Old 02-26-2014, 09:56 PM   #1
hellyvin
Drives: WRB Brz
BRZ Basic SQ Build
Hey guys,
I had always wanted to upgrade the system in my BRZ, so couple months ago, I saw the group buy going on for the OEM+ reference system. I called around looking for installers and came across Bing and Joey @ Simplicity in Sound. This call led me into the rabbit hole of car audio and SQ builds, the rest is history.
They did a fantastic job with my car. Their passion and pride for their craft is second to none. Bing took the time to answer all my questions and lay out a few options that I could go with. Very pleased with the result
Without further ado, here is build log from Bing himself.
This build was two firsts for us...as some of you may know, we have done a TON of Scion FR-Ss, but oddly enough, not a single BR-Z...and as a subaru owner myself, i always kinda felt like something was missing...UNTIL NOW!!
the other first was our introduction to the new Focal FLAX sandwich speakers. Now, you may think, hey they are focal dealers, whats the big deal here? but those that know personally know that my own listening taste often does not gear towards the brighter more detailed top end typical of Focal drivers, and instead, i prefer smooth, laid back highs found on speakers such as DLS or Morel. This is the reason that you dont see Focal speakers gracing our build logs other than the super awesome and super priced Utopia Be sets
This new technology from Focal though, promises a more subdued top end paired with super midbass and overall sonic performance...the technology was interesting and you can read more about exactly how they build the speaker here:
http://focal-america.com/history/focal-technology/#Flax
I am not really a tech and spec guy, so my biggest interest was finding out of these new drivers delivered on their promise sonically. Having done a bunch of sq builds in FR-Ss with other speakers, this car would give me a very accurate idea of how the FLAX 165FX compared against other speakers such as the Illusion Carbon C6, and the Morel Elate and Hybrid lines.
so...lets get started, here is the car in all its World Rally Blue glory, just the way a subby should be
the goals were the system was pretty simple, this is what we like to call our basic level 1 SQ build:
1. achieve a nice level of sound quality throughout
2. maintain stealthiness and oem appearance inside the vehicle
3. take up as little trunk space as possible
lets get started:
The customer is waiting on the new pioneer NEX headunits to come out, so for now it is running off the Subaru premium navigation headunit.
first up is fuse holder mounting , with a custom made metal L bracket by Joey
the only modification done to the interior for now is the additionl of the arc audio remote bass knob:
now, lets take a closer look at the Focal FLAX PS165FX. the build quality is SUPERB like all focal products, and the cone really does look like nothing else in the world. the tweeter is a magnesium/aluminum inverted dome and looks quite cool as well.
onto the build, the FLAX set went into the oem mounting location. first, new speaker wires were run into the doors, and the entire door sound proofed with blackhole Tile on the outter skin, and a combination of foam and cld damper from STP on the inner skin:
adapter baffles were made and coated with several layers of trunk bedliner:
the baffle was then bolted to the car using oem mounting points and then the FLAX midbass was installed:
the outter door panel also got treated with some CLD damper to prevent resonance:
the same procedure was then repeated on the passenger side:
onto the tweeter mounting, i trimmed a pair of illusion audio tweeter mounts to hold the FLAX tweeter cup, and painted them black so the silver would not peer out through the grille, and then mounted the FLAX tweeters to them:
these were then bolted back into the car via oem hardware:
next comes a series of wiring pics as the bundle travesl from the front of the car to the back, ziptied and secured every few inches:
as they entire the trunk, the driver side wires are divided so all the signal cables go up towards the rear deck, the the not yet used cables for the upcoming rear view camera (to be installed with the NEX headunit) went to a point further back; the passenger side meanwhile, had the spekaer and power cables go upward, and the subwoofer wire go to the back side of the trunk, also note the Mosconi 4to6DSP mounted in a custom made metal bracket in place of the oem amplifier:
the rear deck was also sound proofed with foam and cld:
time for the finished product. here is the view of the trunk. a single sealed fiberglass side enclosure of about .5 cubft is on the passenger side, covered in dyed oem matching trunk liner. An audiomobile Elite 2208 8" subwoofer resides behind a matching painted blue grille. Simple, space saving and has a lil extra touch to it
as for the amps, here is the normal view of the trunk standing behind it with the camera held at chest level, not muching to be seen
duck down further, and two arc audio xdi amps is visible, mounted inverted to a beefy metal rack that is bolted to the rear deck. a 805 on the left sends 2x200 to the tweeter and 1x400 to the sub, while a 804 on the right is bridged powering hte midbass with an additional 2x200 watts. all the wires are routed neatly and passes in and out of factory beams and channels so nothing is hanging down. I can tell you now, after quite a few cars, that wiring this was NOT fun
a few build pics.
this is the mold we already had for the FT86 passenger side trunk, joey made a copy and test fitted it int he car:
then he fabricated the mounting ring baffle, attached it to the back side of the enclosure, and pulled puppy love fleece over the shape and applied resin:
then he made the snap in front grille piece that will be painted later:
when the resin cured and reinforcement dried, joey sanded the enclosure:
then it was wrapped in trunk liner, dyed darker, wired up and blackhole STUFF put into the box:
then the AM 2208 was installed and wired up, the painted grille pressed in place, and its ready to go. it stays in the trunk via combination of press fit, velcro and the factory rubber cargo mat.
this is the cricket bat of an amp rack that joey made, the long bar on the right hand side attaches to the car and mounts the two distribution blocks, here it is during painting and with the amps bolted in place:
and finally, i leave you with two pics of the mosconi 4to6 wiring, before and after the factory foam pieces went back in
so thats it...our first BR-Z done! honestly though, for us it was virtually no different than working on a FR-S...
for the other parts of the system, the 2208 sub continues to impress...i really makes itself known that there is a true subwoofer in the car, it blends extremely well with the front stage and provides a great amount of impact and extension for its size.
as for the rest, here is a quick review of the Focal FLAX PS165FX:
1. build quality and ease of installation: superb! the appearance of the driver is one that oozes high quality...installation wise, i appreciate the mounting slots on the mdibas instead of the holes to give you a bit more margin for error, while the tweeter mounting system is very well thought out...overall excellent and befitting a speaker in this 6-700 dollar price range.
2. midbass: once the speaker loosened up after about an hour or pink noise, the midbass performance is very very good. i would not call it an output and extension beast such as a focal KRX or a Morel elate, but high passed at 80 hz, it extended down naturally and smoothly and the impact was very very good...on par with the illusion C6 i would say, it is also very effortless and i couldnt really drive it into distortion even wtih 200 watts on tap. i think it will provide a great midbass anchor for any system, two way or three way. when coupled with a subwoofer, playing madonna's holiday intro really gave my check a good thumping. Nils Lofgren's keith dont go also was very enjoyable with the natural resonance of the guitar.
3. midrange: very balanced and smooth without any major peaks and dips. that is ultimately, what i like to find in a spekaer...just it power it up without any eq on it and see how it sounds, and truth be told, its was very good and i didnt have to address too many things on the eq. nice resolution, things just in general sounded like how they were suppose to sound, not too shouty, or lispy.
4. highs: this, as mentioned, was my biggest concern...and i have to admit, they were spot on in saying these are a different type of sound. its NOT harsh at all, hell often, firing against the windshield can result in even more highs, but in this car, once i got the gain balance right, it was again, smooth and natural, no blaring female focals, no painful cymbals...just nice...but it still has all the details that focal is known for. i would say it doesnt sound too different than the carbon C6 and the seas lotus reference, tweeters that i personally like, and they also look similar on the RTA, prety flat with a slight rise at the upper frequences from 16khz on.
overall, i am VERY impressed by these speakers, and i think you will see us using more and more of them in the future. they are still overall hotter uptop than the morels, but not at all in a displeasing way...and since i am one of those people who is very sensitive to highs (call my listening taste boring and flat perhaps hahaha), that means a lot
cheers,
Bing
hellyvin is offline   Reply With Quote
Old 02-26-2014, 10:32 PM   #2
Visxco
Visxco's Avatar
Drives: BRZ 2014 SWP
This. Is. Amazing.
I'm honestly so jealous and would never be able to do anything like this.
Visxco is offline   Reply With Quote
Old 02-27-2014, 12:41 AM   #3
Acree
Acree's Avatar
Drives: 13 CSB BRZ Ltd
God. Bless.
Fantastically done and executed. Bravo.
2011 BMW M3 (No torque dip)
2013 Subaru BRZ - SOLD - Build Thread
Acree is offline   Reply With Quote
Old 02-27-2014, 02:32 PM   #4
rupert
Audio & Bacon Junkie
rupert's Avatar
Drives: 2013 WRB BRZ Ltd
Bing has done another fantastic job! I have added this to the directory.
rupert is offline   Reply With Quote
Old 02-27-2014, 02:37 PM   #5
simplicityinsound
simplicityinsound's Avatar
Drives: 2010 Subaru LGT
thanks guys...joey deserves most of the credit for the build, as he came up with the subbox, the amp rack, i just did the grunt work of wiring and front speaker install plus tuning
Mobile Electronics Magazine Top 100 Installer 2012-2013
simplicityinsound is offline   Reply With Quote
Old 02-27-2014, 05:08 PM   #6
rupert
rupert's Avatar
Oops!
Great job Joey!
Old 02-27-2014, 06:09 PM   #7
thill
These guys do a really good quality job everytime. You can tell they really care about what they do.
Old 02-27-2014, 08:19 PM   #8
CamryDS
Drives: 2003 Camry Blue | 2013 FR-S White
this was a fantastic build
CamryDS is offline   Reply With Quote
Old 02-27-2014, 09:37 PM   #9
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
Excellent-looking build
^GT5 Replay Photo Mode^
Old 02-28-2014, 06:27 AM   #10
labskaus
labskaus's Avatar
Drives: Toyota GT86
Nice install
labskaus is offline   Reply With Quote
Old 03-01-2014, 07:53 AM   #11
dz93
Drives: toyota 86
Absolutely love it.
Coming from an spl car previously with wires everywhere, when i get
my toyota 86/fr-s i'll want to upgrade the sound system but keep it as OEM as possible.
this thread has definitely inspired how i want my setup to be.
Favourite bit being the amp cricket bat.
many thanks from me
dz93 is offline   Reply With Quote
Old 03-03-2014, 10:11 AM   #12
tripjammer
tripjammer's Avatar
Drives: WRB BRZ limited 6MT
I love this build! The best so far!
tripjammer is offline   Reply With Quote
Old 06-22-2014, 04:47 PM   #13
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
I want to mount my amp under the deck. Any pointers on how to do this?
Old 07-22-2014, 12:25 AM   #14
HiXxY
Shoegazer
HiXxY's Avatar
Drives: 2015 WRB BRZ Series.Blue
clean!
HiXxY is offline   Reply With Quote
Basic STX build? Kodi Tracking / Autocross / HPDE / Drifting 22 02-04-2014 09:50 AM
Borla UEL basic thoughts/ review loogs Engine, Exhaust, Transmission 39 09-28-2013 01:18 PM
What basic tool set to get? ZionsWrath Off-Topic Lounge [WARNING: NO POLITICS] 5 09-05-2013 11:46 AM
Visual Basic and SQL Trashed675 Off-Topic Lounge [WARNING: NO POLITICS] 10 06-10-2013 12:18 PM
GC basic coilovers / Cusco Strut bar Evilbrz151 Brakes, Suspension, Chassis 3 03-29-2013 09:35 PM
