#4061 |
Turning is for Nerds
Drives: 35 characters is not enough
I pulled the clips out unplugged and removed both sensors with the header, it's a lot easier to swap them out off car.
#4062 |
Drives: 2013 MT Asphalt FRS
#4063 |
Fanboy
Drives: 2013 ultramarine frs
From behind with a small flathead. Two barbs need to be pressed flat. Do the top and rock the clip down. Then do the bottom and out it comes. Maybe it was left and right not top and bottom but same idea.
I'm done helping those who won't help themselves.
TL;DR: ![]() -Duke |
#4064 | |
cut them off with a knife/scissor? Worried I might damage the wire |
#4065 |
Fanboy
Oh that was for the clips holding the wire. The plug just has a little deal you press or lift or something with a little catch.
| The Following User Says Thank You to FrsDuke For This Useful Post: | Carlitoz3 (03-29-2014) |
#4066 |
The clips that were directly in the block I just pried out with a small flathead. The other 2 that were in the small brackets, I first unbolted the brackets, then used pliers to press the clips together and out, from the backside of the brackets.
| The Following User Says Thank You to toeout For This Useful Post: | Carlitoz3 (03-29-2014) |
#4067 |
Had my local Subaru mechanic install this header on Friday. The flanges that bolt up to the block were off a bit, causing leak issues. After a couple of tries we double gasketed it with about 50 lb ft of torque.
Perrin 2.5 overpipe and full exhaust, couldnt be happier with the sound. Definitely more power available, lots more fun to drive. I am untuned until nameless releases theirs, hopefully soon. At this point I have put about 250 miles on it so the computer should be settled. |
#4068 | |
Long Distance Driver
And I assume it was flat side of the gasket on the header flange and flat side of the other gasket against the bock?
#4069 |
Drives: small
So let me get this straight, there are some Nameless fanboys that call out competitors for shoddy craftsmanship suggesting Nameless is the pinnacle yet their flanges don't even line up? Yikes...
#4070 |
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
I looked through a bunch of pages, any dynos for innovate plus header and exhaust on pump / non e85?
Nolan
#4071 |
Drives: 2014 BRZ, 08 CBR600RR
I am selling my nameless performance header. Sucks that I didn't even get to run it for a month but i'm ordering a turbo kit tomorrow. Wish it would have came sooner. Anybody interested in the header can PM me for a good price. Uncoated and used for 3 weeks, around 400 miles on it. I have a spacer for the o2 sensor for those untuned so it won't throw a CEL
#4072 |
The flanges line up, they just need to be torque a little more than oem specs. Around 35 ft lbs with new gaskets made mine stop leaking
#4073 |
Drives: Devolving WR Blue 6 Spd BRZ Limited
Just FYI, if your header leaks initially, don't go right to double gaskets or jump to conclusions that the flanges are poorly made. Give it a chance to warm up and try repositioning and tightening things up after it's hot. Mine leaked noticeably at first. I was able to tighten the bolts better after it got hot. Within a few minutes the gaskets set and the leak has completely gone away.
#4074 | |
Lap time enthusiast
Drives: Asphalt '13 FR-S 6MT
| The Following 2 Users Say Thank You to raul For This Useful Post: | sato (03-31-2014), Sportsguy83 (03-31-2014) |
| Tags |
| 21 months no dyno, 22 months no vendor dyno, 22months4rattles&leakssmh, amazing warped qualiy, y u no tag |
| Nameless Performance BRZ Axleback Exhaust | ESBjiujitsu | Engine, Exhaust, Transmission | 1377 | 04-21-2020 03:23 AM |
| Nameless Performance Axleback is available for pre-order. | Nameless Performance Inc. | Engine, Exhaust, Bolt-Ons | 114 | 07-23-2012 11:38 PM |
| Nameless Performance Downpipe is available for pre-order. | Nameless Performance Inc. | Engine, Exhaust, Bolt-Ons | 4 | 07-12-2012 05:57 PM |
| We are Nameless Performance. | John@Nameless | Announcements, Contests, Giveaways | 22 | 06-19-2012 12:32 AM |
| Nameless Performance is here. | Nameless Performance Inc. | Engine, Exhaust, Bolt-Ons | 16 | 06-06-2012 05:32 AM |
