| DIY (Do-It-Yourself) Guides For all DIYs. |
#29 |
Drives: Pegasus GTS86
So decided to get stuck in and do a swap of my injectors for some ID850's. I didn't find this guide until after the fact unfortunately. Now I'm nervous that I didn't do it correctly.
These are the injectors and as you can see they are very different from the OEM ones. Everything indicates that they are correct though. I wonder what impact there will be with the injector now that it isn't as long. The worry I have is that I installed the injectors as they are shown, there are like two seals on the bottom. I removed the oem injectors also as they are shown. Was I supposed to remove a gasket or something from the head that should have been on the old injector? When I fitted the fuel rail it sat up approx 3mm I guess. I just bolted it down and it fit snuggly. I figured that this was just to ensure a tight seal. Now I'm not so sure. Can anyone advise? Btw. The car starts/idles and runs fine. Cheers. [IMG] [/IMG]
| The Following User Says Thank You to Bigmaxy For This Useful Post: | GhostOp86 (08-13-2015) |
#30 | |
Drives: vrooom...
#31 |
Love Boost!!!!!!!!
Drives: Whiteout Scion FR-S
u will need spacers and longer bolts too... ID injectors are taller than OEM
#32 |
Drives: TIE interceptor; BRZ13
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." Jeremy Clarkson
#33 |
Nope. Looks like I'm pulling the injectors out again this afternoon. :-)
At least everything is easier the second time around. Also, thanks for the link to Dezoris's guide. Would have made some of the process easier. |
#34 |
Drives: WRB Limited BRZ
Is there an official DIY for this, I don't plan on doing this yet but knowing where I can reference back to would help
![]() I know I can read off what @ecko04 said, but I'm a lot more of a visual person. I been Googling and searching around the forums and I haven't seen a video or a DIY thread about this. Did I miss anything? |
#35 | |
Drives: 2015 FR-S Release Series 1.0
#36 |
#37 |
Are there any consumables that I should purchase before installing DW injectors?
#38 |
Drives: 2014 BRZ
Can someone that has swapped taller injectors like IDs please help me understand what exactly I am going to be spacing? A spacer will seat between the intake manifold and the rubber gasket on the injector tip? Or am I supposed to use a spacer and longer bolt to space the fuel rail to sit higher?
JDL Auto Design///Turboback///Enkei///Tial///RSR///HRI Tuned
| Injectors installation | kaybee123 | Forced Induction | 27 | 03-08-2016 10:26 PM |
| So what exactly will aftermarket feul injectors do to my frs | Frsexxxy | Engine, Exhaust, Transmission | 8 | 03-10-2013 01:28 PM |
| Deatschwerks BRZ/FR-S Fuel Injectors! | RallySport Direct | Engine, Exhaust, Bolt-Ons | 2 | 09-07-2012 07:29 PM |
