#29 | |
When I grow up, I wanna be God. My flickr - Canibeat Local magazine scout Old Setup: Vortech Supercharged 360WHP/262WTQ @ 11.5psi My build thread - WTF happened to nelsmar's car thread |
| The Following User Says Thank You to nelsmar For This Useful Post: | s2d4 (04-06-2014) |
#31 | |
Drives: red/black
#33 |
so where is the log? you said you would post it but just continued to not post it?
#34 |
It's still not clear if the tune you were running was an FI tune.
#35 | |
The log is worthless he sent it to me it is about ~5. =( Fuel trims are about right, afr is at stoich, but MAP is reading quite high.
#36 |
Drives: Smells like tires when I drive
#37 |
Drives: Pegasus GTS86
If you post the log it will be pretty easy to see if your fuel pressure is ok and what your afr was like during boost. Otherwise it's all speculation.
Stock internals will run 8psi (and more) easily with correct tuning, no need to drop compression ratio unless you are planning on chasing huge numbers. You could use this opportunity to build a stronger motor but you wouldn't need to drop c/r. edit. Log was sent. posted at the same time. |
#38 |
That guy
Drives: Ultramarine mt FR-S
Were you getting on it with the base map only, or was it tuned before you got on it. That part is a little unclear to me. You should never get on a basemap and generally keep it out of boost until it is properly tuned.
There are a lot of ways that it could have gone bad that without taking a close look at it, it is really hard to say. You're pretty close to Dynosty though. You might want to have them check things out.
Ultramarine mt FR-S
P&L stage 1 turbo Prime Motoring Flex fuel Jr Tuned 506whp @17psi (e73) |
#39 |
Drives: 2013 Subaru BRZ
I'm planning on boosting my car when I get back from this deployment, anyone know any good tuners in the NC/SC/VA area that are reliable and good tuners. I don't mind spending a lot of money on a tune I just want everything to be right.
#40 |
They guy who installed it even said it was too lean but you still went and beat on it? I still say the fuel pump install is at fault here but I'm sure the guy will say no even if it was just to save his reputation. Get the logs to LJ asap and he'll tell you what happened.
The Frozen North
#41 |
Drives: Black on black with so much class
Kids go to @Crawford Performance or @Evasive Motorsports
#42 |
Drives: 2014 FR-S Monogram Hot Lava
| The Following 2 Users Say Thank You to Lavalover For This Useful Post: | mikepaul21 (04-07-2014), Sportsguy83 (04-10-2014) |
| Full Blown Turbo Kit! | Unleashed | Engine, Exhaust, Bolt-Ons | 70 | 10-09-2013 09:46 AM |
| 2013 FR-S Full Blown Motorsports Stage1 Turbo kit. Mustang Dyno results. | Infamous Performance | Forced Induction | 10 | 07-03-2013 08:52 PM |
| FINAL RESULTS: Taking Full Blown Stage 1 To The MAX! @Pure Automotive (Dyno Inside!) | Pure Automotive | Forced Induction | 57 | 03-27-2013 11:41 PM |
| The Results Are In!! Full Blown Stage 1 Kit @ Pure Automotive Performance! | Pure Automotive | Forced Induction | 181 | 03-12-2013 02:11 PM |
| The Results Are In!! Full Blown Stage 1 Kit @ Pure Automotive | Pure Automotive | Mid-Atlantic | 22 | 02-12-2013 10:13 AM |
