#883 |
Erected Member
Drives: frs
I'm not sure to what extent the ecu is doing after reflash but the car feels sluggish after every reflash, but feels fine after 80 or so miles. The logs also shows very rich afr at wot during this learning time.
Edit: just for shitz and grinds. Try running your logs in virtual dyno right after reflash with those after 80+miles. Only seems logical..since if you reset a ecu because of a cel. It'll return only after the ecu relearn and can determined that there's an issue |
#884 |
Erected Member
Drives: frs
Sry for double post but my point is that it makes it hard to tune if you are not absolutely sure that the ecu is running at optimal efficiency with the new changes/tweaks
#885 | |
by ensuring that there are no trims operating in open loop and initial IAM is set to 1.. you should be able to flash the car, wait 30 seconds or so max for the exhaust cam to turn on, and go do power pulls. the throttle learning may need to take place but that won't effect a WOT pull. |
#886 | |
Erected Member
Drives: frs
#887 |
#888 |
Drives: 2013 FRS
After you flash your ecu, make sure you start the engine and let it idle for a minute until the revs drop to ~800rpm. Then you can start driving. If you start driving right away, you will be in a low power mode that disables VVT. The car will drive ok but will feel very anemic. You can confirm this condition by plugging in the OFT, going to the realtime data screen and looking at VVT intake and VVT exhaust values. One or both of them will be 0.
#889 |
Drives: 2014 Scion FR-S
Just received tablet today . Flashed 1.42 stage one map at lunch and feels good so far. I noticed those maps seen to be static since December. Would you recommending flashing beta tunes? I have stock 2014 FR-S with drop-in filter. Waiting patiently for open flash header to arrive.
Sent from my SM-N900T using Tapatalk |
#890 |
AIM4APX
Drives: 2013 WRB BRZ Limited
New OFT user here. I feel like I'm getting conflicting stories about eh E85 EL tune. Can/should it be used with a stock exhaust system? I've read people using it with no issues and others saying a header is required. Could anyone help out with that?
Also, I've got a Perrin intake and tube. Will those be ok to use with the STG 1 tune? TIA.
"It's very difficult to present technology as an overtly positive sales device to people who want an emotional car" -Chris Harris
#891 | |
Drives: 2013 FRS
#892 | |
Drives: 2013 FRS
#893 | |
Erected Member
Drives: frs
#894 | |
Drives: 86
is the 1.6 maps just around the corner or am I day dreaming. Sent from my iPhone using Tapatalk
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
#895 |
Village Idiot
Drives: '13 FR-S Ultramarine Manual
Just got mine! Reading as we speak then headed to fill up with e85. Wooo!!!
#896 | |
Drives: UK GT86
You can also clear the accelerator pedal learning too by pushing the pedal through its full range 5 or 6 times while the ignition is on without the engine running.
.: Stealth 86 :.
| Tags |
| #lolwut, divinecomedy, dopeandcashcabinet, free shiv now, goddamitimissedit, golden cage, i missed the show, looks good, missed the fun, omgbbq, shiv 2016, thefatandthefurriest |
| Tablet on the dash ! | TRD_86 | Electronics | Audio | NAV | Infotainment | 23 | 05-16-2015 03:48 AM |
| Tablet Install | ThugNasty | Electronics | Audio | NAV | Infotainment | 4 | 04-13-2013 03:15 PM |
| Blutooth OBD II and a 9.7 tablet.. | Scooby South | Electronics | Audio | NAV | Infotainment | 10 | 12-16-2012 08:11 PM |
| 7.0 Tablet w/ Torque App | Thatruth2001 | Northwest | 26 | 11-21-2012 11:53 AM |
