Old 04-05-2014, 07:50 PM   #43
kALMIGHTY
Drives: TRD Ultramarine '13
Originally Posted by ucsmfu View Post
has anyone tried this method ?
Well as I found out later, the moustache on the BRZ is a part of the whole bumper, and can't be removed or changed separately. The bumper and the moustache is all one piece.
As far as the filling the holes and wrapping it goes, it will definitely work. Someone on here had a WRB BRZ with the moustache wrapped in carbon fibre vinyl and it looked pretty good.
Old 04-05-2014, 07:57 PM   #44
ucsmfu
ucsmfu's Avatar
Drives: BRZ Limited
Any pics ?
I'm thinking of filling it in with silicone and then vinyl wrapping it as well.
ucsmfu is offline   Reply With Quote
Old 04-05-2014, 09:06 PM   #45
syrs_finest_frs
Drives: 2014 WRB BRZ
Any pics ?
I am in the same boat, and was thinking the same thing with the vinyl wrap.
syrs_finest_frs is offline   Reply With Quote
Old 04-05-2014, 10:04 PM   #46
subiestyle
subiestyle's Avatar
Drives: 2014 Monogram FR-S White MT
I can't believe dealers continue to drill the bumper without at least asking the customer.
In the course of doing business, at least 1 customer has to have had complained to the dealer prompting them to evaluate their drilling policy.
I would look into removing that whole plastic mustache piece, or at least coloring it the same as the body.
subiestyle is offline   Reply With Quote
Old 04-06-2014, 04:21 AM   #47
kALMIGHTY
Any pics ?
I think it's just plain gloss black vinyl but because of the texture of the moustache, it gives it a cool look in my opinion.
Old 04-06-2014, 04:26 AM   #48
ucsmfu
ucsmfu's Avatar
Drives: BRZ Limited
Attachment 73266
thanks for the pic, do you know what material was used to fill the holes with ?
Thanks
Old 04-06-2014, 06:26 PM   #49
kALMIGHTY
Thanks
I don't think anything was used because that owner didn't have any holes in the bumper. He just wrapped it in vinyl for fun.
Old 08-10-2014, 06:57 PM   #50
ShibaYuki
Drives: 2013 WRB Subaru BRZ Sport-tech
Originally Posted by Canehda View Post
So I got to go an adventure this weekend trying to take off the license plate mount, by adventure I mean I had to take the whole bumper off forever ruining my perfect factory fitment…
When I finally got the mount off I got the answer to "what is worse than two holes in my bumper"… Four
Are you kidding me?
[IMG][/IMG]
Not sure if visible through the picture, but yes those holes are not centred on the bumper
Needless to say I am not impressed
How did you take out the license plate bracket?! I'm having such a hard time. I can't remove the screws. And that is without remove the whole bumper.
ShibaYuki is offline   Reply With Quote
Old 08-10-2014, 11:01 PM   #51
Canehda
poverty cause racecar
Canehda's Avatar
Drives: Subaru BRZ JRSC'd
Realistically the best/easiest way to get them out is to pull the bumper. If you look earlier in the thread you will see the two rubber nuts that hold the bolt in place. Your two options are to either cut them off or heat them up hot enough to loosen the rubber. The latter option should be done carefully because there is a high risk of melting the plastic on the bumper. You CAN NOT pull the rubber nuts through the bolt's hole without seriously damaging the plastic part so you are essentially SOL unless you pull the bumper. Almost a full year later I still have to look at the four holes because of a failed experience with the S-Craft front nose (See my thread) and I would recommend leaving the plate where it is if the dealer already mounted the bracket. Or if you were lucky enough to only have two holes, get a cover similar to what pretty much every GR WRX/STI has!
Canehda is offline   Reply With Quote
Old 08-10-2014, 11:35 PM   #52
DarkestBuddha
Drives: BRZ limited GBS
you can pull the rubber things out with pliers, use force but they will pop right out
DarkestBuddha is offline   Reply With Quote
Old 08-11-2014, 12:11 AM   #53
ShibaYuki
So no way of doing it without pulling the bumper? I am very inexperienced when it comes to pulling the bumper off.
Old 08-12-2014, 02:44 PM   #54
ShibaYuki
A little update, I went to the dealership to get an oil change and asked them to remove the front plate bracket. They removed it free of charge. I also went to Lowe's and got some plugs for the holes, and it fits perfectly. =)
Old 04-12-2015, 11:48 AM   #55
Bramick
Bramick's Avatar
Drives: 2013 BRZ Limited M/T
Trimmed the bumper edges for a smooth fit and snapped right in.
http://m.lowes.com/pd/The-Hillman-Gr...-Plugs/3013226
2013 BRZ Limited | 1965 Mustang GT Fastback
Bramick is offline   Reply With Quote
Old 04-12-2015, 11:57 AM   #56
Bramick
Bramick's Avatar
Size:  45.1 KBName:  uploadfromtaptalk1428854238911.jpg
Size:  75.7 KBName:  uploadfromtaptalk1428854246094.jpg
Plugging up license plate bumper holes? JohnAyySays Cosmetic Modification (Interior/Exterior/Lighting) 10 04-12-2015 03:06 PM
License plate covering front plate effect cooling? Wolfkiller Scion FR-S / Toyota 86 GT86 General Forum 4 05-04-2013 07:19 PM
Front License plate/bumper protector Aloxi Cosmetic Modification (Interior/Exterior/Lighting) 3 11-20-2012 09:29 PM
Front license plate: Why you don't want the dealer to drill your bumper CircuitJerk Issues | Warranty | Recalls / TSB 53 08-27-2012 02:02 AM
Bumper Plugs for License Plate holes by dealer? mikeg7827 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 6 08-13-2012 05:33 PM
