#43 |
Drives: TRD Ultramarine '13
Well as I found out later, the moustache on the BRZ is a part of the whole bumper, and can't be removed or changed separately. The bumper and the moustache is all one piece.
As far as the filling the holes and wrapping it goes, it will definitely work. Someone on here had a WRB BRZ with the moustache wrapped in carbon fibre vinyl and it looked pretty good. |
#44 | |
Drives: BRZ Limited
I'm thinking of filling it in with silicone and then vinyl wrapping it as well. |
#45 |
Drives: 2014 WRB BRZ
#46 |
Drives: 2014 Monogram FR-S White MT
I can't believe dealers continue to drill the bumper without at least asking the customer.
In the course of doing business, at least 1 customer has to have had complained to the dealer prompting them to evaluate their drilling policy. I would look into removing that whole plastic mustache piece, or at least coloring it the same as the body. |
#47 | |
#48 | |
Drives: BRZ Limited
Thanks |
#49 |
#50 |
Drives: 2013 WRB Subaru BRZ Sport-tech
#51 |
poverty cause racecar
Drives: Subaru BRZ JRSC'd
Realistically the best/easiest way to get them out is to pull the bumper. If you look earlier in the thread you will see the two rubber nuts that hold the bolt in place. Your two options are to either cut them off or heat them up hot enough to loosen the rubber. The latter option should be done carefully because there is a high risk of melting the plastic on the bumper. You CAN NOT pull the rubber nuts through the bolt's hole without seriously damaging the plastic part so you are essentially SOL unless you pull the bumper. Almost a full year later I still have to look at the four holes because of a failed experience with the S-Craft front nose (See my thread) and I would recommend leaving the plate where it is if the dealer already mounted the bracket. Or if you were lucky enough to only have two holes, get a cover similar to what pretty much every GR WRX/STI has!
#52 |
Drives: BRZ limited GBS
you can pull the rubber things out with pliers, use force but they will pop right out
#53 | |
#54 |
A little update, I went to the dealership to get an oil change and asked them to remove the front plate bracket. They removed it free of charge. I also went to Lowe's and got some plugs for the holes, and it fits perfectly. =)
#55 |
Drives: 2013 BRZ Limited M/T
Trimmed the bumper edges for a smooth fit and snapped right in.
http://m.lowes.com/pd/The-Hillman-Gr...-Plugs/3013226 |
| Plugging up license plate bumper holes? | JohnAyySays | Cosmetic Modification (Interior/Exterior/Lighting) | 10 | 04-12-2015 03:06 PM |
| License plate covering front plate effect cooling? | Wolfkiller | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 05-04-2013 07:19 PM |
| Front License plate/bumper protector | Aloxi | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 11-20-2012 09:29 PM |
| Front license plate: Why you don't want the dealer to drill your bumper | CircuitJerk | Issues | Warranty | Recalls / TSB | 53 | 08-27-2012 02:02 AM |
| Bumper Plugs for License Plate holes by dealer? | mikeg7827 | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 6 | 08-13-2012 05:33 PM |
