Old 01-11-2014, 04:32 PM   #1
Dustin
Twin Screw You
Dustin's Avatar
Drives: 2013 Supercharged Whiteout FR-S
Steering wheel removal question.
I followed the DIY on here. Got the airbag removed. Removed the 17mm center nut. Steering wheel is still not coming off. Am I missing something? I'm pulling rather aggressively on the steering wheel to no avail.
Dustin is offline   Reply With Quote
Old 01-11-2014, 04:40 PM   #2
iketiak
iketiak's Avatar
Drives: 2013 Toyota 86/Scion FRS
Leave the nut threaded with enough space for the steering wheel to come out but not completely(prevents steering wheel from slapping you in the face), and pull forward left and then right to loosen the wheel. Slow but steady force to make sure you don't damage the splines.
iketiak is offline   Reply With Quote
The Following User Says Thank You to iketiak For This Useful Post:
Dustin (01-11-2014)
Old 01-11-2014, 05:13 PM   #3
Dustin
Twin Screw You
Dustin's Avatar
Thanks. Now on to problem number 2. How do I fix this eff up.
Not a great picture I know but the clock spring came unraveled. I've tried a number of different things so far and can't get the center on with the ribbon not being in the way.
Old 01-11-2014, 05:35 PM   #4
Dustin
Twin Screw You
Dustin's Avatar
Never mind. Just took a little trial and error to find the right rollers for the ribbon to come out of.
Old 01-11-2014, 05:36 PM   #5
HRTROB
HRTROB's Avatar
Drives: Toyota 86
I'm curious as to how you messed up your clock spring like that? I swapped out my steering wheel and it was fairly easy
HRTROB is offline   Reply With Quote
Old 01-13-2014, 12:07 PM   #6
Dustin
Twin Screw You
Dustin's Avatar
Not sure. The steering wheel did not come off simply for me. Took a bit of force to come off the steering column. When it did finally come off, the cover for that ribbon came off with it. The rest as they say is history.
Old 01-16-2014, 12:53 AM   #7
HapaHaole
Drives: Grocery cart
That is why you need to leave the nut on the steering shaft so you don't end up pulling it out. You will need to replace the clock spring at this point.
HapaHaole is offline   Reply With Quote
The Following User Says Thank You to HapaHaole For This Useful Post:
Dustin (01-16-2014)
Old 01-16-2014, 01:05 AM   #8
Dustin
Twin Screw You
Dustin's Avatar
Eh, we'll see.
Old 01-16-2014, 01:36 AM   #9
HapaHaole
According to the repair manual, it should turn 2.5 times in each direction when you have the clock spring set up correctly. Once you get the wires fixed and the housing attached you can look for a marking on the bottom of the unit.
Old 01-16-2014, 08:16 AM   #10
Dustin
Twin Screw You
Dustin's Avatar
I did that.
Old 03-19-2014, 08:26 PM   #11
Stealth Gt86
Stealth Gt86's Avatar
Drives: silver scion 10 series frs
anyone get an "ABS" and loss of traction light on? I put my sparco wheel on and then removed it to put the oem wheel back on, those 2 lights stay on. the airbag light goes away though...
2013 10 Series
2013 Raven FRS-sold
my old FRS boosted build http://www.ft86club.com/forums/showthread.php?t=31900
follow me on instagram- WeaponsFree86
Stealth Gt86 is offline   Reply With Quote
Old 03-20-2014, 08:13 AM   #12
AdamBomb518
Stealth ***e
AdamBomb518's Avatar
I haven't done mine yet but anytime you are unplugging airbag wires, I strongly recommend to disconnect the battery. Something about keeping the battery connected and disconnecting any airbag wires will trigger your ECU letting you know something is faulty.
You can probably just get them reset at the dealer though for no charge.
AdamBomb518 is offline   Reply With Quote
Old 03-20-2014, 08:26 AM   #13
sshole
Clockspring probably isn't centered. Try reinstalling the steering wheel taking special care to note position of clockspring is centered in relation to steering wheel center.
sshole is offline   Reply With Quote
Old 03-20-2014, 01:32 PM   #14
Stealth Gt86
I made sure the clock spring was centered. No difference
2013 10 Series
2013 Raven FRS-sold
Steering wheel accent removal Gixxer86 Cosmetic Modification (Interior/Exterior/Lighting) 8 11-27-2016 02:03 PM
scion frs steering wheel air bag and steering wheel Jhon19lopez Interior Parts (Incl. Lighting) 7 01-04-2014 06:04 PM
Swapping steering wheels with a new tC steering wheel. jonathan9573 Cosmetic Modification (Interior/Exterior/Lighting) 4 12-20-2013 11:45 PM
Steering Feel Question Concerning Tic Solid Steering Bushings brillo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 10-31-2013 04:52 PM
Steering wheel and air bag removal ZC6 (BRZ)/ ZN6 (86) andrewFT86 DIY (Do-It-Yourself) Guides 0 07-08-2013 12:41 AM
