Old 03-31-2014, 09:14 PM   #897
steve99
Drives: FT86
Originally Posted by Superhatch View Post
New OFT user here. I feel like I'm getting conflicting stories about eh E85 EL tune. Can/should it be used with a stock exhaust system? I've read people using it with no issues and others saying a header is required. Could anyone help out with that?
Also, I've got a Perrin intake and tube. Will those be ok to use with the STG 1 tune?
TIA.
Might be worth adding in Perrin supplied scaling values for MAF, assuming you have 2.75' perrin intake, the 3" scaling are arround somewhere as well, or just emial perrin and they will supply them.
http://www.ft86club.com/forums/showp...9&postcount=44
See previous post by "milhouse" for Perrin CAI scalling values
Make sure you have a copy of your original (unedited) ROM in case of problems
1. Open up your tune ROM in Romraider
2.select "intermediate" or above user level
3. select "mass air flow/engine load" folder on left hand side
4. select "MAF sensor scaling" table
5. copy in the volts and air flow values in as supplied by perrin
6. save
7. flash
Log and test
Old 03-31-2014, 10:07 PM   #898
zinzan
zinzan's Avatar
Drives: Subaru BRZ 2014 Limited WRB
OpenFlash Tablet
What is the warranty on the tablet itself? I plan to keep my BRZ for many years, but what happens a few years from now if I'm on a non-stock flash and the tablet is dead or stolen? Am I just stuck on whatever ECU setting I have at that time, or can my original ECU setting be restored?
I did a search on this, but when I search for openflash tablet warranty, I just get stuff on how this would affect our warranties with the car.
@shiv@vishnu?
-Z
zinzan is offline   Reply With Quote
Old 03-31-2014, 11:10 PM   #899
DC2R
Drives: 2014 Scion FR-S
Originally Posted by shiv@vishnu View Post
The v1.5x OTS maps haven't been "beta" for a few weeks so definitely try them as they are more refined than what you are running now
Weird. Was seeing different info in downloads section of your site earlier.
When I plug in tablet and check Ecu info it says B01C yet in open flash manager it says B00C. It only lets me write B00C bin files to tablet and thus Ecu. Why the different readings?
Sent from my SM-N900T using Tapatalk
DC2R is offline   Reply With Quote
Old 03-31-2014, 11:17 PM   #900
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
The B series OTS maps are all based on the B01C rom. But you need to load a version of that ROM that is compatible with your original rom (B00C). What you are seeing is normal
Shiv@Openflash is offline   Reply With Quote
Old 03-31-2014, 11:36 PM   #901
DC2R
Thanks. Just flashed the stage one 1.58 B001 bin. Took for quick spin and felt great. Almost got me in trouble. If I want to try e85 on stock FR-S I can run stage 2el e85 tune correct?
Old 03-31-2014, 11:49 PM   #902
Shiv@Openflash
Drives: 2013 FRS
great to hear! And yes indeed, the stg2 EL E85 map will fit you well
Old 04-01-2014, 09:04 AM   #903
DC2R
Great! Huuuuge difference between 1.42 and 1.58 maps. Took for spin and logged it. Not sure if i logged it correctly but here it is: http://datazap.me/u/dc2r/stage-1-158-oft
Noticed no LC. Do i need to activate that via ROM Raider. I am a complete noob when it comes to tuning. Is there anywhere on theh webz you would suggest going to learn?
Old 04-01-2014, 09:56 AM   #904
bakerr6
Drives: 2013 raven black fr-s
I believe he ahs a video on youtube, but it's really quite easy. I would say download the software and go to town step by step, using the video first.
bakerr6 is offline   Reply With Quote
Old 04-01-2014, 01:05 PM   #905
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Is my OFT put together upside down?
I noticed in the video the cable plugs into the top but mine plugs into the bottom.
The bottom also has the side with the bigger lip. Seems to make it a little more difficult pressing the buttons on the bottom of the screen.
Never mind... I have now gone through the options and see the screen rotate lol
Old 04-01-2014, 01:26 PM   #906
zinzan
zinzan's Avatar
@shiv@vishnu?
-Z
bump
@shiv@vishnu?
Old 04-01-2014, 01:46 PM   #907
Shiv@Openflash
Drives: 2013 FRS
Sorry... didn't see your question until. Officially, there is a 1 year warranty on the OFT. But realistically just as long as you don't drop kick it across a foot field field in the rain, it should easily outlive your car. Modern electronics are great that way.
Old 04-01-2014, 02:44 PM   #908
zinzan
zinzan's Avatar
Thanks.
That is possibly true, but I had a first gen ipod touch lose wifi after 2 years and then fail to start altogether after 4 years; a second gen ipod touch fail to hold a battery charge after 2 years; a navigon gps device fail to sync with PC after 2 years; etc. My iPad 2 is in pretty good shape 2 years later, but I don't trust that it will outlive my car.
Old 04-01-2014, 03:16 PM   #909
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
Quick question, if I have stock headers but intake and exhaust. Do I go stage 2 EL map? or just stage 1?
edit: think it's stage 1.
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
l0aded is offline   Reply With Quote
Old 04-01-2014, 03:20 PM   #910
phrosty
Thanks.
Keep your original ROM backed up. If OFT dies I'm sure there's a way to "initialize" one from a ROM rather than the car.
phrosty is offline   Reply With Quote
#lolwut, divinecomedy, dopeandcashcabinet, free shiv now, goddamitimissedit, golden cage, i missed the show, looks good, missed the fun, omgbbq, shiv 2016, thefatandthefurriest
Tablet on the dash ! TRD_86 Electronics | Audio | NAV | Infotainment 23 05-16-2015 03:48 AM
Tablet Install ThugNasty Electronics | Audio | NAV | Infotainment 4 04-13-2013 03:15 PM
Blutooth OBD II and a 9.7 tablet.. Scooby South Electronics | Audio | NAV | Infotainment 10 12-16-2012 08:11 PM
7.0 Tablet w/ Torque App Thatruth2001 Northwest 26 11-21-2012 11:53 AM
