Old 03-29-2014, 03:05 PM   #491
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
Originally Posted by nelsmar View Post
Just finished stock vs stock tuned. Installing on this hot ass engine...
130whp baseline. 145whp tuned. <3 me a heartbreaker dyno :P
That is true econocar numbers
Luckrider is offline   Reply With Quote
The Following User Says Thank You to Luckrider For This Useful Post:
Jmonty (07-20-2014)
Old 03-29-2014, 03:14 PM   #492
Pixie_Niner
Drives: GT86
Looking forward to seeing the results
Pixie_Niner is offline   Reply With Quote
Old 03-29-2014, 03:29 PM   #493
nelsmar
Tip: don't do this right after back to back dyno pulls. And don't misplace your magnet on a stick. Damn that burned. I could only imagine how dez would be on a rant at this very moment if he was here haha.
My flickr - Canibeat
Local magazine scout
The Following 3 Users Say Thank You to nelsmar For This Useful Post:
Boofneenee (03-29-2014), Hawaiian (03-29-2014), Luckrider (03-29-2014)
Old 03-29-2014, 03:38 PM   #494
governor
Drives: 2013 FR-S Navy Blue
Every time a valve is opened or closed there is a sonic boom as the pressure differential is so great that the gases moving around break the sound barrier, there's a shockwave from this that can be used to aid (or hinder) in airflow not only to the single cylinder but to the system as a whole.
As an engineer with a very good understanding of hydraulics and fluid dynamics I feel the need to challenge the quoted statement.
Compressible fluid flow is a subject of which there is a good amount of information online. The one thing that you will find stated in almost every single resource is that without a very specifically designed nozzle mach speeds are not achievable and that in reality the maximum achievable speed in a piping assembly is going to be in the neighborhood of 0.7 mach. We use this bit of very well understood physics to design pressure relief piping in plants, however the fundamental physical limitation still exists and applies.
I find the notion that gas is breaking the sound barrier inside a vehicle a bit absurd. Disclaimer: I could be wrong, but in this case I highly doubt it. As a valve opens the mass flow rate through the effective orifice will be dependent on the upstream pressure, orifice characteristics of the valve, the downstream piping and the exit pressure. There's a very concise blurb about this and critical vs. subcritical pressure ratios and the effect of the piping on flows in Perry's handbook.
Now the speed at which a compression wave can move in the fluid is a different story. This will be close to the speed of sound in the compressible continuum I.E. Mach - 1.0. Once again however, nothing is -breaking- the sound barrier.
In terms of piston design and efficiency, pistons are used extensively to teach the topic of thermodynamics. The amount of available PV work (Pressure-Volume work) is well understood and good design for power will not necessarily be one that is efficient as an infinite amount of time would be required to pull out every last quantum of energy created by the increased pressure from combustion. So the piston and exhaust hydraulics could be designed in some way to balance a trade-off of efficiency and power-weight and of course cost.
-gov
governor is offline   Reply With Quote
The Following 5 Users Say Thank You to governor For This Useful Post:
avishenoy1 (09-24-2015), FrsDuke (03-29-2014), Hawaiian (03-29-2014), Sojhinn (03-29-2014), strat61caster (03-30-2014)
Old 03-29-2014, 03:42 PM   #495
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
-gov
As a physics teacher I really appreciate this explanation.
Installed Mods:
The Following 2 Users Say Thank You to Sojhinn For This Useful Post:
governor (03-29-2014), Team STILLEN (03-29-2014)
Old 03-29-2014, 05:25 PM   #496
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
As a doctor I have no clue what your talking about
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline   Reply With Quote
The Following 2 Users Say Thank You to Boofneenee For This Useful Post:
raven1231 (03-29-2014), Sojhinn (03-29-2014)
Old 03-29-2014, 05:26 PM   #497
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
-gov
FRS
Old 03-29-2014, 05:28 PM   #498
Sojhinn
Sojhinn's Avatar
-gov
I don't want to side track this thread but you had to take the mcat.
Installed Mods:
Old 03-29-2014, 06:27 PM   #499
Dimman
Kuruma Otaku
Dimman's Avatar
-gov
I'm not 100% certain on the gas itself (there is often talk of sonic choking if velocity gets to high) leaving breaking breaks the sound barrier, but there is a wave produced that travels at the local speed of sound. The wave is what is used to increase gas speed and flow by modifying the pressure differential across the valves. It's timing, sign and effective strength are affected by the tubing cross section, distance traveled, gas density etc... which is what part of header and intake tuning is about. You want a high pressure positive wave at the intake as it opens and a low pressure negative wave at the exhaust when it opens.
This is why you sometimes see headers "shift" power up or down the rpm range, with a bump at high rpm. The higher rpm bump is typically from flow improvement, whereas the shift is from acoustic changes.
Because titanium.
Old 03-29-2014, 07:08 PM   #500
FrsDuke
Fanboy
FrsDuke's Avatar
Drives: 2013 ultramarine frs
Did you fall asleep during lecture? He said the compression wave can move at mach1.0 but no material breaks the sound barrier. His post was just to clear up the guy claiming sonic booms from flow velocity at the valves. I'm not making a claim about the validity of your statement only that it is not a correction of gov's.
I'm done helping those who won't help themselves.
TL;DR:
-Duke
FrsDuke is offline   Reply With Quote
The Following User Says Thank You to FrsDuke For This Useful Post:
Old 03-29-2014, 07:10 PM   #501
FrsDuke
Fanboy
FrsDuke's Avatar
Good thing "your" vs "you're" wasn't a major part of the mcat.
TL;DR:
-Duke
Old 03-29-2014, 07:13 PM   #502
Sojhinn
Sojhinn's Avatar
That's why I'm a physics teacher and not an English teacher. We get our point across and that's good enough.
Installed Mods:
Old 03-29-2014, 07:16 PM   #503
FrsDuke
Fanboy
FrsDuke's Avatar
Not you
I was making fun of this
TL;DR:
-Duke
Old 03-29-2014, 07:17 PM   #504
AdrianG
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
"Good enough": The standard Teacher mentality. :P
AdrianG is offline   Reply With Quote
The Following User Says Thank You to AdrianG For This Useful Post:
TwinturboCamry (03-29-2014)
billet, crawford, magic blocks
Crawford Performance Turbo BRZ! Balance Meets Power - Ignition Episode 71 ZetaVI BRZ Photos, Videos, Wallpapers, Gallery Forum 22 04-01-2014 05:19 PM
short blocks? 350matt Engine, Exhaust, Transmission 4 11-04-2013 08:37 PM
Billet Oil Catch Can #BC-175 by Billet Custom Tim_Asphalt_FRS Engine, Exhaust, Transmission 48 10-27-2013 02:29 PM
***Blitz Advance Power Air Cleaner and SUS Power Core Intakes*** FT-86 SpeedFactory Engine, Exhaust, Transmission 1 10-07-2013 09:40 PM
