Old 03-21-2014, 04:45 AM   #29
midnight23
dying bird under the hood
Drives: 2013 SWP Limited BRZ
Any reason for no head work?
Build Thread
Instagram
Old 03-21-2014, 07:59 AM   #30
Mathewgzlz
Mathewgzlz's Avatar
Drives: 2013 SCION FR-S FIRESTORM RED
Nice to see big boy numbers
Mathewgzlz is offline   Reply With Quote
Old 03-21-2014, 09:08 AM   #31
Boss Paco
Subaru Certified Sales
Boss Paco's Avatar
Drives: '13 BRZ Premium, '05 WRX STi
Yup. This car is a beast but I'm sad that 2K got rained out. Woulda loved to see this car run.
[Subaru WRX STi] Benson Block - Kelford Cams - PTE6466 - ID2000s - AEM - E85
[Subaru BRZ] Speed by Design Turbo Kit - Invidia N1 - BC Racing BR Coilovers - Rota RT5s
[Subaru WRX] Prodrive - Subaru Tecnica International - APS - Tein - Rota Titans
"The only thing that I trust in this world is cars!" - Don 'The Goods' Ready
Boss Paco is offline   Reply With Quote
The Following User Says Thank You to Boss Paco For This Useful Post:
JK21 (03-22-2014)
Old 03-21-2014, 10:09 AM   #32
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Nice drums bro.
Old 03-21-2014, 10:59 AM   #33
Deadspool
Much title. Wow.
Deadspool's Avatar
Drives: 2013 BRZ Sport-Tech
What are your plans for the transmission? I suspect axles will be high on the to do list too, with tons of traction, lowered and more than enough torque.
You're just about in the grenade zone from what I see in other high power builds.
༼ つ ◕_◕ ༽つI PUT A SPELL ON YOU ༼ つ ◕_◕ ༽つ
Deadspool is offline   Reply With Quote
Old 03-22-2014, 03:04 AM   #34
JK21
Oh yeah. The heads were port and polished. i forgot to mention that
It would've been nice. But next year it will be drag ready. It is just setup for good rolls right now since the drivetrain is stock.
Nice drums bro.
They will be replaced soon. But I have drums in the rear to allow more for tire plus braking bias is more towards the front.
This true. Axels, 8.8 diff, and reinforced gears. The BC coils work well for this setup. I will not launch the car nor put it on the strip until the other components are done. Until then roll races and cruising.
JK21 is offline   Reply With Quote
The Following User Says Thank You to JK21 For This Useful Post:
midnight23 (03-24-2014)
Old 03-22-2014, 03:17 AM   #35
Ec1990
Drives: '14 BRZ
Nice drums bro.
Drum brakes with calipers. Must be new.
Ec1990 is offline   Reply With Quote
Old 03-24-2014, 02:25 AM   #36
JK21
Nice drums bro.
The front brakes are slotted…..not drums. The REAR brakes are drums. I mentioned that in the first post. Wilwood fronts and stock drums in the rear. Try reading
Conundrum (03-24-2014)
Old 03-24-2014, 04:02 AM   #37
Knshro13
Drives: 10 series FRS
That...is definitely not a trd kit..
Knshro13 is offline   Reply With Quote
Old 03-24-2014, 04:12 AM   #38
AZFA20
Automotive Connoisseur
AZFA20's Avatar
Drives: too many cars
Gotta love rear drum conversions and that 5axis bought out TRD
Don't get angry, just given ya a hard time. Nice numbers!
LSx Powered 86/ASE Master Certified Automotive Technician
AZFA20 is offline   Reply With Quote
Old 03-24-2014, 05:05 AM   #39
AirborneDeth
Regular Guy
AirborneDeth's Avatar
Drives: '13 FRS '97 Jeep Cherokee
Great numbers.
Unless you swapped out your stock REAR disc brakes and replaced them with a drum set up after you took pictures, which would be epically dumb with these numbers, you most certainly have rear disc brakes.
AirborneDeth is offline   Reply With Quote
The Following 2 Users Say Thank You to AirborneDeth For This Useful Post:
JK21 (03-31-2014), UltraMarine86 (03-24-2014)
Old 03-24-2014, 10:15 AM   #40
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Built not bought bro.
Old 03-24-2014, 11:16 AM   #41
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by JK21 View Post
Also the power I made were on my baby injectors and not even my original injectors (2200s). For time sake we tuned on straight e85 and 1300s. The car has plenty left in it but an issue in the software is not letting us go higher than 36 PSI absolute boost or 22 pounds. The fuel constantly wants to lean out.
What fuel pump or system do you have?
I have encountered that issue but at 15 psi on Dw65c pump.
Look above @jamesm
Old 08-11-2014, 05:04 PM   #42
Black86
Black86's Avatar
Drives: 2013 Raven Black FR-S
Car looks awesome I love the build! Is there a upgraded build for our transmissions? I see the v160 is an option but that sounds pretty pricey..I'd like to build mine and go for 800whp with a 6466 setup. I'm sure 600 in the frs is pretty fast lol I want to take something to the Texas 2k event.
-Raven Black 13 FR-S : The daily driver
-88 supra turbo : 2jz 66mm single on E85 in the process
Black86 is offline   Reply With Quote
First Vinyl Wrap completed, AMA! Ironsquid Cosmetic Modification (Interior/Exterior/Lighting) 121 11-24-2015 07:07 PM
Completed!! FBM 700+HP Build Dyno graph & Vid inside FullBlown Forced Induction 214 03-31-2014 01:56 PM
Vinyl wrap completed!! laley81 Southern California 14 08-30-2013 11:10 PM
Nearly Completed my Firstorm Build - Lots of Pics msile Member's Car Journals 52 03-10-2013 10:25 AM
Turbo FRS completed! Philly CANADA 24 09-03-2012 09:18 AM
