MisterSheep
Old 03-27-2014, 08:57 PM   #57
mr. slim
SoCal86
mr. slim's Avatar
Drives: '13 Whiteout FR-S
Originally Posted by shif7i7down View Post
The file it self is just the ots map with the added adjustment which takes roughly 1minute to implement. But if you must have it., PM me your email and the ots map that youre currently using, I can send you a moded version.
With that said, I however can not be held responsible for anything that could or may happen to you and or your vehicle by using any files that i send you
Haha!
I'll trying messing with the stage 2 UEL tune and well see what's up.
.: SUPER KAWAII :.
.: BUBSQUAD :.
.: LivinLow :.
.: FRS86 :.
mr. slim is offline   Reply With Quote
Old 03-27-2014, 09:01 PM   #58
Walla Walla
Hicas Thread Basher
Drives: Subaru BRZ 13, Hyundai Genesis 15
thanks for all the help about romraider.. I just understood that it needs Java 32bits
I'm installing it right now and it should work now!
Walla Walla is offline   Reply With Quote
Old 03-27-2014, 09:32 PM   #59
Walla Walla
Hicas Thread Basher
finally still unable to install..!
Old 03-27-2014, 10:22 PM   #60
Marusich
Marusich's Avatar
Originally Posted by gonzo View Post
What did you put the overrun RPM delta at? did you change any other overrun parameters?
overrun RPM delta to 6000ms and what I stated before was all i changed.
Marusich is offline   Reply With Quote
The Following User Says Thank You to Marusich For This Useful Post:
gonzo (03-28-2014)
Old 03-27-2014, 10:28 PM   #61
Marusich
Marusich's Avatar
Have you tried setting the overrun enrich rpm delta activation lower to say, 4k? That should allow for the popping at a lower rpm rev, right?
Overrun enrich delta is a time period after you're off throttle in ms, not rpm.
gonzo (03-28-2014)
Old 03-27-2014, 10:33 PM   #62
Walla Walla
Hicas Thread Basher
i'm about to try it now (finally was able to install it)
just want to make sure, is it normal that it says a error message first when you open file (error about checksum) and then when you upload it to OFT it says Checksum corrected?
Old 03-27-2014, 10:37 PM   #63
AdrianG
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
Yup.
- AdrianG
AdrianG is offline   Reply With Quote
Old 03-27-2014, 10:52 PM   #64
NorCal_Guy
It's turbo time!
NorCal_Guy's Avatar
Drives: 2013 Scion FRS
Originally Posted by andrew5826 View Post
did some testing and changes to achieve a noisier exhaust. no damage to anything so far and barely any changes in gas mileage(.1 L/100km).
with just ignition base timing A modified, no pops produced. ignition base timing B produced some pops, but not as aggressive. i ended changing both ignition base timing maps A and B to -10* timing in the lowest load column(.15g/rev) for the most aggressiveness. with the lowest load at negative timing, it kind of made the throttle an on/off switch for the pops. you wouldn't reach that engine load when normally driving or when decelerating. but if you gave it the slightest bit of throttle to that sweet spot, it would spit pops and become obnoxious. but everyone loves it. changing the full decel engine load value to negative timing doesn't produce pops for some reason. but its better to not have pops at full decel because you don't want to constantly become a pack of firecrackers when coming to a stop.
after messing with the ignition maps, i started looking into fueling. with the overrun enrich rpm delta activation set to 6000, the pops were alot more aggressive and rally sounding, as opposed to before where it sounded like you were running over a bunch of pop cans.
trying to achieve flames but i think this is as far as im going. i don't want to break stuff
will get some driving videos up. just need a exterior camera mounting solution
bored @ a railroad crossing under a roof
Sorry but I think it sounds like a shit can
NorCal_Guy is offline   Reply With Quote
Old 03-28-2014, 12:00 AM   #65
Marusich
Marusich's Avatar
Can't say I've ever heard a can of shit make noise like that, but I'll take your word for it.
I'll try to get some clips of mine with my adjustments, it's subtle.
The Following 2 Users Say Thank You to Marusich For This Useful Post:
gonzo (03-28-2014), NorCal_Guy (03-28-2014)
Old 03-28-2014, 12:06 AM   #66
NorCal_Guy
It's turbo time!
NorCal_Guy's Avatar
Sorry for my choice of words lol
Old 03-28-2014, 12:09 AM   #67
shif7i7down
Erected Member
Drives: frs
because racecar??
shif7i7down is offline   Reply With Quote
Old 03-28-2014, 12:45 AM   #68
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
enrich delta is oem on wrxs at -17. a positive number makes in inactive i believe. when its on engine braking is much harder.
IG-Joey_Soul
Progress Thread Ported billet 20G
Grip Ronin is offline   Reply With Quote
The Following User Says Thank You to Grip Ronin For This Useful Post:
gonzo (03-28-2014)
Old 03-28-2014, 04:30 AM   #69
gonzo
Drives: frs
I'm hoping it sounds better in real life. Plus, messing with my file and changing stuff like this is fun.
I love tinkering with shit, even shit cans.
gonzo is offline   Reply With Quote
Old 03-28-2014, 04:40 AM   #70
gonzo
Drives: frs
That makes sense if it is measured in rpms and not ms. It's related to how often the fuel injectors are going into overrun mode as the engine drops in rpms.
rom tuning for pops and backfires andrew5826 Software Tuning 110 12-23-2016 05:39 AM
First romraider defs are up jamesm Software Tuning 95 01-13-2015 06:29 AM
Transient Ignition Retard Tables from RomRaider Ralph Spoilsport Issues | Warranty | Recalls / TSB 31 05-24-2014 08:48 AM
OFT-Help with Romraider/FFS and Launch Control-issues continuecrushing Software Tuning 9 04-18-2014 12:07 AM
Possible backfires Bg8780 Engine, Exhaust, Transmission 0 05-22-2013 03:12 PM
