#29 |
Drives: UK GT86
Closed loop MAF scaling:
http://forums.nasioc.com/forums/show....php?t=1427448 Open Loop MAF Scaling: http://www.ft86club.com/forums/showp...&postcount=995 As far as adding timing, I would advise only adding timing over 2500 and 1 load. Then you're not likely to add tip in knock. The rest of the table has no influence over WOT so IMO there's no need. Unless of course you think partial throttle is lacking....
.: Stealth 86 :.
| The Following User Says Thank You to Kodename47 For This Useful Post: | phrosty (04-12-2014) |
#30 |
Erected Member
Drives: frs
Everyone that is currently a "pro tuner" at one time or another was at the same stage the op is currently in. If the guy wants to explore,great. Just do in a safe manner. And what better way to explore? enlist the help and knowledge of a forum!
Last edited by shif7i7down; 04-07-2014 at 04:21 PM. Reason: edit for non fighting words LOL |
#31 | |
Drives: FR-S 10 #103 AT
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
#32 | |
Drives: blk;2dr;rwd;fun
Thanks for pointing that out.. didn't mean to confuse anyone.
Life is like taking a dump, sometimes it's easy and other times its hard. But it always stinks
#33 | |
Drives: FT86
To do true live tuning you would need a different ECU or emulator where some or all of the map tables are stored in RAM so they can be changed on the fly . I believe hydra http://www.hydraems.com/ can do this to some extent but it costs $$$$$ not really worth it for average person. Probably Motec and other as well. Saw somewhere here where some Ecutek guys has a pseudo live tuning setup where they hijacked a couple on inputs to the ecu to switch/offset some custom maps on the fly for a sort of live tuning effect. |
#34 |
With ecutek you have 4 map modes, so you only have to flash once every 4 runs if you use them right. Combined with a ~1 minute flash time, it makes it far less of a pita.
#35 |
hey @jamesm and @Kodename47 , i've updated the first post to reflect what you guys been saying and alot of stuff from the links that were provided. can you guys check it out and advise on revisions?
I would be great if we can get a thread with accumulated information to help people that are new to tuning and want to learn. thankx
#36 | |
#37 | |
Drives: UK GT86
Very few people will give away their ideal fuel and ignition maps it seems at the moment and would you risk running someone else's maps anyway? The way I see it, Google is your friend and have a deep look around what's around already with Subaru ECU information. If you have any questions then ask.... That's exactly how I learnt. Read info, compare maps which will inevitably lead to more questions which you then research. I found it quite satisfying.
.: Stealth 86 :.
| The Following User Says Thank You to Kodename47 For This Useful Post: | Turdinator (04-09-2014) |
#38 | |
Drives: FT86
#39 | |
Drives: UK GT86
To make OL scaling easier, you could set the map to a flat AFR of loads 1 and above - eg all cells 12.5/12.6 etc. This makes it easy to analyse and won't be an issue for a couple of runs that are needed for scaling. Due to the sensor accuracy, you want it as lean as possible BUT remember if your MAF scaling is already off then you could run leaner than the commanded AFR. How I've been looking at it just for MAF scaling on an NA car: - 1st runs with a map of 12.0/12.1 - If you've already got logs, you have an idea whether your scale makes you run lean/rich. Do a few pulls to get good data - I like 3 or 4 pulls from 2.5/3k to reline. - 2nd runs around 12.5 - 3rd runs - fine tune with as lean as you're happy to go, but reduce timing a little to prevent knock. With the DI capability I personally would go as high as 12.75 but only for a couple of pulls. That should be enough. If in doubt, always make the MAF scale a touch higher. I'd rather run 0.05 richer than leaner. If you can visualise the data in graphs etc, you can see if the stock sensor starts to read inconsistently and then discard that data. Once you can do this, I would seriously look into latency and PI/DI scaling as it's just an evolution of this technique. Also worth noting on CL MAF scaling, as per @jamesm's screencast, don't go mental and randomly adjust each point. You want to adjust everything together.
.: Stealth 86 :.
#40 | |
Drives: FT86
After logging for an hour or so whacked data into CL Maf scale spread sheet see below. Look like CL area is pretty good only a couple of minir tweeks required. Looking at the WOT runs I did for OL scaling similar to stuuf I sent you a while back it was off a fair bit Measured AFR 11.3-11.5, commanded AFR 12.3-12.5 (STFT=0, LTFT =+2%). Weird all the error in top end? Unless I am doing something wrong ? |
#41 |
Drives: UK GT86
I wouldn't change it point by point, make sure you change it as a curve. If the lowest end of the MAFv scale get's increasingly distant from 0% error at as you near 1v then you need to look at latency. Random errors on the chart could be due to where the PI/DI systems change. What I would add to the chart above is % change. I have a table setup that compares my new table to OEM scaling. You can have the percentage of change increase/decrease as you go up the scale, but ideally you want that to be a smooth transition. Looking at the table above, there's nothing I'd change below 2v and notice how you have + error around 2.5v and then - error after.
For example, on one I've done recently the % change from the stock scale at 2.5v is 1% but I'm seeing 6% at the top end. I look at the data and work out at which points I should start to smooth the transition to keep the scale a nice curve. Remember there will be no STFT in OL.
.: Stealth 86 :.
| The Following User Says Thank You to Kodename47 For This Useful Post: | steve99 (04-09-2014) |
#42 | |
I.e reducing from 1.16v to 1.7v down .03 would have more of an impact on the lower voltage then on the lager one wouldn't it? So by tackling each given voltage column and adjust each one to the ltft readout should yield greater accuracy shouldn't it? Please advise. Thanks
| Best Break-in Procedure | xantonin | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 198 | 02-11-2015 04:40 PM |
| Visual Basic and SQL | Trashed675 | Off-Topic Lounge [WARNING: NO POLITICS] | 10 | 06-10-2013 12:18 PM |
| dyno numbers based on break in procedure. | EZWood | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 25 | 06-09-2013 08:32 PM |
| Fr-s Break in procedure. | Ontariofrs | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 18 | 03-14-2013 07:14 PM |
| Winter storage procedure | wbradley | DIY (Do-It-Yourself) Guides | 20 | 10-31-2012 12:49 AM |
