Old 03-18-2014, 11:24 AM   #15
was385
Drives: MT WRB BRZ Limited, 2007 911s
Originally Posted by dbrandt01 View Post
Really though, half the stuff I don't need. Especially the front license plate. It's not required in Alabama. Am I the only one that doesn't mind the original side markers? I don't even notice them on my car.
I'd say main thing for me, is weathertech floor mats. It's raining a lot here and I walk through grass at school. It'd just make things simpler.
Just like a lot of car mods, I think the side markers are mainly based in the pack mentality. Most of the people who are so against them probably wouldn't have ever even noticed them had they not seen someone talking abou them on here. It's just part of car modding.
was385 is offline   Reply With Quote
Old 03-18-2014, 11:26 AM   #16
was385
Originally Posted by meeskee2 View Post
That drain valve is a pretty sweet idea. I'd be affriad that it would open on accident though.
It won't open on accident. If something manages to happen to that valve while you're driving, then some spilled oil is definitely going to be pretty low on your list of concerns. If you get a chance to play around with one, you'll understand what I'm talking about.
Old 03-18-2014, 11:26 AM   #17
dbrandt01
Drives: none
Haha yeah exactly. I bought the car without even noticing them, then I see so many people like "Ugly side markers, you need clears" and it took me a good 3-4 months before I realized mine were orange.
dbrandt01 is offline   Reply With Quote
Old 03-18-2014, 11:32 AM   #18
kseroski
Drives: Dark Grey Metallic BRZ
Markers + amber lights keep it legal
JDK Smoked Side Markers
LED Lights by Diode Dynamics:
Side markers (stage 2 amber)
Dome light (stage 2 white)
License plate (stage 2 white)
kseroski is offline   Reply With Quote
Old 03-18-2014, 11:36 AM   #19
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
Amber side markers are more retro anyway (check out old JDM cars), it's not like you can reprogram the ECU readily to make the clear side markers flash.
krayzie is offline   Reply With Quote
Old 03-18-2014, 11:40 AM   #20
meeskee2
meeskee2's Avatar
Drives: World Rally Blue BRZ Limited, MT
Cool, they're cheap enough, I'll pick one up and check it out.
- World Rally Blue BRZ | Limited | Manual -
"Some guys think that having a better car makes them better than other guys, and those guys are right." -Top Gear
meeskee2 is offline   Reply With Quote
Old 03-18-2014, 11:47 AM   #21
AznBRZer
Drives: 16 CBS WRX Limited
Originally Posted by krayzie View Post
How do those JDM exhaust tips change the sound?
It makes it a tad bit more deeper and throaty. The sound has more to bounce off of compared to the stock tips.
AznBRZer is offline   Reply With Quote
Old 03-18-2014, 11:48 AM   #22
extrashaky
Drives: 2014 BRZ Limited
Originally Posted by zinzan View Post
I'm fine with orange side-markers, plus I'm not 100% sure of the legality of these in Georgia.
They are probably not legal. Even though one of these side markers is not really going to blind anybody, the whole idea behind red and amber lenses is that white light impairs night vision, while light shifted toward red does not (or at least not as much). Anything that can be seen by a driver behind you is generally supposed to be red or amber. Even when it's not bright enough to impair your night vision, a point of white light in your field of vision adds to visual clutter more than an amber light.
Even if state law allows them, keep 'em amber as a courtesy to other drivers.
I've got the BRZ trunk liner, and very happy with it. Great protection recently for a bunch of plants and a bag of mulch from home depot.
I ordered mine with the OEM trunk liner, but not for carpet protection. I got it because when you put something on that rubber, it stays put. I've been amazed at how I can sling the car around and not have my toolbox slide all over the car. It's a must-have just for that.
Old 03-18-2014, 11:52 AM   #23
meeskee2
meeskee2's Avatar
Thats a good idea, I noticed that I have things always sliding all over my trunk. haha.
Old 03-18-2014, 11:58 AM   #24
was385
You won't regret it. I change my oil now without any gloves or rags to clean up. I just turn the valve and go do something else for 10 or 15 minutes while it drains. Makes everything so much better.
The Following User Says Thank You to was385 For This Useful Post:
meeskee2 (03-18-2014)
Old 03-18-2014, 12:19 PM   #25
TrackRider54
TrackRider54's Avatar
Drives: n/a
The Fumoto drain valve has a spring on the "handle" that pushed it into a recess in the valve body. In order to open the valve, you have to lift up on the handle and rotate it. You can also purchase a "lock" for a few bucks that is a clip which snaps on the valve body and won't allow the handle to rotate.
I've had a Fumoto valve on ever vehicle I've owned over the last 10 years and have never had a failure or leak.
TrackRider54 is offline   Reply With Quote
The Following 2 Users Say Thank You to TrackRider54 For This Useful Post:
meeskee2 (03-18-2014), was385 (03-18-2014)
Old 03-18-2014, 12:29 PM   #26
JS + BRZ
Drives: 2010 MS3
Track day tickets.
Old 03-18-2014, 02:38 PM   #27
daiheadjai
daiheadjai's Avatar
Drives: 2003 S2000, 2008 Fit
Lightweight crank pulley.
I did this on Saturday, and it transforms the car from a fairly-responsive Drive-by-wire throttle to a car that feels like a cable-throttle car.
Makes the car much easier to drive. I'd say get this before anything else (maybe adjust the clutch pedal as well).
After that, a heavier shift knob improves shift feel greatly. The stock knob, while not exactly a featherweight, does feel less-than-solid.
daiheadjai is offline   Reply With Quote
Old 03-18-2014, 02:59 PM   #28
funwheeldrive
Originally Posted by Turbowned View Post
Rubberized trunk liner - keeps spills and dirt off your trunk carpet
Sharkfin antenna - makes your car look less cheap
Cusco sports accelerator pedal - aids in heel-and-toe downshifting
Wheel locks - because gettin' yo' rims jacked would not be a good thing
Where can I find the rubber trunk liner?
BRZ Basic SQ Build hellyvin Electronics | Audio | NAV | Infotainment 13 07-22-2014 12:25 AM
Basic STX build? Kodi Tracking / Autocross / HPDE / Drifting 22 02-04-2014 09:50 AM
Taniguchi shows basic technique m.box.design FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 10-25-2013 10:47 PM
What basic tool set to get? ZionsWrath Off-Topic Lounge [WARNING: NO POLITICS] 5 09-05-2013 11:46 AM
Visual Basic and SQL Trashed675 Off-Topic Lounge [WARNING: NO POLITICS] 10 06-10-2013 12:18 PM
