Old 03-07-2013, 04:14 PM   #1
bdanisi
You Made Bro?
bdanisi's Avatar
Drives: Raven 86
Coasting into the gas station?
You know when you don't need gas you see one every 2 seconds? But then when you are late and on E you can't find one to save you life? Well I filled up 11.2 gallons today haha. Pretty close to empty. What's the most you've had to put in? If you can beat mine ill be fairly impressed by your stupidity haha jk
bdanisi is offline   Reply With Quote
Old 03-07-2013, 04:19 PM   #2
DarkSunrise
DarkSunrise's Avatar
Isn't the FR-S fuel tank 13.2 gallons? You theoretically had 2 gallons to spare =)
2022 BRZ Build
2013 FR-S Build
Old 03-07-2013, 04:22 PM   #3
mezdup
#1362
mezdup's Avatar
Drives: 2014 Ice Silver WRX
yea there's almost 2 gallons that serve as a reserve tank after you hit E
mezdup is offline   Reply With Quote
Old 03-07-2013, 04:22 PM   #4
bdanisi
You Made Bro?
bdanisi's Avatar
Drives: Raven 86
Holy shit my meter is way off then I was under the empty sign. I think I will have to read the owners manual but I doubt it's much bigger than 11 and a half
Damn I stand corrected. Good to know.
Old 03-07-2013, 04:24 PM   #5
MVJ1975
Automatic Hooligan
MVJ1975's Avatar
I liked the gas gauge on the tC - it didn't have "E" for empty, but rather "R" for reserve, as the tank isn't empty at that point.
I generally run down to the point the light comes on and then fill up, unless I'm travelling and might be in an area where there aren't gas stations. If that's the case I'll start looking for a gas station at 1/4.
MVJ1975 is offline   Reply With Quote
Old 03-07-2013, 04:26 PM   #6
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
I always fill up when i'm at 1/4, and when i pump i only put $20 in. Lets me monitor my driving. Though if i know i'm traveling long distances i'll fill it up.
Old 03-07-2013, 04:28 PM   #7
Eurasianman
Chief
Eurasianman's Avatar
Drives: 2013 DGM BRZ Premium 6MT
Well, according to the manual, when your fuel light comes on, you have approximately 7 liters or 1.8 gallons of gasoline left. I just put gas in last week and the gas pump stopped at 11.5 gallons The way I look at it, if you drive moderately, you're probably getting ~25 MPG (at least for me, this works). So, 13.2 gallons * 25 = 330 miles. I reset my Trip meter every time I fill up to help me keep track. I basically don't bother looking for a gas station until I hit 300 miles.
Eurasianman is offline   Reply With Quote
Old 03-07-2013, 04:31 PM   #8
strat61caster
strat61caster's Avatar
Owners manual also states that you should get fuel as soon as it hits "E", the gasoline lubricates the fuel pump and all the mechanisms in the fuel tank, if you let it sit with low fuel you could dry it out and cause premature degradation of the parts.
But still, no worries as long as you don't actually run out of gas on the road you'll be fine.
ineedyourdiddly
Old 03-07-2013, 04:32 PM   #9
bdanisi
You Made Bro?
bdanisi's Avatar
Drives: Raven 86
Except for today is always fill up when the light comes on. Is it bad for the engine to run completely out of gas? I assume it's not good for it and is something I don't plan on doing it but will it cause long term damage
Old 03-07-2013, 04:40 PM   #10
bdanisi
You Made Bro?
bdanisi's Avatar
Drives: Raven 86
Damn so much knowledge just dropped on me. Many thanks. Still can't believe the tank is almost 14 gallons.
Old 03-07-2013, 04:45 PM   #11
zaptorque
zaptorque's Avatar
Drives: 2013 Asphalt FR-S
I was under the impression the tank is 12gal. I always try and fill once it hits E, usually end up putting about 10.5 gal each fill.
zaptorque is offline   Reply With Quote
Old 03-07-2013, 05:22 PM   #12
HunterGreene
Hail Magnet
HunterGreene's Avatar
Most I have ever put in was 12 gal.
Old 03-07-2013, 05:40 PM   #13
KingGeo
Drives: FRS
spec in Canada is 50l which is 13.2 US gal or 11 imp gal
KingGeo is offline   Reply With Quote
Old 03-07-2013, 05:55 PM   #14
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
12.4 is my worst. The tank is 13gal US, the light turns on after 10 gal US. I think people are confusing US and Imperial gallons.
Which gas station did you get your FRS/BRZ refilled in Calgary? percyng CANADA 34 03-17-2014 03:19 PM
Which gas station(s) do you OR folks pump at? m.box.design Northwest 41 05-12-2013 02:01 AM
College Station Firestorm 6MT ortizwyld Southwest 7 03-23-2013 11:36 AM
Xm Radio Station Bones36 Electronics | Audio | NAV | Infotainment 2 01-07-2013 01:21 PM
