Old 12-15-2012, 06:49 PM   #1
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
Blutooth OBD II and a 9.7 tablet..
I thinking of getting a Blutooth OBD II module with the Torque App on a 10.1 Tablet...To be able to Display the gauges and do some data-logging.. that way I wouldn't need extra gauges... Would that work...
Functions:
Read diagnostic trouble codes, both generic and manufacturer-specific, and display their meaning (over 3000 generic code definitions in the database).
Clear trouble codes and turn off the MIL ("Check Engine" light)
Display current sensor data, including:
Engine RPM
Calculated Load Value
Coolant Temperature
Fuel System Status
Vehicle Speed
Short Term Fuel Trim
Long Term Fuel Trim
Intake Manifold Pressure
Timing Advance
Intake Air Temperature
Air Flow Rate
Absolute Throttle Position
Oxygen sensor voltages/associated short term fuel trims
Fuel System status
Fuel Pressure
Scooby South is offline   Reply With Quote
Old 12-15-2012, 10:16 PM   #2
2forme
What tablet is 9.7 other than maxiPad?
Old 12-15-2012, 10:24 PM   #3
Scooby South
Conedancer
actually I meant 10.1...my bad..
Old 12-16-2012, 08:42 AM   #4
2forme
Oh ok, only reason I asked is because the iPad only works with WiFi OBD2 from what I've seen.
Old 12-16-2012, 10:40 AM   #5
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I believe the HP Touchpad is 9.7 too
Old 12-16-2012, 12:28 PM   #6
Scooby South
Conedancer
What I am thinking is to use the talblet..(Whatever size) to act as my gauges with the torgue Software app...so I don't have to actually install gauges...you can pickup the pieces for the install for around $150..tablet included....that and be able to data log all at once..
Bill
Old 12-16-2012, 02:11 PM   #7
Sportsguy83
Drives: Limited BRZ
Bill
I would like to think Torque and a Bluetooth adapter are good enough to get AFR and several other parameters but I don't know if I should trust them as replacement for actual wired gauges.
Old 12-16-2012, 02:19 PM   #8
Scooby South
Conedancer
why??? its ECU data which is probably more accurate than the gauges since its coming Right off the ECU .
Bill
Old 12-16-2012, 02:24 PM   #9
Sportsguy83
Drives: Limited BRZ
Bill
I know. I will probably give it a shot when the time comes. Just wanted to read more about cons about doing it this way.
Old 12-16-2012, 02:52 PM   #10
2forme
AFR off the ECU isn't as accurate as a real wideband. I wouldn't trust it.
Old 12-16-2012, 08:11 PM   #11
Scooby South
Conedancer
my Torque App Digital Display ..it has many Inputs...Me likey..
Nexus 7 Tablet Lefty Electronics | Audio | NAV | Infotainment 63 06-13-2015 01:18 PM
Tablet on the dash ! TRD_86 Electronics | Audio | NAV | Infotainment 23 05-16-2015 03:48 AM
7.0 Tablet w/ Torque App Thatruth2001 Northwest 26 11-21-2012 11:53 AM
Android Tablet + torque CharlieChaos Electronics | Audio | NAV | Infotainment 3 10-04-2012 08:23 PM
