Northwest AK, ID, OR, WA
Old 10-02-2012, 10:52 PM   #1
m.box.design
m.box.design's Avatar
Drives: 2013 Whiteout FRS
Which gas station(s) do you OR folks pump at?
So far I've done 76 and Shell gasoline. I know people like to praise Shell V-Power but I think I've been getting better throttle response from using 76 gas. Just wondering what you guys are filling up with around these neck of the woods.
Old 10-02-2012, 10:55 PM   #2
Touge_ninja
Sending rods to their doo
Touge_ninja's Avatar
Drives: 700HP STi
Costco and shell are my regular stops
Touge_ninja is offline   Reply With Quote
Old 10-03-2012, 12:12 AM   #3
Neziah
Drives: 2013 HotLava FRS, 2005 Legacy
I use shell Vpower most of the time, once in a while Chevron , both seem to work as well as the other.
HotLava FRS MT
Neziah is offline   Reply With Quote
Old 10-03-2012, 12:27 AM   #4
deucethemoose
Functionally Retarded
deucethemoose's Avatar
Drives: LinkECU V6 MR2 - MKVII Golf R
Costco.
1991 MR2 - T-tops - Crimson Red - 1MZ-FE 3.0L - Other Stuff
I'm not really an asshole, but I play one on the internet.
deucethemoose is offline   Reply With Quote
Old 10-03-2012, 01:19 AM   #5
SeattleJeremy
SeattleJeremy's Avatar
Drives: Vibe
Costco.
SeattleJeremy is offline   Reply With Quote
Old 10-03-2012, 12:48 PM   #6
Chen
Regional Moderator
Chen's Avatar
Drives: 00-AP1 20-A90 06-Z33 07-FA5 93-NA1
Shell or Chevron.
Chen is offline   Reply With Quote
Old 10-03-2012, 06:04 PM   #7
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Shell, Chevron, Union 76 or the occasional Safeway
NOT Astro (or any other sub-grade stations)
NOT Arco (I have actually felt my cars run worse on the crap)
Old 10-03-2012, 06:15 PM   #8
m.box.design
Yeah I tried ARCO before on my old 4runner, ran like crap and emptied much faster. Just wondering if anyone else is noting marginal differences between the likes of Shell vs. 76 vs. Chevron.
So far I'm feeling more throttle response from 76 vs. Shell V-Power, but it could also be my imagination. Maybe the next 3 fill-ups I'll ask my wife to go fill it up from these 3 in random order so I can gauge it from a more blind approach.
Old 10-03-2012, 06:45 PM   #9
Zaggeron
Zaggeron's Avatar
Drives: '13 BRZ Limited '10 370ZR
I think that any high quality gasoline will work. I think the key thing here is use the same brand all the time. While each manufacturer tests their own additives, what hasn't been tested is the result of mixing gas companies A's additives with the additives from company B.
2013 GBS Subaru BRZ Limited 6MT
2010 PG 370z Roadster: Sport/Touring 6MT
Zaggeron is offline   Reply With Quote
Old 10-03-2012, 07:16 PM   #10
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
I still believe it's all the same. Sure some of the additives are different but all the fuel comes from the same 4 distributors (I think it's only 4).
Last time I did some research I believe it showed ARCO has surprisingly good quality fuel but just not the same massive levels of additives like Chevron.
I have ran several cars: ITR, NSX, S2000, FRS, Prelude and my race car on ARCO with no noticeable affects, ever. It's just gasoline. Unless it's stored improperly or is heavily contaminated there should be very little difference station to station.
Old 10-03-2012, 07:17 PM   #11
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
Shell V-Power FTW
Old 10-23-2012, 01:00 AM   #12
31katys
31katys's Avatar
Drives: whiteout mt fr-s
Nothing but Chevron in all my vehicles.
31katys is offline   Reply With Quote
Old 10-23-2012, 11:26 AM   #13
whataboutbob
AutoX-10/10ths every run
Shell, sometimes 7-11 (Citgo?)
Build thread:Here
Old 10-23-2012, 01:50 PM   #14
DarrenDriven
NW Region Moderator
Many years ago I watched a documentary show on how gas works, and it covered some of this stuff. The pipeline that carries gas around the country is shared by all of the gas companies, with at least one notable exception. Chevron might produce gas at their refinery and pump it into the pipeline, but when they pump out the same volume at the other end, it could have been produced by a different refinery owned by a different company. Essentially, all gas is basically the same.
Where it differs is when it gets to the regional storage location. It is there that each company mixes in different additives to create their own brand of gas. All of the top name brands (Chevron, Texaco, Union 76, Shell, etc) do this and other than their personalized additives, you are getting the same thing.
There is a lower grade of gasoline that is slightly less refined, and that stuff gets sold to the off-brand stations. Around Portland these are Space Age, Leathers, etc. You should stay away from these stations if you can.
ARCO is the notable exception to the pipeline. They don't use the same pipe and they produce their own gas with their own mixture of additives.
Like I said, this was years ago that I watched this, so maybe some of the details are not accurate anymore... and it was before Safeway, Fred Meyers and Costco began selling gas, so I have no idea where theirs comes from.
Tallahassee Folks b_massey02 Southeast 21 03-31-2014 01:36 PM
Which gas station did you get your FRS/BRZ refilled in Calgary? percyng CANADA 34 03-17-2014 02:19 PM
RT* folks at Nats des Tracking / Autocross / HPDE / Drifting 33 09-10-2012 07:07 PM
Where did all the old folks go? S2KtoFT86 Off-Topic Lounge [WARNING: NO POLITICS] 36 11-04-2010 12:52 AM
