Old 06-04-2013, 12:10 PM   #1
Trashed675
Trashed675's Avatar
Drives: 2013 Ultramarine FRS
Visual Basic and SQL
Does anybody know how to pass a variable from a VB form (datetimepicker) into an SQL query?
Heres what i've got and it doesn't quite work:
SELECT FirstName, LastName, Phone, DateJoined
FROM Members
WHERE (DateJoined < date1)
Bascially i just want to get all the records before the date that user selects from the date time picker that is stored in date1.
Trashed675 is offline   Reply With Quote
Old 06-04-2013, 12:41 PM   #2
2forme
FROM Members
There are a few ways. The "easiest" is to assemble the SQL in a string and execute it with an ADODB command object.
Dim strSQL as string = "SELECT blah FROM blah WHERE blah = " & variable
Alternatively, you could use a stored procedure with a parameter, but will still need an object to interface with it. In most of my applications, I use some form of abstraction to handle all my database functions/needs. Of course choosing your solution should be based on the requirements of the project, scalability, etc. So it's solely your discretion.
Also SQL is a pretty arbitrary description of what database you're trying to run against. Some of the less popular databases (I'm looking at you, Sybase), need the date formatted in a certain way before it will be able to analyze it in a WHERE clause. The VB version also makes a difference.
Old 06-04-2013, 01:32 PM   #3
Spartan65
USMC Veteran Semper Fi
Spartan65's Avatar
Drives: 2010 WR Blue STi
have you tried
WHERE (getdate() > date1)
Spartan65 is offline   Reply With Quote
Old 06-04-2013, 01:35 PM   #4
Trashed675
Trashed675's Avatar
Forgive me, but a little hand holding would be greatly appreciated. This is my first term working with SQL(we are only skimming the surface in this course) and i've never used ADODB anything.
Google hasn't given me anything that that really makes sense to me as far as setting up the ADODB object.
I'm using VS 2012.
Code from the form that i'm working on.
Public Class MembersDates
Dim retVal As New Date
Private Sub gtnGo_Click(sender As Object, e As EventArgs) Handles gtnGo.Click
' Me.MembersTableAdapter.Fill(Me.FindMemberDataSet.M embers, txtLastName.Text)
dtpDate.Value = Now()
'Takes the value of whatever is in the datetimepicker
Dim date1 As Date = dtpDate.Value
'2forme's suggestion, not sure how to implement further
Dim strSQL As String = "SELECT FirstName, LastName, Phone, DateJoined FROM Members WHERE " & date1 & " > DateJoined"
'just to see what the output looks like as a string, in a textbox on the form.
txtDate.Text = dtpDate.Value.ToString()
Me.MembersTableAdapter.Fill(Me.DateJoinedDataSet.M embers)
End Sub
Public Function getDate()
'Earlier attempt, obviously didn't work, no longer calling
retVal = txtDate.Text
Return retVal
End Function
End Class
Old 06-04-2013, 01:37 PM   #5
Trashed675
Trashed675's Avatar
Originally Posted by Spartan65 View Post
have you tried
Yup, it doesn't seem to understand the date1 variable. If i plug in a static number in the sql, it works fine, but not with a variable.
Old 06-04-2013, 01:50 PM   #6
2forme
Oh, you're using a tableadapter.
http://www.dreamincode.net/forums/to...adapter-query/
Old 06-04-2013, 06:17 PM   #7
FrX
Drives: 2013 Scion FR-S, 1993 Lexus SC300
As someone in the security industry. Please, please, please do not do this. While it will likely not matter for a local application, it is a bad habit to get into. Please use parameters and prepared statements.
Sorry...after investigating about the 100th SQL injection caused by this exact method, you tend to get a bit touchy.
FrX is offline   Reply With Quote
Old 06-04-2013, 07:03 PM   #8
2forme
It's for his course LOL. I never use this, as you would see if you quoted the rest of my post.
Old 06-04-2013, 07:59 PM   #9
Trashed675
Trashed675's Avatar
Don't worry. After searching the grungy corners of the internet for the past few days, i've realized this isn't something that people do often. Its just part of an extra credit assignment that i'd like to get done.
Old 06-10-2013, 11:11 AM   #10
Want.FR-S
Want.FR-S's Avatar
Drives: 4 Wheels Auto
@FrX
What is wrong if one forms a SQL statement in a string and submit that to the database to query and retrieve information? I thought that is the way to interface with a SQL database.
Just by looking at your code, I noticed something in terms of data types. You pass the object *as is* to the string without converting or getting the correct data type of information. For example, *date1* is an object of Date. I am not sure if the default value of a Date object is a string type, but when you concatenate it into a string, you need to ensure it is the string that is interpreted when you form it. You can check it by printing the string to see if VB can get the date as a string for SQL statement.
Hope this helps.
Originally Posted by Winding Road FR-S review
What is astonishing about the FR-S is that it combines the cruising comportment and function of the 128i with the dynamics of the Cayman, or Boxster, or S2000.
Want.FR-S is offline   Reply With Quote
Old 06-10-2013, 12:18 PM   #11
Trashed675
Trashed675's Avatar
Originally Posted by Want.FR-S View Post
@FrX
Hope this helps.
I'm sure that has something to do with it. I have tried converting it to a string, a date(short and long), even and Int, all with no luck. It does make me feel a little better that i asked my (OCD) teacher for help on the problem on Wednesday and she has yet to get back to me with a solution.
Visual Garage Shark fin antenna EvoXDD Cosmetic Modification (Interior/Exterior/Lighting) 86 08-02-2015 02:20 PM
GC basic coilovers / Cusco Strut bar Evilbrz151 Brakes, Suspension, Chassis 3 03-29-2013 09:35 PM
Question about basic performance mods bdanisi Engine, Exhaust, Transmission 2 01-25-2013 05:40 PM
visual garage shark fin group buy. Mr.Jay Exterior Parts - The Rest 39 07-02-2012 10:09 PM
