Northwest AK, ID, OR, WA
Old 03-15-2014, 11:26 AM   #1
evan
Drives: fr-s
evan's innovate fr-s hits 311.5whp on the juice
Uncorrected on the dyno dynamics (no hearts were broken yesterday).
For those of you not familiar with my build, sprintex 210 (not +) powered non-intercooled. Meth injection. ~11.5 pounds at peak.
Limited driving yesterday, but so far a monster. Exhaust change tamed the beast inside too.
Still tuned on brzedit. Good job to @PRE-Erich.
evan is offline   Reply With Quote
Old 03-15-2014, 12:46 PM   #2
digital_assassin
digital_assassin's Avatar
Drives: 2013 FR-S Matte Orange
Great numbers Evan!
digital_assassin is offline   Reply With Quote
Old 03-15-2014, 04:30 PM   #3
Jmonty
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
Glad you are enjoying the new tune
Jmonty is offline   Reply With Quote
Old 03-15-2014, 08:15 PM   #4
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
What, not 400?
Old 03-15-2014, 08:47 PM   #5
evan
Drives: fr-s
Originally Posted by DarrenDriven View Post
What, not 400?
Haha.. Will need forged short block and a turbo or bigger SC to get there.
Old 03-16-2014, 12:35 AM   #6
clayrush
Drives: FRS,09 370z, 00 CelicaGT-S, 85 300Z
Nice.
Why no intercooler?
Too much loss over the benefits gain of cooler air with the meth?
clayrush is offline   Reply With Quote
Old 03-16-2014, 12:52 AM   #7
evan
Drives: fr-s
@clayrush Correct. Laminova is restrictive. Any gains over my existing setup are unlikely. With E85 and the spray, I'm already keeping knock at bay and cooling the charge. It's working very very well. I have other plans for this twin screw and a much bigger intercooler.
Old 03-16-2014, 12:03 PM   #8
clayrush
How do you think you would do without the spary?
My girlfriend really wants a fi kit that has a carb certificate. But she is ok cconverting to e85. And then back to base kit for smog time.
Old 03-16-2014, 12:31 PM   #9
stockysnail
Just the tip
stockysnail's Avatar
With 70mm pulley, without the spray I've seen supposed numbers of 285 on E85. Without E85 you'll get around 260-ish not intercooled and a little less intercooled, like 250-ish (on 92oct), which is where I'm at with 70mm. You're basically at the limit of this kit at these numbers. The kit doesn't have a post blower air temperature reading and the intercooler is very restrictive so they are hard to tune and know exactly what's going on.
Old 03-16-2014, 04:43 PM   #10
evan
Drives: fr-s
Couple of thoughts on this:
Any discussion of numbers needs to be on the same type of dyno at a minimum. I learned my lesson on this one. All of my published numbers have been on a dyno dynamics (uncorrected) which typically read 10% or so less than a dynojet. Nonetheless, dynos are tuning and bragging tools.. Nothing more. If I take it to a dynojet operator the way it is now, I'm certain it will read higher.
With E85, Erich made it clear that the meth is not really doing anything in the addition of octane points since it only took 2 deg of timing to achieve a nearly 40 horse increase. The meth is there to cool the charge. My car smells of rubbing alcohol now and I kinda like it
I'm running the 70mm too. 700cc injectors. 3 bar map sensor made things easier to tune and I now have a dual fuel pump setup (OEM and DW) in the back to keep the fuel on the hump with the bigger pump flowing. I do have a post-blower IAT read courtesy of a hole drilled in the IAT plate on the manifold. This is also used for reading psi values for the meth to spray. I was tuned with the post blower IATs in mind.
The intercooler (laminova) is restrictive, that's why I'm not running one. I don't think these are hard to tune and that is evident by my conversations with Erich at PRE. My car is running great on Erich's brzedit tune. I still think there is some power to be had with these blowers. You just need to start getting creative. I've never been one to just plug n play so we will see what else this setup will bring!
There is also the 210+ with upgraded rotors and the 335 and of course, compound charging (turbo feeds the SC). Post blower is where things get interesting in the last setup I mentioned. Wild things.. (Forged shortblock needed)
Old 03-16-2014, 05:42 PM   #11
clayrush
Compound charging is a small part of the reason we are thinking about getting the innovative charger, If we decide to eventually make it a track only car years from now. The weather out here usually stays below 80 so I am hoping e85 will be well enough without meth for us.
Especially because my girlfriend is hoping for 250-275 for now.
We have our cars tested on both a mustang dyno and a dynamic pack dyno.
I have not had a chance to look and your overall build progress. When I get to a real computer I'll take a look.
Old 03-16-2014, 06:36 PM   #12
evan
Drives: fr-s
I don't have a build thread right now. I'll put one up soon.
Old 03-17-2014, 03:34 PM   #13
evan
Drives: fr-s
'merica!!
Old 03-17-2014, 09:59 PM   #14
NickFRS
Drives: 2013 Asphalt FRS
Keep in mind Evan is using Meth at this point to cool the Blower instead of a intercooler. The blowers get molten hot. We also live in Oregon where it's hardly ever over 80.
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
NickFRS is offline   Reply With Quote
GREDDY FRS/BRZ TURBO KIT IS HERE!! +93.5whp!!! genometuning Forced Induction 27 04-19-2014 08:04 PM
Replacing stock speakers without juice fmsida Electronics | Audio | NAV | Infotainment 17 03-01-2014 04:16 AM
ORANGE JUICE FELL ON SEATS! enjoi23 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 7 05-17-2013 10:31 AM
Stock car / Corn juice / FA20club tech4pdx Engine, Exhaust, Transmission 15 01-06-2013 09:08 AM
