Old 03-28-2014, 03:44 AM   #71
gonzo
Drives: frs
Originally Posted by Marusich View Post
Overrun enrich delta is a time period after you're off throttle in ms, not rpm.
My intuition is telling me it's measured in delta rpms. That's why it's active when set to a negative number as Grip Ronin says.
gonzo is offline   Reply With Quote
Old 03-28-2014, 06:06 AM   #72
gonzo
Drives: frs
I don't have access to romraider, so I can't look at the full name of those overrun parameters, but if we can increase pulse width during overrun, then the extra fuel should cause the popping sound right when you let off the pedal while in neutral or gear (and cause the overrun condition). You may have to retard timing a bit in the lower loads, but not nearly as much as you did.
Disclaimer: dunno if this works and I'm not responsible for fucked up cars. I'll try it on my own car this weekend
Old 03-28-2014, 06:46 AM   #73
Marusich
Marusich's Avatar
I could totally be wrong, let me know how it goes.
Marusich is offline   Reply With Quote
Old 03-28-2014, 07:12 AM   #74
Migero86
Migero86's Avatar
Drives: 2015 Trailhawk
Unfortunately, I am going to be removing this from my tune... my car really stinks with this enabled which I assume it would since we are dumping some fuel into the exhaust. Anyone experience that?
I tried it, it was cool, but the stench of fuel in stop and go traffic is a no-go for me. Maybe we can find a different way to do this without the smell.
Migero86 is offline   Reply With Quote
Old 03-28-2014, 08:20 AM   #75
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
i removed the overrun too. i makes the car buck when slightly tipping into the throttle thanks to heavy fueling/ low timing swinging to high timing light fueling.. i just added a bit of fuel in the open loop map at low load and smoothed out the advance transition
IG-Joey_Soul
Progress Thread Ported billet 20G
Grip Ronin is offline   Reply With Quote
Old 03-28-2014, 09:37 AM   #76
ML
ML's Avatar
Drives: 13 White MT FR-S
My unichip does this to my car. After getting on the engine, and then starting to ease off sometimes when I push in the clutch it will pop pretty loud. I'm thinking about ditching it though and just getting a T-cable.
Old 03-28-2014, 03:43 PM   #77
gonzo
Drives: frs
How did you add fuel? Lowering the AFR? How many columns from the left did you modify in the timing map?
Old 03-28-2014, 05:23 PM   #78
gonzo
Drives: frs
I changed only my timing to -5 in the lowest load and made the column .06. I'm not getting any loud popping. Could it be because I have the header cat and a high flow cat? Has anyone with two cats tried this?
Edit: changed the column load number back to stock since it wasn't as loud after lowering it to .06
The Following User Says Thank You to gonzo For This Useful Post:
carlitosway6891 (03-30-2014)
Old 03-28-2014, 08:34 PM   #79
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Edit: nevermind it's there! Just quiet and muffled. I also have e85 so that likely tones it down.
you cant take it to .06 because it switches to closed loop maps at that point which is a different fuel and ignition table. we cant control the closed loop timing yet so we cant do fully off throttle burbling. leave it at .15 and it will pop at very light throttle, while still deceling (thats not a word lol).i added fuel on the regular fuel table just the first column but it makes the car a bit jumpy on transition so ill be removing it
IG-Joey_Soul
The Following User Says Thank You to Grip Ronin For This Useful Post:
gonzo (03-28-2014)
Old 03-28-2014, 08:40 PM   #80
gonzo
Drives: frs
Thanks a lot. How about retarding timing in the "base timing idle (in gear)(above speed threshold)"? Does the ecu use this timing table as soon as you let off the throttle? Is that what "idle mode" is?
Old 03-28-2014, 11:08 PM   #81
Grip Ronin
The Mechanic
Grip Ronin's Avatar
im not really sure what that does because the ecu doesnt know what gear a manual trans is in. maybe a automatic feature? i adjust ignition base (normal).the first time you flash the car will be on the safe mode map until operating tempature
IG-Joey_Soul
gonzo (03-30-2014)
Old 03-30-2014, 02:25 PM   #82
Proof
Proof's Avatar
Drives: 2007 STI Limited / 2014 BRZ Limited
[ame="http://vimeo.com/90468186"]Nameless over pipe/front pipe combo with 3" alxeback on Vimeo[/ame]
Proof is offline   Reply With Quote
The Following 2 Users Say Thank You to Proof For This Useful Post:
chaoskaze (01-13-2015), gonzo (03-30-2014)
Old 03-30-2014, 11:57 PM   #83
gonzo
Drives: frs
Originally Posted by bee_are_zee View Post
The next tuning adventure should be to find out if we can get ghost cams at idle...
After looking up what this sounds like...
YES
FRS with ghost cams at idle
Old 03-31-2014, 11:26 AM   #84
bee_are_zee
bee_are_zee's Avatar
Drives: GBS BRZ
I had some success messing with cam overlap at idle. But for some reason I had to give just barely some input on the pedal before the timing would shift. When the car is at idle does it pull from a different timing map?
bee_are_zee is offline   Reply With Quote
The Following User Says Thank You to bee_are_zee For This Useful Post:
gonzo (04-04-2014)
rom tuning for pops and backfires andrew5826 Software Tuning 110 12-23-2016 04:39 AM
First romraider defs are up jamesm Software Tuning 95 01-13-2015 05:29 AM
Transient Ignition Retard Tables from RomRaider Ralph Spoilsport Issues | Warranty | Recalls / TSB 31 05-24-2014 07:48 AM
OFT-Help with Romraider/FFS and Launch Control-issues continuecrushing Software Tuning 9 04-17-2014 11:07 PM
Possible backfires Bg8780 Engine, Exhaust, Transmission 0 05-22-2013 02:12 PM
