 20-30 from smaller 13 psi pulley.
Old 04-10-2014, 10:20 PM   #39
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
Is that the stock clutch that is slipping? and that seems to be pretty on point. what do you expect to push with the bigger C38-81? low boost 370ish? high boost 400+?
Old 04-10-2014, 10:48 PM   #40
Basket Case
Drives: 2013 Raven fr-s
i have NEVER seen e85 anywhere here...I don't really see e85 as a viable option for anyone who dd's their car...I am everywhere on a daily basis and the thought of having to rely on trying to find a station somewhere that had e85 scares me...How could you take a road trip or go anywhere further then the stations you know 100% carry it.
Basket Case is offline   Reply With Quote
Old 04-10-2014, 11:04 PM   #41
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
Really? well if we had it up here i'd probably map out my route to take advantage of it. so pump gas it is.
the turbo is going to get you more power overall. but superchargers have their niche, i like the way they put power down linearly.
i had a 400+whp turbo s2k and really didn't like the way the power came on, just comes down to preference i suppose.
either way you go you win in reality, as long as the tune is safe, it's going to put a huge ass smile on your face for a long time and thats what really matters haha
Old 04-11-2014, 08:35 AM   #42
Jason@DSG
Jason@DSG's Avatar
As I said, "it's not likely". It's do-able but way more work than it's worth hitting 350whp with a supercharger on a small displacement engine like this. Turbos are ideal for small displacement power and it'll be a lot easier to hit your goal. 350whp is bearing a zone that I highly suggest you look into at least pistons and rods for long-term reliability.
The Following User Says Thank You to Jason@DSG For This Useful Post:
FreshFRS (04-11-2014)
4 point harness BuhhDill Cosmetic Modification (Interior/Exterior/Lighting) 10 03-07-2014 12:12 PM
Nav System Direction Up? ScottDRFT Electronics | Audio | NAV | Infotainment 3 01-14-2013 01:25 PM
What is the point of this car? dem00n Scion FR-S / Toyota 86 GT86 General Forum 88 10-09-2012 03:31 AM
exhaust direction please 75 carrera Engine, Exhaust, Transmission 6 07-04-2012 09:28 PM
BRZ at Point Mugu, CA ashtray BRZ Photos, Videos, Wallpapers, Gallery Forum 5 07-01-2012 06:52 PM
