Old 03-22-2013, 07:06 AM   #1
luv85
Drives: Grey GT
Cant find passenger window wire from drivers side remote.. help?
From drivers side remote you can control passengers side window.. so thought I could easily figure out the wires to passenger side window motor but I actually cant.
Managed to figure out drivers side window wire which (from memory) was pin 6. +12V was detected from pin 6 when window was rolling up. When window was rolling down pin 7 had 12V so that was easy.
However finding out passengers side window was not possible. Tried testing all the wires but nothing seemed to work. Anyone can help me out here..?
p.s. Reason for doing this is so I can install automatic window rolling up on lock module. I got drivers side window to roll up on lock but as I can not find wires to passengers side window, I cant get it to work. Pls help~
luv85 is offline   Reply With Quote
Old 03-22-2013, 09:20 AM   #2
sparks
sparks's Avatar
The passenger window is controlled from the Master switch via UART (Universal Asynchronous Receiver/Transmitter). Your best bet is to tap the passenger window switch.
2013 BRZ Preimum #452 - Sterling Silver
sparks is offline   Reply With Quote
Old 11-03-2020, 09:13 AM   #3
zypher10
zypher10's Avatar
Drives: GT86
We're you able to figure it out, also trying to make auto window module.
zypher10 is offline   Reply With Quote
Passenger window stuck. Marshman Issues | Warranty | Recalls / TSB 6 03-08-2013 07:39 AM
Passenger Window Switchs Out LarryGP Issues | Warranty | Recalls / TSB 10 11-13-2012 06:04 PM
Passenger window mystery FRiSson Scion FR-S / Toyota 86 GT86 General Forum 6 09-07-2012 02:30 PM
free wire harness on passenger side is for? SuperDave BRZ First-Gen (2012+) — General Topics 7 08-21-2012 01:12 PM
Teaking Tail light and Driver side passenger window auto down feyrerm Issues | Warranty | Recalls / TSB 2 08-11-2012 12:32 AM
