jpit
Old 03-29-2014, 09:37 PM   #4061
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
Originally Posted by Carlitoz3 View Post
How are you guys taking off the 02 sensor plugs?
I pulled the clips out unplugged and removed both sensors with the header, it's a lot easier to swap them out off car.
Decay107 is offline   Reply With Quote
Old 03-29-2014, 09:51 PM   #4062
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
I'm having the hardest time to even do these simple things.
How did u remove the clips?
Carlitoz3 is offline   Reply With Quote
Old 03-29-2014, 10:01 PM   #4063
FrsDuke
Fanboy
FrsDuke's Avatar
Drives: 2013 ultramarine frs
From behind with a small flathead. Two barbs need to be pressed flat. Do the top and rock the clip down. Then do the bottom and out it comes. Maybe it was left and right not top and bottom but same idea.
I'm done helping those who won't help themselves.
TL;DR:
-Duke
FrsDuke is offline   Reply With Quote
Old 03-29-2014, 10:07 PM   #4064
Carlitoz3
Carlitoz3's Avatar
As for the two plastics holding the wire,
cut them off with a knife/scissor?
Worried I might damage the wire
Old 03-29-2014, 10:21 PM   #4065
FrsDuke
Fanboy
FrsDuke's Avatar
Oh that was for the clips holding the wire. The plug just has a little deal you press or lift or something with a little catch.
TL;DR:
-Duke
The Following User Says Thank You to FrsDuke For This Useful Post:
Carlitoz3 (03-29-2014)
Old 03-29-2014, 10:31 PM   #4066
toeout
The clips that were directly in the block I just pried out with a small flathead. The other 2 that were in the small brackets, I first unbolted the brackets, then used pliers to press the clips together and out, from the backside of the brackets.
toeout is offline   Reply With Quote
The Following User Says Thank You to toeout For This Useful Post:
Old 03-30-2014, 12:01 PM   #4067
Callahan
Had my local Subaru mechanic install this header on Friday. The flanges that bolt up to the block were off a bit, causing leak issues. After a couple of tries we double gasketed it with about 50 lb ft of torque.
Perrin 2.5 overpipe and full exhaust, couldnt be happier with the sound. Definitely more power available, lots more fun to drive. I am untuned until nameless releases theirs, hopefully soon. At this point I have put about 250 miles on it so the computer should be settled.
Callahan is offline   Reply With Quote
Old 03-30-2014, 12:49 PM   #4068
Sargy
Long Distance Driver
Sargy's Avatar
Double gaskets gave you no more leaks from the flanges?
And I assume it was flat side of the gasket on the header flange and flat side of the other gasket against the bock?
Sargy is offline   Reply With Quote
Old 03-30-2014, 01:21 PM   #4069
Boxer486
Drives: small
So let me get this straight, there are some Nameless fanboys that call out competitors for shoddy craftsmanship suggesting Nameless is the pinnacle yet their flanges don't even line up? Yikes...
Boxer486 is offline   Reply With Quote
Old 03-30-2014, 02:16 PM   #4070
pheoxs
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
I looked through a bunch of pages, any dynos for innovate plus header and exhaust on pump / non e85?
Nolan
pheoxs is offline   Reply With Quote
Old 03-30-2014, 04:15 PM   #4071
14BRZ
14BRZ's Avatar
Drives: 2014 BRZ, 08 CBR600RR
I am selling my nameless performance header. Sucks that I didn't even get to run it for a month but i'm ordering a turbo kit tomorrow. Wish it would have came sooner. Anybody interested in the header can PM me for a good price. Uncoated and used for 3 weeks, around 400 miles on it. I have a spacer for the o2 sensor for those untuned so it won't throw a CEL
14BRZ is offline   Reply With Quote
Old 03-30-2014, 04:16 PM   #4072
14BRZ
14BRZ's Avatar
The flanges line up, they just need to be torque a little more than oem specs. Around 35 ft lbs with new gaskets made mine stop leaking
Old 03-31-2014, 01:22 AM   #4073
Slip Angle
Drives: Devolving WR Blue 6 Spd BRZ Limited
Just FYI, if your header leaks initially, don't go right to double gaskets or jump to conclusions that the flanges are poorly made. Give it a chance to warm up and try repositioning and tightening things up after it's hot. Mine leaked noticeably at first. I was able to tighten the bolts better after it got hot. Within a few minutes the gaskets set and the leak has completely gone away.
Slip Angle is offline   Reply With Quote
Old 03-31-2014, 08:22 AM   #4074
raul
Lap time enthusiast
raul's Avatar
Drives: Asphalt '13 FR-S 6MT
I was installing mine yesterday and we tried tightening things cold and hot. Still have a leak. Having the car looked at today. I got my baseline dyno Saturday, once I get the leak sorted out I'll run an untuned dyno, then get it tuned and once more on the rollers. Should have results by late next week.
raul is offline   Reply With Quote
The Following 2 Users Say Thank You to raul For This Useful Post:
sato (03-31-2014), Sportsguy83 (03-31-2014)
21 months no dyno, 22 months no vendor dyno, 22months4rattles&leakssmh, amazing warped qualiy, y u no tag
Nameless Performance BRZ Axleback Exhaust ESBjiujitsu Engine, Exhaust, Transmission 1377 04-21-2020 02:23 AM
Nameless Performance Axleback is available for pre-order. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 114 07-23-2012 10:38 PM
Nameless Performance Downpipe is available for pre-order. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 4 07-12-2012 04:57 PM
We are Nameless Performance. John@Nameless Announcements, Contests, Giveaways 22 06-18-2012 11:32 PM
Nameless Performance is here. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 16 06-06-2012 04:32 AM
