Old 03-27-2014, 08:01 PM   #1
BrewCity-FR-S
Drives: 2013 Raven FR-S
Loose hanging wire from passenger footwell
Can anyone identify this wire?
BrewCity-FR-S is offline   Reply With Quote
Old 03-28-2014, 01:43 AM   #2
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
Bump...might just be a random/extra cable from the harness that is utilized by a different model?
Old 03-28-2014, 10:46 AM   #3
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
how many pins does it have?
supramkivtt2jz is offline   Reply With Quote
Old 03-31-2014, 11:45 AM   #4
BrewCity-FR-S
Bump....any clue?
Old 03-31-2014, 11:47 AM   #5
samfrs
Custom User Title
Drives: FRS
There's a thread about this a while back. I forgot what it was
samfrs is offline   Reply With Quote
Old 03-31-2014, 11:50 AM   #6
cnk
Drives: '13 DGM BRZ Limited
This is the only thread I could find about a loose wire. There may be others, but I only searched on "passenger wire". The connector in the link looks different though.
http://www.ft86club.com/forums/showt...plug+automatic
Old 03-31-2014, 12:12 PM   #7
andrew20195
Drives: 2013 Subaru BRZ
The blue tape indicates it's an accessory connector. If you don't have whatever accessory it is used for, it should not be connected to anything.
andrew20195 is offline   Reply With Quote
Old 03-31-2014, 12:19 PM   #8
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
it has a push pin thing attached to it so it should be held in place somewhere at least.
I was hoping he could tell me how many pins it has - the brz wiring diagram displays all connectrs and the routing path of the wires.
Old 03-31-2014, 12:45 PM   #9
2pt5RS
Berz
sounds like this might be for the interior footwell kit you can buy from your local dealer?
2pt5RS is offline   Reply With Quote
Old 03-31-2014, 01:28 PM   #10
extrashaky
Drives: 2014 BRZ Limited
I thought that kit came with its own harness that plugs in behind the stereo. Would the harness already be there?
Old 04-06-2014, 07:41 PM   #11
BrewCity-FR-S
Here are more angles of the plug, 3 wires go into it: White / Red-Blue / Yellow-Black
Old 04-07-2014, 01:53 AM   #12
Well, BrewCity-FR-S, if everything works on your car ...... I'd just put a piece of electrical tape over the end of it and stuff it back under the dash where it came from and forget about it......
PS - further research leads me to guess (if it were a BRZ) it would be a H-26 or H-27 connector for the door control receiver, which is part of the theft control system. Not positive of all of that.
Cant find passenger window wire from drivers side remote.. help? luv85 Electronics | Audio | NAV | Infotainment 2 11-03-2020 10:13 AM
Found Loose wire...?? IDK what it is rikdrt1 Scion FR-S / Toyota 86 GT86 General Forum 34 06-10-2020 01:42 PM
Flooded passenger footwell TonyTDT Issues | Warranty | Recalls / TSB 17 12-23-2014 06:10 PM
Reverse Wire Tap wire Location? Norkoastal Electronics | Audio | NAV | Infotainment 2 10-19-2012 11:22 AM
free wire harness on passenger side is for? SuperDave BRZ First-Gen (2012+) — General Topics 7 08-21-2012 02:12 PM
