Old 03-24-2014, 07:01 PM   #2255
tysoNgwaNg
awesome.
tysoNgwaNg's Avatar
Drives: 1994 Toyota Celica, 2014 Scion FRS
Tires on the front are 225/40 and rear are 265/35 ( rims are 18x9 and 18x10 +38 ) don't want to super slam it but want to lose the gap the most. Coilovers are Stance. Just want to make sure I won't have issues with rubbing or having it hit something.
tysoNgwaNg is offline   Reply With Quote
Old 03-26-2014, 02:04 AM   #2256
Asphalt TG
Captain Stabbin
Asphalt TG's Avatar
Drives: 2013 FRS Asphault
H/S Enkei Raijin 18x8.5/9.5 +45 w/ Springs?
Hey @Slick do you happen to know if HR Super Sport springs will work ok with my new setup? Will I need LCAs if drop is greater than +1in?
Also thinking about playing it safe with the Eibach pro-kit OR HR Sport Kit(slightly less drop than super sport)
Appreciate the input.
Originally Posted by Asphalt TG View Post
Good looks @Slick, ya I think I read every post on that thread lol here's the set up I went with..
Hankook Venus V12 235/40 255/35.
Asphalt TG is offline   Reply With Quote
Old 03-26-2014, 08:00 AM   #2257
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
As for lowering, you could go with the SuperSports, but you will be lower than stock by 1.2"F/1.4"R and you'll be around -1.7 to -1.9 camber due to the drop. You only need the LCA's if you want to add much more negative, or take some out.
If you want just a bit more camber, go with the $5 Subie crash bolts. You'll be around -2.2 to -2.4 with those on the H&R's.
Not sure how well the SS plays with the stock shocks, but I know the Eibach ProKits are great with them. Compare the spring rates to give you an idea.
Also, compare the lowering specs of each spring. With the Eibachs at only 1" lower, they are even from stock, but the H&R's will drop the back end a bit more. Depends if you like or dislike the "rake" or stance.
Slick is offline   Reply With Quote
The Following User Says Thank You to Slick For This Useful Post:
Asphalt TG (03-26-2014)
Old 03-26-2014, 08:06 AM   #2258
Slick
Slick's Avatar
See this thread, it's your scene:
http://www.ft86club.com/forums/showthread.php?t=25171
Old 03-26-2014, 06:33 PM   #2259
Asphalt TG
Captain Stabbin
Asphalt TG's Avatar
I haven't been able to find Any spring rates for HR sport or SS even HRusa site doesn't list them. Only the approx lowering height. I'm leaning towards the more conservative side tho with either HR sports or Eibach prokit. Good to know I shouldn't have Any issues with my setup. Going to try install myself with DIY provided on here, wish me luck. If you don't hear from me I'm in a ditch somewhere because my wheels fell off lol.
Old 03-26-2014, 07:13 PM   #2260
Slick
Slick's Avatar
Lol, install is straightforward, good luck!
Old 03-26-2014, 10:08 PM   #2261
PoWn3d_0704
PoWn3d_0704's Avatar
Drives: 1990 BNR32 GTR
Does anyone know of a company that sells 17x9 or 17x10 5x100 rims? I want like 265-275 rear and 235 fronts that are totally flush with a 1" drop. I want 17" rims because I have a Wilwood big brake kit that is designed to fit under the OEM rim.
I am on stock suspension and will be for a bit, but I am going to buy Ohlins sooner or later. Also going to TC and will actually need the rubber at some point. Are staggered set ups stupid? I've never actually bought aftermarket rims.
Thinking 17x8 +35ish for the front and 17x9 +40ish for the rear. 17x10's would be cool though if they can be flush and not rub. (Doesnt look like anyone has done that though.)
I'm having trouble finding rims like that with a 5x100 offset. I've pretty much just found the Rota Titans. I really rather have the spokes be all evenly placed.
Picked up my BRZ on 6/11/13.
Build Album:
PoWn3d's BRZ Pictures
Build Thread: PoWn3d's BRZ
PoWn3d_0704 is offline   Reply With Quote
Old 03-27-2014, 10:33 AM   #2262
Slick
Slick's Avatar
Lots of 17x9 choices, quite popular for these cars, can fit 17x9 square. 17x10 is not as common but would fit in the rear with a proper offset.
http://www.ft86club.com/forums/showthread.php?t=7535
Old 03-27-2014, 11:38 AM   #2263
tiz22
tiz22's Avatar
Drives: 2013 Scion FR-S (Raven) MT
Hoping some of the experts can weigh in here...
I have finally decided on a wheel I like (TSW Interlagos - matte black), but can't decide whether to go 17" or 18"...So many things to consider..
I'll start by giving my end goal:
- Mostly DD...plans to track it in a year or so which is when I will add a 1" drop via coilovers
- Handling/performance is important but I also want it to look good and get decent mileage
- Ride comfort is also a consideration...Stock ride is about as rough as I would want it
- If I go 17"...I would most likely want to use the stock Primacy HP tires until they wear out (might as well?)
- If I go 18"...I would want minimal speedo difference
- Would like as close to flush as possible
- Don't want staggered setup...Want to be able to rotate tires
- Most likely adding a BBK at some point
Right now I'm leaning towards an 18x8 +35 setup with 225/40/18 tires because through my research it looks like that is the best compromise for DD/performance/looks but I'm just not convinced...Would love as much feedback/opinions as possible...The more the better!
My Car Journal: Raven FR-S w/ TRD Flavour
Click for my AVIC Z150BH Head Unit DIY Install
tiz22 is offline   Reply With Quote
The Following User Says Thank You to tiz22 For This Useful Post:
sirisvirus (03-27-2014)
Old 03-27-2014, 12:25 PM   #2264
86viper
Drives: 2013 Toyota 86 GTS
Hi Guys
Simple Question :P
Will this fit with no rubbing lowered on
Tein S. Tech Springs (approx drop 1.4" Front, 1" Rear) (i already have these)
Or Does it Requires coilovers with more adjustment?
No Other Suspension Mods
Work Emotion XD9's
18x9+38 with 225/40 Front
18x10+38 with 245/35 Rear
I am ok with an aggressive fitment as long as it doesn't rub.
Cheers!
86viper is offline   Reply With Quote
Old 03-27-2014, 02:24 PM   #2265
hakkoo
Hello,
I was wondering if this would fit.
17x9 42, rota Titans, wrapped in 255/40/17 Conti DW
on ST Coils, with a minor drop 1"
I ordered LCA's with it but they are on back order and would like to know if these would fit fine w/o them for now
Thanks!
hakkoo is offline   Reply With Quote
Old 03-27-2014, 02:39 PM   #2266
jshadeck
jshadeck's Avatar
17/18 makes no difference to speedo, the tire size compensates.
17 will have more sidewall, so, likely a better ride quality.
18s will help clear a bbk, depending what bbk you get.
jshadeck is offline   Reply With Quote
Old 03-27-2014, 04:22 PM   #2267
tiz22
tiz22's Avatar
I'm thinking of the Brembo BBK down the line...Will that fit in a 17" wheel?
If I go with 18"s and find the ride quality more rough...Are there any suspension upgrades I can do to improve it? I've heard so many different opinions on coilovers
Old 03-27-2014, 04:31 PM   #2268
mid_life_crisis
Drives: FR-S 10 #103 AT
I know this will fit, the question is the best offset to make it work.
17x8 rims with 235/40 tires. Ultimately the car will be dropped about an inch.
The target is to have the tires sit safely inside the fenders but still close enough to look better than from the factory.
If you want to have the same offset rim on all four corners to simplify everything, what offset do you need and what size spacer do you get for the rears so they all sit the same distance from the fenders?
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
