| View Poll Results: Which spring rates? | |||
| 8kg 8kg FR |
17 | 53.13% |
| 9kg 9kg FR |
4 | 12.50% |
| 10kg 10kg FR |
4 | 12.50% |
| 10kg 11kg FR |
1 | 3.13% |
| 10kg 12kg FR |
6 | 18.75% |
| Voters: 32. You may not vote on this poll | |||
Drives: 04 Toyota Tacoma Prerunner Reg Cab
Help me choose custom spring rates for coilovers
I've decided to get the Fortune Auto 510 when I have saved up enough money. Simple post...just need to narrow down what spring rates to get.
Mods - Planning on mostly a stock car with just these few mods... 9" wide wheels, 245-255 street tires (going to try D2, PSS, RS3, RE11 and maybe others), upgraded brake pads and fluid, maybe a 4.56 or 4.88 FD and catted headers more in the future and that's pretty much it..and of course, coilovers. Stock aero. Pretty much a super simple, no-fuss, NA low power, stock car. Use - DD on the weekdays in SoCal (but, I do not care about "comfort" one bit and I am very very tolerant driving around on a "racecar" stiffness around town. Mostly trackdays for fun, 2-3 times a month, at Button Willow and Willow Springs (maybe others further away or out of state on special occasions); so, a moderate amount of track time. AutoX and drift events here and there for fun but seldom, whenever interesting ones come about. I want it Firm and hard like rottweiler. Fuck comfort and a cushy caddy ride. |
#2 |
Firm doesn't mean fast. Look to some of the vendors with your needs and they will point you in the right direction
#3 |
What does Fortune recommend?
- Andy |
#4 |
Drives: 2013 Scion FRS
Maybe not relevant since you are going with 510s, but I just ordered a set of 500s from ft86SpeedFactory. They recommended 7k/6k F/R based on my need for best comfort for DD with predictable oversteer. Jeremy said they had luck running a bit lower in the rear to balance the car out. I trust there judgment and experience with Fortune Auto. I'll report back when they arrive and I get them installed. BTW I went with the Swift upgrade and roller bearings.
| The Following User Says Thank You to MyEvilMonkeys For This Useful Post: | fooddude (03-20-2014) |
#5 |
Dismember
Drives: 2013 Red Scion FR-S
If you want firm, go firm. I think you can then lose the rear sway bar and won't need to worry so much about correcting geometry when lowered. Look into it. I think that's what CSG does.
| The Following User Says Thank You to EAGLE5 For This Useful Post: | fooddude (03-20-2014) |
#6 |
This, going way too stiff on the spring rates will make it horrible if the dampers aren't valved for it. Forget stiff, you'll have bouncy.
#7 |
#8 | |
#9 | |
![]() Yes, I heard the same from Feal regarding a lower rate in the rear - more power to the ground, more turn in and accel grip, etc. |
#10 | |
Seriously though, just run what FA recommends. I have my own reservations on FA simply due to driving multiple platforms with the 500s and 510s. |
#11 |
#12 |
Drives: 1997 Eagle Talon TSi AWD
All my customers with FA LOVE including many people here. I wrote in your last thread why they're IMO one of the best, even up against more expensive competitors.
As for spring rates, I'm more concerned with your choice on the 510. The 510 is truly track-only or very limited daily driving. The valving is quite aggressive and if you're leaning more towards daily, 500 would be a better choice with Radial Bearing's added. This car needs an offset spring rate, and FA recommends 7/6 but for people looking for some a bit more aggressive, I've been doing 9/8. Our DSG-Edition FA500's are 9k/9k for the EvoX and it's plenty solid. FYI -- we still have a few spots left for our DSG edition FA's, they can be made for the FRS/BRZ. |
#13 |
We worked hard with Fortune to create something between the 500 and 510. A daily driver 510 basically with elements of the Dreadnoughts. This is the EvoX edition but all the info is here:
http://www.dsgperformance.com/DSG-Ed...hi-Evolution-X |
#14 |
| Spring Rates - Track / Autocross | Dave-ROR | Tracking / Autocross / HPDE / Drifting | 83 | 05-16-2023 04:56 PM |
| Coilover spring rates for comfort | Barbecue | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 35 | 12-12-2013 11:09 PM |
| For Sale: Fortune Auto Coilovers, Custom Spring Rates | stoneman155 | Brakes, Suspension, Chassis | 10 | 08-06-2013 08:23 PM |
| Spring rates for Super charged FRS | jdzumwalt | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 7 | 04-21-2013 09:32 PM |
| BC BR coilovers standard spring rates for toyota 86 | fiveoneone | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 12-19-2012 12:16 PM |
