Old 04-04-2014, 12:32 AM   #15
D K
Stig's dark passenger
Originally Posted by protpibe View Post
Thanks man, you're a beauty!
Hmm...
D K is offline   Reply With Quote
Old 04-04-2014, 10:42 AM   #16
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
Originally Posted by D K View Post
Hmm...
lol sorry. Translated from Canadian hockey lingo, that actually means "You're a good guy" and not "i want to make out with you"
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
The Following User Says Thank You to protpibe For This Useful Post:
SkAsphalt (04-04-2014)
Old 04-04-2014, 11:04 AM   #17
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Nice!
The one T-Bolt clamp I haven't replaced yet is the one on the Turbo inlet (PIC 2). Can you do me a giant favor and measure the diameter? The only thing I can offer is a "thanks" on your post lol
The turbo inlet doesn't see boost so a normal hose clamp is fine, plus nobody can see it all hidden down there anyways.
Old 04-04-2014, 02:29 PM   #18
Astroboy
Astroboy's Avatar
Drives: None
This is the measurement I need
Just confirming we're talking about the same thing!
Thanks again
I'll Check today when I get home, was going to check it yesterday but there was a tornado and my shack where I keep my tools is pretty far from my house. But hey I got one more question if you could help me out. I might sound stupid but, must I drain my oil before I star or any other fluids? If no, would it be a good idea to get my oil changed at Toyota one more time before I void my warranty?
Sent from my LG-D800 using Tapatalk
Astroboy is offline   Reply With Quote
Old 04-04-2014, 02:29 PM   #19
D K
Does anyone have the actual turbo specs on this?
I know its a hybrid of something....vf39? And 18g?
Wheel sizes, trims?
David
Old 04-04-2014, 02:44 PM   #20
protpibe
protpibe's Avatar
Thanks, and no rush at all.
It's not required, but I changed my oil after the install just because. If you don't, you'll still have to add a little bit of oil since the lines, turbo, and oil reservoir will have increased the oil capacity in your car. You won't lose any oil during the install unless you're doing it wrong lol. Both oil tap locations (galley plug and back of the cam) are mounted on top of the engine, so everything would of drained down.
You don't need to drain the entire coolant system, but you will need to top it off since you will lose some coolant when replacing the lines. Make sure you use the right stuff. My BRZ needed Subaru Super Blue.
1L of 0w20 from the dealer and a jug of coolant shouldn't run you more than $30 or so.
Old 04-04-2014, 02:49 PM   #21
protpibe
protpibe's Avatar
Wheel sizes, trims?
David
The only thing I've seen is that it's listed as an AVO 18/49 Turbo. I'm assuming 49 is the trim since it's not exactly known for it's giant power numbers? edit; Or maybe the a/r? I have no idea, just speculating lol
Old 04-04-2014, 03:14 PM   #22
xwd
It's pretty much a standard 7cm TD05-18G turbo. So it's larger than a VF39.
The Following 2 Users Say Thank You to xwd For This Useful Post:
SkAsphalt (04-04-2014), Sportsguy83 (04-07-2014)
Old 04-06-2014, 10:01 AM   #23
Astroboy
Astroboy's Avatar
Drives: None
I left the measurements at the shop
I have it written down. I'll give it to you later today
The Following 2 Users Say Thank You to Astroboy For This Useful Post:
D K (04-06-2014), ZionsWrath (04-08-2014)
Old 04-06-2014, 05:39 PM   #24
Astroboy
Astroboy's Avatar
Drives: None
Does anybody have pics of where each line goes connected from the turbo?
The Following User Says Thank You to Astroboy For This Useful Post:
Old 04-06-2014, 06:24 PM   #25
M1K3
M1K3's Avatar
Drives: vrooom...
here are some pics:
Sorry I don't have a pic of the water line that goes to the heater hose return pipe at the back of the engine.
M1K3 is offline   Reply With Quote
The Following 2 Users Say Thank You to M1K3 For This Useful Post:
onzippy (04-06-2014), ZionsWrath (04-08-2014)
Old 04-06-2014, 06:31 PM   #26
onzippy
Drives: 2014 FRS
Originally Posted by M1K3 View Post
here are some pics:
Sorry I don't have a pic of the water line that goes to the heater hose return pipe.
here's that picture... at the end of the pliers with the clamp.
This is where the coolant will come gushing out when you take it off.
Also have a picture of the oem coolant hose that gets removed. It ran along under the intake manifold. hmm.. Damn I didn't put the braiding on the new hose.
onzippy is offline   Reply With Quote
The Following 2 Users Say Thank You to onzippy For This Useful Post:
M1K3 (04-06-2014), ZionsWrath (04-08-2014)
Old 04-06-2014, 06:41 PM   #27
M1K3
M1K3's Avatar
Drives: vrooom...
Good team work
I concur
I wouldn't worry too much about it. I'm just anal and do stupid things that are not necessary.
Old 04-06-2014, 07:30 PM   #28
Astroboy
Astroboy's Avatar
Drives: None
Size:  126.8 KB which route should this hose go on the turbo, the blue side or the red side. It's the short hose
Installing a Turbo Kit + other mods chiefshayan Forced Induction 21 01-22-2014 10:58 PM
Installing a hood for the fr-s? Frs32907 Cosmetic Modification (Interior/Exterior/Lighting) 11 08-16-2013 11:06 AM
installing harness andrew5826 Cosmetic Modification (Interior/Exterior/Lighting) 16 07-25-2013 10:41 PM
need help installing this chenshuo Cosmetic Modification (Interior/Exterior/Lighting) 6 07-14-2013 01:17 PM
tips for installing amp and sub brichard0625 Electronics | Audio | NAV | Infotainment 4 05-19-2013 07:25 AM
