Old 03-15-2014, 09:30 PM   #1
Cal3000
Drives: Panda FR-S
Regarding Switching from Pump Gas to E85 at the gas station
I know this question has been asked many times before.
Will I need to completely drain the tank before I switch to e85 or can I have, maybe, 1 or 2 gallons of pump gas in the tank and fill the rest with e85?
I know most pump gas use about 10% Ethanol.
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
242whp/197ft-lb on Mustang Dyno (91 octane water)
284whp/223ft-lb on Mustang Dyno (E85)
Cal3000 is offline   Reply With Quote
Old 03-15-2014, 09:50 PM   #2
pmccut
Drives: Blue Subarus
It really depends on the tune. Some tuners might offer you a e70 map for this (assuming you get e85 year round). When I've switched I bought multiple 5gal jugs and kept going until I was well below E - fill it up at home so you don't look nuts at the pump with a harsh start.
'13 GBS BRZ 6MT | FBM 9:1 w/ GTX3076R| FBM oil cooler + catch-can + radiator + SPAL fans| Rays 57xtreme / PSS | Perrin 2.5" FP | Invidia 2.5" OP | Perrin 3" CBE | RCE T2s | Exedy Stg1
'15 STI LE | Cobb Stg1
pmccut is offline   Reply With Quote
Old 03-15-2014, 10:06 PM   #3
nelsmar
Talk to your tuner. Especially since you are running a supercharger.
I typically run to E, drive XX # of miles, put in 1 - 2 gallons of E85 (depending on driving conditions / time) and then drive XX# of miles to burn that fuel off and then fill the tank that way I burn a "blended" mix while in closed loop only.
My flickr - Canibeat
Local magazine scout
Old 03-15-2014, 10:08 PM   #4
Cal3000
Drives: Panda FR-S
Or look nuts revving your engine down to E at the pump. 5gal jugs seem like a good idea. Do you have ECUTek? I'm thinking the tuner could possibly set up multiple maps for the map switch. Instead of reflashing all the time, you can turn the ignition to the 1 position and switch to the desired map, then start the car.
Old 03-15-2014, 10:13 PM   #5
Cal3000
Drives: Panda FR-S
So you run pump gas to E, then place 1 or 2 gal of e85 which possibly mixes with pump gas. Run the car to let the ecu adjust in closed loop, then fill up with full e85?
Old 03-15-2014, 10:26 PM   #6
nelsmar
1) Yes I use ecutek
2) I made my own maps including "Migration maps" that make life easier
3) Yes you can make an E85 dedicated map to switch to. I prefer to make people flash so they don't accidentally drive on the wrong map when tired as your car will not remember your map. Sometimes it does but never ever ever depend on it remember which map you were on.
4) You should talk to YOUR tuner
5) If you cant get ahold of him and you are on 100% oem fuel system drive down to where the light comes on. Once the light comes on reset your average MPG meter and trip B. Calculate burning 1.5-2 gallons (You can actually go further than this). So if you are getting 20MPG drive 30miles. Once you hit this point add 1-2 gallons of E85. Reset your average MPG meter & Trip B again, calculate the same for the amount of E85 you put into the tank. Assuming your tuner has not disabled long term fuel trims keep under 3,600RPM and 30% throttle.
Do not blip throttle with significant throttle angle on a supercharger even in neutral! This will produce boost!
If you are confused and want to talk on the phone you are more than welcome to PM me your number and I can give you a call!
Old 03-16-2014, 09:07 AM   #7
86viper
Drives: 2013 Toyota 86 GTS
Take this with a grain of salt. But when my light comes on, my obd reader still shows 25% fuel remaining. Which is about right when i go-to fill it. Aussie Spec Toyota 86
86viper is offline   Reply With Quote
Gas Station Rant PollosHermanos Off-Topic Lounge [WARNING: NO POLITICS] 98 08-28-2014 08:43 PM
Switching to E85 and back bfrank1972 Engine, Exhaust, Transmission 8 09-10-2013 10:16 PM
Which gas station(s) do you OR folks pump at? m.box.design Northwest 41 05-12-2013 01:01 AM
Coasting into the gas station? bdanisi Scion FR-S / Toyota 86 GT86 General Forum 28 03-07-2013 08:16 PM
Xm Radio Station Bones36 Electronics | Audio | NAV | Infotainment 2 01-07-2013 12:21 PM
