#897 | |
Drives: FT86
http://www.ft86club.com/forums/showp...9&postcount=44 See previous post by "milhouse" for Perrin CAI scalling values Make sure you have a copy of your original (unedited) ROM in case of problems 1. Open up your tune ROM in Romraider 2.select "intermediate" or above user level 3. select "mass air flow/engine load" folder on left hand side 4. select "MAF sensor scaling" table 5. copy in the volts and air flow values in as supplied by perrin 6. save 7. flash Log and test
| The Following User Says Thank You to steve99 For This Useful Post: | Superhatch (04-01-2014) |
#898 |
Drives: Subaru BRZ 2014 Limited WRB
OpenFlash Tablet
What is the warranty on the tablet itself? I plan to keep my BRZ for many years, but what happens a few years from now if I'm on a non-stock flash and the tablet is dead or stolen? Am I just stuck on whatever ECU setting I have at that time, or can my original ECU setting be restored?
I did a search on this, but when I search for openflash tablet warranty, I just get stuff on how this would affect our warranties with the car. @shiv@vishnu? -Z Last edited by zinzan; 03-31-2014 at 11:32 PM. |
| The Following User Says Thank You to zinzan For This Useful Post: | Turdinator (04-01-2014) |
#899 | |
Drives: 2014 Scion FR-S
When I plug in tablet and check Ecu info it says B01C yet in open flash manager it says B00C. It only lets me write B00C bin files to tablet and thus Ecu. Why the different readings? Sent from my SM-N900T using Tapatalk |
#900 | |
Drives: 2013 FRS
#901 | |
#902 | |
Drives: 2013 FRS
| The Following User Says Thank You to Shiv@Openflash For This Useful Post: | DC2R (04-01-2014) |
#903 | |
Noticed no LC. Do i need to activate that via ROM Raider. I am a complete noob when it comes to tuning. Is there anywhere on theh webz you would suggest going to learn? |
| The Following User Says Thank You to DC2R For This Useful Post: | Shiv@Openflash (04-01-2014) |
#904 | |
Drives: 2013 raven black fr-s
| The Following User Says Thank You to bakerr6 For This Useful Post: | DC2R (04-01-2014) |
#905 |
Drives: Neptune GR86
Is my OFT put together upside down?
I noticed in the video the cable plugs into the top but mine plugs into the bottom. The bottom also has the side with the bigger lip. Seems to make it a little more difficult pressing the buttons on the bottom of the screen. Never mind... I have now gone through the options and see the screen rotate lol
| The Following User Says Thank You to Andrew025 For This Useful Post: | Shiv@Openflash (04-01-2014) |
#906 | |
@shiv@vishnu? |
#907 | |
Drives: 2013 FRS
| The Following User Says Thank You to Shiv@Openflash For This Useful Post: | zinzan (04-01-2014) |
#908 | |
That is possibly true, but I had a first gen ipod touch lose wifi after 2 years and then fail to start altogether after 4 years; a second gen ipod touch fail to hold a battery charge after 2 years; a navigon gps device fail to sync with PC after 2 years; etc. My iPad 2 is in pretty good shape 2 years later, but I don't trust that it will outlive my car. |
#909 |
Addicted
Drives: 2013 Asphalt FR-S 6MT
Quick question, if I have stock headers but intake and exhaust. Do I go stage 2 EL map? or just stage 1?
edit: think it's stage 1.
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
#910 | |
| Tags |
| #lolwut, divinecomedy, dopeandcashcabinet, free shiv now, goddamitimissedit, golden cage, i missed the show, looks good, missed the fun, omgbbq, shiv 2016, thefatandthefurriest |
| Tablet on the dash ! | TRD_86 | Electronics | Audio | NAV | Infotainment | 23 | 05-16-2015 03:48 AM |
| Tablet Install | ThugNasty | Electronics | Audio | NAV | Infotainment | 4 | 04-13-2013 03:15 PM |
| Blutooth OBD II and a 9.7 tablet.. | Scooby South | Electronics | Audio | NAV | Infotainment | 10 | 12-16-2012 08:11 PM |
| 7.0 Tablet w/ Torque App | Thatruth2001 | Northwest | 26 | 11-21-2012 11:53 AM |
