Northern California NorCal
Old 03-14-2014, 10:16 PM   #1
wilfredwong
Drives: 13 FR-S
Suggestion for brake pads and fluid
I'm thinking of upgrading my brake pad and brake fluid since I felt a little brake fade almost the end of my track day.
Does anyone have any suggestion?
My car is currently bone stock.
wilfredwong is offline   Reply With Quote
Old 03-14-2014, 11:55 PM   #2
kster1
kster1's Avatar
I'm using Motul RBF600 brake fluid. For pads, there are lots of options, check the thread in the racing forum for a variety of opinions.
(FWIW, I'm also utilizing Carbotech XP8s with ducting; with this setup, there was no brake fade of any kind today at Thunderhill.)
kster1 is offline   Reply With Quote
The Following 2 Users Say Thank You to kster1 For This Useful Post:
PMok (03-15-2014), wilfredwong (03-15-2014)
Old 03-15-2014, 12:22 AM   #3
wilfredwong
Drives: 13 FR-S
Originally Posted by kster1 View Post
Run something like Motul RBF600 brake fluid. For pads, there are lots of options, check the thread in the racing forum for a variety of opinions.
(FWIW, I'm using Carbotech XP8s with ducting; with this setup, there was no brake fade of any kind today at Thunderhill.)
Did you change the front only or both front and rear?
Old 03-15-2014, 12:28 AM   #4
kster1
kster1's Avatar
I'm running XP8s in both front and rear. I don't daily drive my BRZ, but if you do, keep in mind that the XP8s dust quite a bit. The noise level isn't terribly bad but you will hear them.
Old 03-15-2014, 12:29 AM   #5
wilfredwong
Drives: 13 FR-S
Ok. Thank you very much
Old 03-15-2014, 01:38 PM   #6
PMok
Codename: Stitch
PMok's Avatar
I did my first few track days with just XP8s in front, stock pads in rear. No issues at all felt very good all day. That was on stock tires first 2 track days and then on grippier 140TW tires on 3rd day, very good performance no fade. However I do plan to swap out all 4 brakes to same material next time.
The Following User Says Thank You to PMok For This Useful Post:
wilfredwong (03-16-2014)
Old 03-15-2014, 01:55 PM   #7
MyRx
MyRx's Avatar
If you don't get a chance to swap your pads or fluid, you can certainly just bleed the brakes at the track. Just bleed the fluid that are in the lines.
I know having to swap pads on the stock calipers can be time consuming if you don't have practice or are not too familiar. Bleeding you could learn and do quickly.
The Following User Says Thank You to MyRx For This Useful Post:
Old 03-16-2014, 12:21 AM   #8
wilfredwong
Drives: 13 FR-S
Most of the reviews on XP8s are positive, I might be getting them.
I'll just change all four of them once for all, as well as changing the brake fluid.
Old 03-16-2014, 12:27 AM   #9
wilfredwong
Drives: 13 FR-S
I'm thinking to just swap the pads and leave them there, rather than swap before going onto the track.
I don't know if that's a good idea, and might change my mind later on.
Anyway thank you for telling me that, now I can at least do something if for whatever reason I will be using my stock pad on track.
Btw David Ray (The owner of HOD) had coached me for one section yesterday
Old 03-16-2014, 12:42 AM   #10
PMok
Codename: Stitch
PMok's Avatar
the main concerns of running race pads all the time, will be the noise, dust and potentially accelerated wear of your rotors. just FYI. I've simply learned to live with it.
Old 03-16-2014, 03:42 AM   #11
wilfredwong
Drives: 13 FR-S
hm...I can live with the noise
For dust, will it be solved by cleaning it more often?
And for wearing of rotors, will changing rotors help?
Old 03-16-2014, 10:08 AM   #12
kster1
kster1's Avatar
If you do almost all street driving, you'll likely get some extra rotor wear. But the bigger factor will be the heat cycles on the track as you get faster. This is when you start seeing discoloration and hairline cracks (I recently replaced my rotors).
I wouldn't worry too much about extra wear with XP8s when driving on the street, it shouldn't be too bad.
PMok (03-16-2014), wilfredwong (03-16-2014)
Old 03-16-2014, 11:27 AM   #13
LV2CRNR
LV2CRNR's Avatar
Drives: 2013 black FR-S
I was thinking about the stainless brake upgrade kit with 600 fluid. Comes with slotted rotors, performance pada and stainless lines. $530 at speedfactory86
2013 Scion FR-S black/black auto
LV2CRNR is offline   Reply With Quote
Old 03-16-2014, 12:45 PM   #14
SeanBlader
Drives: Suburu BRZ Limited, black
Just FYI, brake fluid is not an upgrade mod. It either works or it doesn't, there's no variation in capabilities between any hydraulic fluid, unless you happen to be overheating your brakes and boiling the fluid, which is very difficult to do. So, unless you have a very good reason to be removing and spending the trouble to reflush the entire system, I'd recommend leaving it alone.
SeanBlader is offline   Reply With Quote
The Following 2 Users Say Thank You to SeanBlader For This Useful Post:
strat61caster (03-18-2014), wilfredwong (03-16-2014)
DIY - Changing Your Brake Pads (Race Pads upgrade) PMok DIY (Do-It-Yourself) Guides 53 09-03-2021 05:17 PM
Volunteers to help install my high temp brake fluid and pads with me? stockysnail Northwest 9 07-22-2013 05:15 PM
HPDE Brake Pads & fluid Gopherboy6956 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 04-25-2013 10:18 AM
Essex Valentine's Day Brake Bundle-Pads, lines, fluid JRitt Brakes, Suspension, Chassis 1 02-13-2013 12:53 PM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 10:20 PM
