| Northern California NorCal |
#15 | ||
Codename: Stitch
One driver mentioned he boiled his fluid by the first track day in this thread: http://www.ft86club.com/forums/showthread.php?t=60598 And in this thread, CSG Mike was asked what the top 10 mods were suggested for a car going to the track... his answer in part included what he thought was essential mods, which included brake pads and fluid upgrades: http://www.ft86club.com/forums/showthread.php?t=38926 Quote:
| The Following 7 Users Say Thank You to PMok For This Useful Post: | CSG Mike (03-16-2014), finch1750 (03-16-2014), kster1 (03-16-2014), MyRx (03-17-2014), strat61caster (03-18-2014), unsurety (06-07-2014), wilfredwong (03-16-2014) |
#16 |
#17 |
Drives: 13 FR-S
#18 |
We conveniently have a group buy going, if you want to try some hybrid/autox type pads. Alternatively, if you're comfortable swapping pads yourself, use race pads, and swap on your stock pads or street pads for daily driving.
| The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | MyRx (03-17-2014), wilfredwong (03-16-2014) |
#19 | |
Drives: Suburu BRZ Limited, black
For all the rest of the drivers who will be commuting, autocrossing, and with an "occasional" track day... No. I'd consider all ten best upgrades for a first time track day to be the driver, no contest. In fact, I would suggest that if you are experiencing brake fade, that's something you should learn to deal with on the track, hopefully not something you're going to learn when descending out of the Rocky Mountains, which is again a driver upgrade first. Here's my list for top 10 upgrades on the track: Learn,
After that, I'd do tire pressure, tires, (maybe brake fluid in here if it's failing), dampers, springs, brake pads, (again maybe fluid here). I'd be more worried that people new to the track can't even correctly identify what happens when your brake fluid boils. Brake "fade" is typically caused by your pads overheating and vaporizing against the rotor causing them to basically do the same thing when your tires hydroplane, where as pedal sponginess is better attributed to fluid failure. The latter (boiling fluid) you identify really fast as the pedal going much closer to the floor, the prior (fade) you experience as a normally solid pedal, but a reduced effect of your normal pedal travel. And I say that hydraulic fluid doesn't usually fail because the boiling point of it increases when it's under pressure, this is why your radiator cap is pressurized, so literally the act of pressing on the pedal improves the performance of your brake fluid. Still figuring out what's actually happening and learning how to deal with it is a better "mod" than pre-emptively replacing your brake fluid. |
#20 | |
Codename: Stitch
I get what you're saying. Driver improvement is always the best and most inexpensive upgrade. But others more experienced than I have recommended more or less that the car stock is great for the track, except for the weaknesses in the brake pads and fluid. And they generally recommended that those are the first, and possibly the only things you need to upgrade before taking the car on track. If there is a known safety issue and a relatively inexpensive fix is available, why not do it proactively? And eliminate that issue from ever coming up. Otherwise you're just deferring something that you will realize that you need by the second or third track day. Sent from my iPad using Tapatalk
#21 |
Drives: '13 Ultramarine FR-S M/T
hey i plan to do at least few autox events this year and maybe a track event if money permits. I also DD my car. Do you think the hybrid/autox pads are worth the money/the right upgrade? i'm still running stock tires and probably will be until next year some time. thanks
#22 | |
Brake pads and fluids are something that should be done for everyone except the absolute novice. Even then, it's better to be prepareed. Do you have airbags in your car? Do you plan on using them? |
#23 | |
Remember, it's a compromise. It's not as good as a race pad, and won't have the bite or heat capacity, but it'll be significantly better than a street pad. Likewise, it will dust more and possibly make noise compared to a street pad, but it does have significantly higher capabilities. |
#24 | |
my problem isnt so much being comfortable with swapping the pads but more of me being too lazy lol. |
#25 |
For competitive reasons be proactive, definitely. Those guys rebuild engines annually regardless of what they think the wear and tear was. Wrenching on the car is another part of the enjoyment of their cars. I knew a guy who ran Solo 1 on his Mk1 and would rebuild when he had less than 1000 miles on the engine. That was his off season. Realistically however no one is being competitive on the road course in this car, at least not without a team of professionals behind them.
For an open track day, take your first time out unmodded, regardless of what anyone else says, the car may be far better than you are. A typical day goes like this: the first half of the day you will be learning the track. The 3rd quarter of the day will be you getting used to the car. And the last quarter of the day you'll be too tired to drive right and if you're not careful, you'll have an off course excursion. The reasons I suggest not doing anything with your brake fluid are 1.) A lot of drivers in these cars will be on tight budgets and will try to do things themselves, and brake fluid is not something to be messed with except by professional shop. 2.) It's likely that more experienced drivers are a lot rougher on their brakes than most of us here, and that means that a first timer on the track, or even an intermediate driver may have no issues with stock brakes. If you aren't absolutely sure you know what you're doing, then best case a self attempted brake fluid change is a tow truck to the shop fix. Worst case your car rolls into the street. Maybe it's only property damage, maybe someone dies. Either way, that's not a risk I would recommend in writing to anyone. |
#26 | |
I'd much rather end up in the gravel trap at Laguna Seca, than in court over involuntary manslaughter charges. You think I'm kidding. I saw a kid accidentally release the automatic gear shifter of his parents car at home out of park, let the car roll down the driveway, and run over their little brother who was like 3 years old. Sure the parents are to blame for not watching their kids playing around the car, but it's not out of the question when messing with your brakes for a 2700 lb car to get out of control. Don't kill your little brother, get rid of cable. Okay well I didn't see it, I came out to the parents screaming, and a story about what happened before the EMT's showed up. Last edited by SeanBlader; 03-18-2014 at 06:01 PM. |
#27 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
So because you saw one incident that nullifies the probably hundreds of thousands of brake jobs done (not to mention exhaust install, tire rotation, oil changes, and a laundry list of other work) in peoples driveways without someone getting hurt? You say he hit the car out of park? Was he doing a brake job? Was he working on the car at all? How is it relevant to whats being discussed? I am all for open debate, but for such a strong feeling please provide more context to how this is relevant.
You should know what you are doing when working on a car. How to safetly jack and support, to use chalks, etc. If not thats what shops are for or call a buddy to come help and learn. Mike did say if he was comfortable with doing it himself, who are we to tell him his comfort level. If he is unsure peopke are haven proven they are more than willing to help in any way they can. Sent from my LT30at using Tapatalk |
#28 | |
All of the above being said, my MR2 has had a caliper rebuild, brake lines replacement, new master cylinder, Porterfield R/S4 pads, and after all that I put in ATE Super Blue brake fluid. Now I have a lighter car, carry more speed into and around the corners than the twins, but having driven on 100+ degree days I never had fade or sponginess even before those upgrades. Really, none of it made much difference for the cost except the pads. Your mileage may vary based on your driving. I still recommend having professionals work on your brake fluid. I feel to recommend otherwise is grossly negligent. Should you decide to ignore my suggestions and have success, then more power to you, hope it goes well. If it goes wrong, and given the prosecution happy nature of the world, well you likely have plausible reasoning to file suit against those recommending otherwise in this thread, as well as the forum owners themselves. More obscure lawsuits have succeeded in the US, and that's a little more invested than I want to be in someone's "brake job". |
| DIY - Changing Your Brake Pads (Race Pads upgrade) | PMok | DIY (Do-It-Yourself) Guides | 53 | 09-03-2021 06:17 PM |
| Volunteers to help install my high temp brake fluid and pads with me? | stockysnail | Northwest | 9 | 07-22-2013 06:15 PM |
| HPDE Brake Pads & fluid | Gopherboy6956 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 9 | 04-25-2013 11:18 AM |
| Essex Valentine's Day Brake Bundle-Pads, lines, fluid | JRitt | Brakes, Suspension, Chassis | 1 | 02-13-2013 01:53 PM |
| Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS | Redline360 | Brakes, Suspension, Chassis | 12 | 01-05-2013 11:20 PM |
