| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#15 | |
#16 |
Scrape Master
Drives: Goal: Oldest FRS State Side
The rear have stock control arms so it never changed since there is no way of adjusting camber with stock parts. On the front picture I just remembered I took that pick with stock suspension and never retook when I got coils. With the coils on now the top of the wheel is 100% flush with the fender, I never touched the camber on the plates. If you want I could retake a pic of how the fronts look now.
#17 | |
| The Following User Says Thank You to wparsons For This Useful Post: | WolfsFang (03-05-2014) |
#18 | |
Scrape Master
#19 |
NW Region Moderator
Drives: FR-S No More
#20 |
Drives: 2006 STi
wow this looks amazing. and like spitfire said up above, -2 to -3 degrees all around and youll be good, so pretty much natural camber when lowering the car + playing with the camber plates a lil and you should be golden. Good luck, looking foward to seeing this!
#21 |
any guess as to how much that silver car is lowered by?
#22 |
Drives: 86 GTS
While searching around for wheels a while ago, I found this, unsure of how thick the adapter is (they are actual 33GTR wheels as far as my knowledge goes) but:
![]() Looks amazing imo, and doesn't seem like you need crazy camber to get them to fit. Last edited by Tranz; 03-18-2014 at 06:02 AM. |
#23 |
Drives: '14 Subaru BRZ
Bringing this back from the dead.
Anybody have legit concrete facts of what needs to be done to make these fit? Don't want to run silly camber.
Life's too short to drive a boring car
#24 |
Drives: brZed
| The Following User Says Thank You to slava For This Useful Post: | HeadBanger (11-22-2014) |
#25 |
Drives: brZed
oh and as far as what needs to be done, if you dont cut the factory studs when you install the adapters, you will have to shave some metal off the wheel (in the back) to make them fit. This can be the case with a lot of different wheels with the adapters.
#26 |
Drives: '13 WRB BRZ '22 ISM BRZ Ordered
Wheel Directory: OEM Nissan Skyline R33 17x9.0 +30
Bump from the dead. Thought I would post mine finally.
#27 |
Also plan on doing the hub conversion at some point next year!
| Wheel Directory : Drag DR-38 17x9.0 +38 | smbstyle | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 21 | 07-21-2019 06:32 PM |
| Wheel Directory: ESM 004 17x9.0 +38 | Scott | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 25 | 06-26-2017 04:54 AM |
| Wheel Directory: Rota DPT 17x9.0 +35 | lightdir | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 12 | 05-17-2016 03:10 AM |
| Wheel Directory: Rota RT5 17x9.0 +30 | b-25 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 12-03-2013 02:21 PM |
| Wheel Directory: XXR 531 17x9.0 +35 | Drftfan | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 07-19-2013 05:16 PM |
