Old 03-27-2014, 05:18 AM   #29
Bigmaxy
Drives: Pegasus GTS86
So decided to get stuck in and do a swap of my injectors for some ID850's. I didn't find this guide until after the fact unfortunately. Now I'm nervous that I didn't do it correctly.
These are the injectors and as you can see they are very different from the OEM ones. Everything indicates that they are correct though. I wonder what impact there will be with the injector now that it isn't as long.
The worry I have is that I installed the injectors as they are shown, there are like two seals on the bottom. I removed the oem injectors also as they are shown.
Was I supposed to remove a gasket or something from the head that should have been on the old injector?
When I fitted the fuel rail it sat up approx 3mm I guess. I just bolted it down and it fit snuggly. I figured that this was just to ensure a tight seal. Now I'm not so sure.
Can anyone advise?
Btw. The car starts/idles and runs fine.
Cheers.
[IMG][/IMG]
Bigmaxy is offline   Reply With Quote
Old 03-27-2014, 07:21 AM   #30
M1K3
M1K3's Avatar
Drives: vrooom...
Can anyone advise?
Did you remove the original o-rings from the Intake Manifold?
M1K3 is offline   Reply With Quote
Old 03-27-2014, 08:35 AM   #31
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
u will need spacers and longer bolts too... ID injectors are taller than OEM
Old 03-27-2014, 09:12 AM   #32
TIE Pilot
TIE Pilot's Avatar
Drives: TIE interceptor; BRZ13
Might as well:
Originally Posted by Dezoris View Post
3:15-15:20 Removal of Intake Manifold and Port Injectors...
http://www.ft86club.com/forums/showthread.php?t=42849
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." Jeremy Clarkson
TIE Pilot is offline   Reply With Quote
Old 03-27-2014, 06:15 PM   #33
Bigmaxy
Nope. Looks like I'm pulling the injectors out again this afternoon. :-)
At least everything is easier the second time around.
Also, thanks for the link to Dezoris's guide. Would have made some of the process easier.
Old 04-07-2016, 09:20 PM   #34
Alltezza
Alltezza's Avatar
Drives: WRB Limited BRZ
Is there an official DIY for this, I don't plan on doing this yet but knowing where I can reference back to would help
I know I can read off what @ecko04 said, but I'm a lot more of a visual person.
I been Googling and searching around the forums and I haven't seen a video or a DIY thread about this. Did I miss anything?
Alltezza is offline   Reply With Quote
Old 05-19-2016, 04:03 PM   #35
avishenoy1
avishenoy1's Avatar
Drives: 2015 FR-S Release Series 1.0
Here you go, copied right out of the factory service manual with step by step instructions and pictures.
File Type: pdf FA20 Fuel Injector Assembly (Port).pdf (241.3 KB, 397 views)
avishenoy1 is offline   Reply With Quote
Old 05-19-2016, 08:55 PM   #36
Alltezza
Alltezza's Avatar
I love you man.
Old 08-09-2016, 01:41 AM   #37
Aaronimoe
Are there any consumables that I should purchase before installing DW injectors?
Aaronimoe is offline   Reply With Quote
Old 08-22-2019, 11:20 PM   #38
Amputechture
Drives: 2014 BRZ
Can someone that has swapped taller injectors like IDs please help me understand what exactly I am going to be spacing? A spacer will seat between the intake manifold and the rubber gasket on the injector tip? Or am I supposed to use a spacer and longer bolt to space the fuel rail to sit higher?
JDL Auto Design///Turboback///Enkei///Tial///RSR///HRI Tuned
Amputechture is offline   Reply With Quote
Injectors installation kaybee123 Forced Induction 27 03-08-2016 09:26 PM
So what exactly will aftermarket feul injectors do to my frs Frsexxxy Engine, Exhaust, Transmission 8 03-10-2013 12:28 PM
Deatschwerks BRZ/FR-S Fuel Injectors! RallySport Direct Engine, Exhaust, Bolt-Ons 2 09-07-2012 06:29 PM
