Old 03-27-2014, 10:55 PM   #1
mike the snake
Turbo coolant lines GTX2867. Can I use the throttle body coolant lines?
Has anyone had any issues with the turbo not getting enough coolant on their GTX2867?
Mine was leaking oil, and after sending it off, it was determined that none, or not enough coolant got to the turbo and damaged it.
Everything was installed as per the instructions, including the oil restrictor.
Coolant lines were installed and run as per the instructions.
It's baffling me how the turbo could not be getting enough coolant.
Could an air bubble get trapped and block the coolant line?
I read about someone using the coolant lines that go to the throttle body. Is this OK to do?
If it is, I'm tempted to switch to the throttle body coolant lines just to eliminate the possibility that the other lines aren't working properly.
Thanks for any help,
Mike
Old 03-27-2014, 11:55 PM   #2
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Yes, use the throttle body lines. I use them in my kit and its what the AVO kit instructs to use.
Old 03-28-2014, 12:05 AM   #3
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
I dont know what lines you are using but fbm instructions are to use the throttle body coolant lines. They supply fitting that T into the TB lines. I personally didnt use them and essentially put the turbo in the coolant system where my TB used to be.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Old 03-28-2014, 10:43 AM   #4
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
This. I ran mine with the FBM fitting for a month or two, but when I pulled my intake manifold I decided to simplify my coolant for the turbo by removing the throttle body cooling completely and using the coolant for the turbo only. I don't see how they could tell how much coolant was getting to the turbo just by looking at it.
Old 03-28-2014, 11:00 AM   #5
mrk1
Drives: Sterling BRZ Ltd
An air bubble could have been trapped but usually that would work itself out after a little bit. Certainly not long enough to do damage I would think. On my setup I run the coolant lines from the TB supply lines. I didn't use Tees though just cut the TB out of the circuit all together.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 03-28-2014, 11:04 AM   #6
kingkai23
Drives: 13 swp limited
Will there be any issues not running coolant to tb ?
kingkai23 is offline   Reply With Quote
Old 03-28-2014, 12:00 PM   #7
mrk1
I've done it on numerous cars and never had a problem. Maybe if you live in a super cold climate. I also don't drive my car in the winter.
The Build Thread
Old 03-28-2014, 02:19 PM   #8
mid_life_crisis
Drives: FR-S 10 #103 AT
The liquid is not there to cool the TB. It's bringing engine heat to it for cold weather driving. Kind of like how old cars had a duct that funneled hot air up to the intake during the winter.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 04-01-2014, 05:56 PM   #9
mike the snake
On my way to pick up my car.
The company was nice enough to repair the turbo under warranty.
The report stated lack of, or no coolant flow.
The shop eliminated the coolant lines to the throttle body and ran those coolant lines directly to the turbo and reported improved coolant flow to the turbo.
I'm hoping this solves the issues that caused the original turbo to spring an oil leak!
Coolant, Anyone tried this?? stevo_12v Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 11 04-27-2016 04:50 PM
low coolant BRZPDX Northwest 17 06-06-2015 01:42 PM
is my coolant low? chenshuo Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 12-19-2013 11:43 PM
Where did my coolant go? ZionsWrath Scion FR-S / Toyota 86 GT86 General Forum 1 11-02-2013 11:46 AM
Low Coolant Tt3Sheppard Issues | Warranty | Recalls / TSB 12 11-25-2012 12:03 PM
