Old 03-30-2014, 11:51 AM   #533
Slowbaru
Slowbaru's Avatar
Drives: 2013 WRB BRZ Limited
Originally Posted by cslntuee View Post
HI,
I plan to order Grimmspeed strut bar.
Do you think this block can fit with Grimmspeed strut bar?
The block height is 35.8 mm from the thread.
Thanks a lot.
IDK. It looks like it would be a tight fit. You may end up having to remove the engine cover. There are other STB that have plenty of room to spare. Im going to go with Cusco just to be sure.
Slowbaru is offline   Reply With Quote
The Following User Says Thank You to Slowbaru For This Useful Post:
cslntuee (03-30-2014)
Old 03-30-2014, 06:17 PM   #534
Turdinator
Señor Member
Turdinator's Avatar
HI,
Thanks a lot.
I did some rough measurements the other say and I think it will be a little too tight, less than a cm of clearence without the engine over. When I eventually get the power blocks i will be looking to space the strut bar up somehow.
1974 TA22 Celica
2013 86 GT
The Following User Says Thank You to Turdinator For This Useful Post:
Old 03-30-2014, 06:39 PM   #535
Slowbaru
Slowbaru's Avatar
Just finished installing mine. Dont be lazy with disconnecting the hoses and wires. It will eventually be in your way. I decided I would try to be a "badass" like the dude in the motoiq article and do it without help. I reminded myself of Ralphs dad fixing the water heater weaving a tapestry of curse words. It was a minor pain in the ass, but not too bad.
kodyo (03-30-2014)
Old 03-30-2014, 07:08 PM   #536
cslntuee
Drives: Subaru BRZ Limited
Originally Posted by Turdinator View Post
I did some rough measurements the other say and i think it will be a little too tight, less than a cm of clearence withouit the engine over. When I eventually get the power blocks i will be looking to space the strut bar up somehow.
Do you consider other brand of the strut bar?
Which one will be the candidate in your mind?
Thanks again.
cslntuee is offline   Reply With Quote
Old 03-30-2014, 07:09 PM   #537
Craig
Craig's Avatar
Drives: Asphalt FRS
It's so strange reading these threads, there's 4 kinds of people.
Those asking intelligent / necessary questions
Those responding to said questions
Those bashing each other
Those bashing crawford
This thread and forum in general would be better without the second two, its getting tiring reading through pointless arguments about product cost / who's **** is bigger when I'm just looking for people like @nelsmar who're trying to get information out there.
Current: Nameless Headerback- Crawford BPB - Zeta Intake Duct - Mishimoto Intake
Craig is offline   Reply With Quote
The Following 8 Users Say Thank You to Craig For This Useful Post:
CARNZ (03-30-2014), Crawford Performance (03-31-2014), kodyo (03-30-2014), Mathewgzlz (03-30-2014), nelsmar (03-31-2014), Readytoxplod (04-06-2014), Turdinator (03-30-2014), Yobiwan (03-30-2014)
Old 03-30-2014, 07:27 PM   #538
Turdinator
Señor Member
Turdinator's Avatar
Thanks again.
I don't know what is out there as far as strut bars go I am sorry. I think the JDM TRD bar may as I have drooled over it before and it is raised up a bit. Maybe ask people with the innovate superchargers what they do?
1974 TA22 Celica
2013 86 GT
The Following 2 Users Say Thank You to Turdinator For This Useful Post:
Carlitoz3 (03-31-2014), cslntuee (03-30-2014)
Old 03-30-2014, 07:42 PM   #539
JDogg
JDogg's Avatar
Drives: 2013 Black Scion FR-S
Would leaving the cover off be a bad idea?
JDogg is offline   Reply With Quote
Old 03-30-2014, 08:15 PM   #540
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Cuscos strut bar clears Innovate kit, and will clear this mod as well for sure.
The Following User Says Thank You to OICU812 For This Useful Post:
Old 03-30-2014, 08:44 PM   #541
Slowbaru
Slowbaru's Avatar
No. Its there for looks. It serves no real purpose.
JDogg (03-30-2014)
Old 03-30-2014, 09:56 PM   #542
JDogg
JDogg's Avatar
Sweet, I'm just going to take it off and keep my Hotchkis STB then. Hopefully that should fit.
Old 03-30-2014, 11:08 PM   #543
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Originally Posted by governor View Post
As an engineer with a very good understanding of hydraulics and fluid dynamics I feel the need to challenge the quoted statement.
-gov
Fair, I picked it up from a lecture and I'll need to do some research to back it up, as an engineer who's spent the last two years focusing on mechanical design and heat transfer, my fluids are weak.
Intuitively, the intake and exhaust valves are nozzles, albeit ones with a terribly inefficient shape, at the precise moment of opening there is a huge amount of pressure difference between the chamber and the intake/exhaust with an extremely small choke point which from my hazy lecture memory is what forces the escaping gas to travel at ludicrous speeds.
Just saw your second post basically saying what I just did, glad we're on the same page, even more glad there's someone to challenge me when I'm not up to snuff.
ineedyourdiddly
governor (04-05-2014)
Old 03-30-2014, 11:34 PM   #544
s2d4
s2d4's Avatar
@strat61caster, hope you can shed some light on this being clued up about heat transfer.
What would the implication of a solid ally block compared to non-metalic/lower heat absorption material instead?
Sent from my Galaxy Nexus using Tapatalk
Old 03-30-2014, 11:52 PM   #545
FrsDuke
Fanboy
FrsDuke's Avatar
Drives: 2013 ultramarine frs
Plastic intake feeds aluminum heads. The plastic now feeds aluminum spacers for like 35mm before entering an aluminum head. I'm gonna say its insignificant.
I'm done helping those who won't help themselves.
TL;DR:
-Duke
FrsDuke is offline   Reply With Quote
Old 03-31-2014, 12:35 AM   #546
nelsmar
HI,
Thanks a lot.
I'll ask @Ninjin if I can borrow his this week and test fit it. Do me a fav and pm me to remind me later this week!
Thanks. Apparently everyone knows more than us though. Thus makes me question I'd I should waste my time and money on future tests of other products >.< apparently the internet can decide what is better without real testing.
My flickr - Canibeat
Local magazine scout
The Following 4 Users Say Thank You to nelsmar For This Useful Post:
Craig (03-31-2014), cslntuee (04-01-2014), GT86_PRAGUE (12-22-2014), SirBrass (03-31-2014)
billet, crawford, magic blocks
Crawford Performance Turbo BRZ! Balance Meets Power - Ignition Episode 71 ZetaVI BRZ Photos, Videos, Wallpapers, Gallery Forum 22 04-01-2014 05:19 PM
short blocks? 350matt Engine, Exhaust, Transmission 4 11-04-2013 08:37 PM
Billet Oil Catch Can #BC-175 by Billet Custom Tim_Asphalt_FRS Engine, Exhaust, Transmission 48 10-27-2013 02:29 PM
***Blitz Advance Power Air Cleaner and SUS Power Core Intakes*** FT-86 SpeedFactory Engine, Exhaust, Transmission 1 10-07-2013 09:40 PM
