Old 01-03-2014, 09:32 AM   #1
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
Wheel Directory : Drag DR-38 17x9.0 +38
Haven't seen a thread for these wheels, so I figured I'd start a new one.
Here are the specs:
Drag DR-38
17x9
+38 offset
73mm bore
19.4 lbs (weight that I measured, manufacturer lists like 21 lbs)
Price: $358 shipped through Discount Tire Direct
I've been looking for an inexpensive gunmetal wheel for a while that I can use on the car for daily driving, and came across these when I was browsing Discount Tire Direct. Here's the best part - these suckers were $358 shipped to my door from them, which included some special promotion they were running at the time with a $50 off coupon (usually run that promotion every few months). They kind of remind me of a less aggressive 57Xtreme.
Here are some pics; I'll have them mounted up shortly on OEM suspension, and then next weekend they'll be on RCE Tarmac 2 coilovers, so I'll post pics then as well.
Tires are another good deal I found; GT Radial Champiro UHP1's, it's a 280 treadwear summer tire, not many people in the US are running them, but seem popular in Australia. They were $300 shipped to my door through Discount Tire Direct for a 245/40R17.
Here's another member running them with good reviews:
http://www.ft86club.com/forums/showthread.php?t=44940
2013 SWP BRZ
Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781
smbstyle is offline   Reply With Quote
Old 01-03-2014, 09:41 AM   #2
zeppy
Drives: subaru brz-limited
it's a good cheap wheel, not the lightest but does the job. I got the same wheel in the tire size. Here's a shot if you were wondering how it will look:
zeppy is offline   Reply With Quote
The Following User Says Thank You to zeppy For This Useful Post:
smbstyle (01-03-2014)
Old 01-05-2014, 03:13 PM   #3
Travisty75
Travisty75's Avatar
Drives: 2015 Scion FR-S
Originally Posted by zeppy View Post
it's a good cheap wheel, not the lightest but does the job. I got the same wheel in the tire size. Here's a shot if you were wondering how it will look.
How much do you poke with these wheels? I ordered the 17x9 +28 because they were the only ones in green, and according to the wheel fitment calculator the fronts would only poke 3mm.
Looking at your picture though, yours looks like a perfect fitment for your ride height. What size tires too? I ordered 255/40 Nitto's.
Travisty75 is offline   Reply With Quote
Old 01-05-2014, 06:53 PM   #4
zeppy
No poke, I run rs3's 245/40/17. Basically add 10mm to my photo and that's how yours will look
Old 01-05-2014, 07:00 PM   #5
Travisty75
Travisty75's Avatar
Yep, but from the picture you provided it already looks flush. How close are you?
I'm not looking for poke, and if anything I'd like to keep things inboard a bit.
Your front tires don't sit inside the fender by a half inch, do they?
Old 01-08-2014, 09:48 AM   #6
smbstyle
smbstyle's Avatar
Here are pictures on the STOCK suspension. I should have pictures on RCE T2 coilovers by this weekend.
Definitely makes the wheel gap more pronounced as the face of the rim sits out further. With the stock wheels tucked into the wheel wells it isn't as noticeable.
Even my wife, who is against me modifying the car, told me that I needed to lower it, lol, so for any of you who are in the same situation, get the wheels first; it'll convince other family members that the car needs to be lowered!
2013 SWP BRZ
The Following User Says Thank You to smbstyle For This Useful Post:
Travisty75 (01-08-2014)
Old 01-08-2014, 05:41 PM   #7
Travisty75
Travisty75's Avatar
Wow, thanks for all those pictures. That put me at complete ease setting where your wheels sit width-wise.
I had the +28's on order, but after seeing this thread I have cancelled those and have now gone with the +38. With a drop it should be about perfect!
Looking forward to seeing your car dropped and how well the tires tuck. Are you going for an alignment at the same time? Do you have camber numbers in mind?
Old 01-08-2014, 06:51 PM   #8
smbstyle
smbstyle's Avatar
Yep, alignment and corner balancing next week. Pretty much just going for max camber with OEM top hats and crash bolts
2013 SWP BRZ
Old 01-09-2014, 01:58 PM   #9
MPI_Jack
Drives: '13 FRS, '02 BMW 530i(550HP, turbo)
I'm sold on these. Great looking and inexpensive!
MPI_Jack is offline   Reply With Quote
The Following User Says Thank You to MPI_Jack For This Useful Post:
smbstyle (01-09-2014)
Old 01-09-2014, 02:13 PM   #10
Philly758
Drives: GMC
I have been considering these wheels for a while. They look great and I think I am sold.
Also, those tires look good but they are so cheap I've always overlooked them. What are your impressions? Sticky? Stiff sidewalls? I guess only time will tell with wear.
Philly758 is offline   Reply With Quote
Old 01-09-2014, 04:01 PM   #11
Travisty75
Travisty75's Avatar
Quoted from the OP's first post:
TL;DR
Great wet traction, good tread life, great braking, soft sidewall, and overall not a super aggressive-driving tire.
I just got my wheels and tires in. Tried to mount them up (255/40 N555's) and they rub against the spring perch. I'm looking for coilovers and LCA's now, ugh.
Old 01-09-2014, 04:20 PM   #12
smbstyle
smbstyle's Avatar
I'll be posting up some driving reviews shortly; only took them around the neighborhood for a spin so far after install.
2013 SWP BRZ
Old 01-09-2014, 11:43 PM   #13
chiprez
Was this $50 coupon per wheel? That's a damn good price. I've decided on getting these after I sel off the 18's I'm on now.
chiprez is offline   Reply With Quote
Old 01-10-2014, 12:39 AM   #14
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Should look even better of you decide to lower it a good inch to inch and half.
The Following User Says Thank You to OICU812 For This Useful Post:
smbstyle (01-10-2014)
Wheel Directory: Enkei RPF1 17x9.0 +35 D1cker Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 801 06-18-2024 06:31 AM
Wheel Directory: Axis OG-SAN 17x9.0 +32 GuerillaRacing Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 09-24-2016 12:46 AM
Wheel Directory: Rota RT5 17x9.0 +30 b-25 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 12-03-2013 02:21 PM
Wheel Directory: Drag DR-38 17x8.0 +??/17x9.0 +?? blue_frs Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 12-03-2013 10:07 AM
Wheel Directory: XXR 531 17x9.0 +35 Drftfan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 07-19-2013 05:16 PM
