Old 04-08-2014, 01:01 PM   #43
OrbitalEllipses
Drives: Attitude
Originally Posted by protpibe View Post
You need a boost gauge and I would recommend an aem failsafe so you have boost and afr in one spot , and will be able to see 2 critical bits of data to prevent blowing up your engine
FTFY.
ZionsWrath (04-08-2014)
Old 04-08-2014, 01:12 PM   #44
ZionsWrath
Thanks
ZionsWrath's Avatar
After replacing my drive belt on honda accord today I have to say I love how easy it looks on this boxer vs the i4. But then again I will probably have a slew of curse words when I try to change spark plugs on this BRZ....
Old 04-08-2014, 01:27 PM   #45
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
So the AVO kit can be purchased without even a BPV?
The BPV or any BOV is additional to the kit.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Old 04-08-2014, 02:45 PM   #46
Astroboy
Astroboy's Avatar
Drives: None
Boost AND AFR gauge are a must IMHHO.
You can't just plumb those lines, you will make a mess of boost/vacuum. (Protpibe is correct, I personally would just not use the kit without a BOV or recirculating valve).
Either purchase AVO's BOV or the generic recirculating valve (Both are on the AVO page for sale).
The PSI is dictated by the WG spring. What kit did you get, stage 1 or 2?
Stage 1
Sent from my LG-D800 using Tapatalk
Astroboy is offline   Reply With Quote
The Following 2 Users Say Thank You to Astroboy For This Useful Post:
Sportsguy83 (04-08-2014), ZionsWrath (04-08-2014)
Old 04-08-2014, 02:47 PM   #47
Astroboy
Astroboy's Avatar
Drives: None
They either forgot the bypass valve or it doesn't come with it. I never got one, was it suppose t come with one?
The Following User Says Thank You to Astroboy For This Useful Post:
Old 04-08-2014, 02:51 PM   #48
Sportsguy83
Drives: Limited BRZ
Originally Posted by Astroboy View Post
Stage 1
Your boost gauge will show you being at ~6 psi.
You can also check it with an ELM327 OBD2 bluetooth adapter and an Adroid phoen with the app Torque
It is not included with the kit, you buy it separately.
http://www.avoturboworld.com/avoshop...-c-95_103.html
The Following 2 Users Say Thank You to Sportsguy83 For This Useful Post:
Astroboy (04-08-2014), ZionsWrath (04-08-2014)
Old 04-08-2014, 03:00 PM   #49
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
In hindsight, I'm not sure how you're supposed to install the kit without one of the two BOV options. They don't include caps for the pipes. I guess you're supposed to improvise?
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
The Following 2 Users Say Thank You to protpibe For This Useful Post:
Old 04-08-2014, 03:01 PM   #50
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Certainly blue sticky tack
not that cheap white stuff.
The Following 2 Users Say Thank You to SkAsphalt For This Useful Post:
Old 04-08-2014, 03:17 PM   #51
protpibe
protpibe's Avatar
Maybe an oily shop rag and some zipties
Old 04-08-2014, 03:41 PM   #52
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Can you cover the holes with extra exhaust manifold gaskets?
@Sportsguy83
The Following 4 Users Say Thank You to King Tut For This Useful Post:
Astroboy (04-08-2014), SmsAlSuwaidi (04-08-2014), Sportsguy83 (04-08-2014), ZionsWrath (04-08-2014)
Old 04-08-2014, 03:43 PM   #53
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Oh snap ^
Old 04-08-2014, 03:43 PM   #54
protpibe
protpibe's Avatar
@Sportsguy83
If you've gone through enough of them, yes, you can stack and fold them over the holes.
The Following User Says Thank You to protpibe For This Useful Post:
Old 04-08-2014, 04:28 PM   #55
Sportsguy83
Drives: Limited BRZ
@Sportsguy83
Old 04-08-2014, 04:35 PM   #56
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
@Sportsguy83
The Following User Says Thank You to SmsAlSuwaidi For This Useful Post:
Installing a Turbo Kit + other mods chiefshayan Forced Induction 21 01-22-2014 10:58 PM
Installing a hood for the fr-s? Frs32907 Cosmetic Modification (Interior/Exterior/Lighting) 11 08-16-2013 11:06 AM
installing harness andrew5826 Cosmetic Modification (Interior/Exterior/Lighting) 16 07-25-2013 10:41 PM
need help installing this chenshuo Cosmetic Modification (Interior/Exterior/Lighting) 6 07-14-2013 01:17 PM
tips for installing amp and sub brichard0625 Electronics | Audio | NAV | Infotainment 4 05-19-2013 07:25 AM
