| DIY (Do-It-Yourself) Guides For all DIYs. |
Love Boost!!!!!!!!
Drives: Whiteout Scion FR-S
DIY Request- Port Injectors
Thanks
Sent from the moon
Well follow the DIY for pulling the fuses for fuel pump. Then try and start vehicle to get pressure out. Make sure engine is cold. Or carbecue could happen. Remove the big bulky steel covers the passenger side is the hardest one. I removed the upper brace on the driver side to make room. You should see the fuel rails at this point there are 2 12mm socket head bolts per side.
Also dezoris in his direct injector vid should really be of some help. I would have a magnet on a stick ready. I dropped a few bolts when I did mine. Dont over tight dosent take much torque to strip out the aluminum threads in the head
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
NASA SpecE30 Racer
Are you actually going to DIY it? It really isn't too difficult. I prefered disconnecting the fuel lines during my install of the injectors. It is basically just removing the covers and then unbolting the fuel rails.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#4 | |
Love Boost!!!!!!!!
Its time for me to start working on my own shit Thats how i found out about the fuel pump Sent from the moon
#5 | |
well if you are on the moon take a spin in the lunar roving vehicle.
#6 | |
Love Boost!!!!!!!!
Sent from the moon
#7 | |
I lolled that thing is slow as balls but gets hella airtime
Love Boost!!!!!!!!
Full blown kit on it and that shit will flyyy
Sent from the moon
did you get your injectors done
#10 | ||
Love Boost!!!!!!!!
Car didnt start the first time, i figure there was no pressure. It did the second time but rpm goes up and down like fast 1-2k and got Code p062D could i have done something wrong?
#11 |
Well what size injectors did you have installed when you received your tune.
#12 |
NASA SpecE30 Racer
Did you flash your ECU with a ROM for the twice as large injectors?
- King Tut
#13 | |
Love Boost!!!!!!!!
I dont know wtf is wrong dude Car stalls and Blinking Cel Sent from my iPhone using Tapatalk - now Free
#14 |
NASA SpecE30 Racer
I would guess that your tuner doesn't have the settings correct for the injectors then. What is your AFR at idle? How do your short term fuel trims look at idle? Did you make sure the injectors are seated well and there are no leaks? Did you use the same fuel rail spacers as the Full Blown 550cc injectors?
- King Tut
| Injectors installation | kaybee123 | Forced Induction | 27 | 03-08-2016 09:26 PM |
| So what exactly will aftermarket feul injectors do to my frs | Frsexxxy | Engine, Exhaust, Transmission | 8 | 03-10-2013 12:28 PM |
| Deatschwerks BRZ/FR-S Fuel Injectors! | RallySport Direct | Engine, Exhaust, Bolt-Ons | 2 | 09-07-2012 06:29 PM |
